P1 Video scaling — Parallax Forums
P1 Video scaling
pic18f2550pic18f2550 Posts: 400
edited 2024-02-05 16:33 in PASM/Spin (P1)
Hello,
I would like to modify this driver a little.
The resolution in the memory is 256x192.
The resolution on the monitor is 512x384.
To double the lines is no problem but how do I get the pixel 2x in a row?
Halving the pixel clock is not possible with 35MHz.
Does anyone have a tip?
  • AribaAriba Posts: 2,697
    edited 2024-01-22 20:37
    To half the pixelrate, try to change:
                            movi    frqa,#(pr / 5) << 3     'set pixel rate
    into
                            movi    frqa,#(pr / 5) << 2     'set pixel rate
    or set the PLL to x2 instead of x4
    Andy
    Edit: You also need to set the pixel based constants like hp, vp, hf, hs, hb to half the value.
  • Wuerfel_21Wuerfel_21 Posts: 5,845
    edited 2024-01-22 23:00
    Far simpler, no need to change the main video clock, just double up the VSCL value used for the visible area. See documentation for that register.
  • pic18f2550pic18f2550 Posts: 400
    edited 2024-01-26 16:38
    vscl_pixel long 1 << 12 + 32 '1 pixel per clock and 32 pixels per set
    vscl_pixel long 2 << 12 + 32 '2 pixelclock per pixel and 32 pixels per set
    With the correct description, I now also understand this.
    '  xtiles = hp / 32              '{Pixelbreite}
      xtiles = hp / 64              '{Pixelbreite}
    You actually need to double the 32, too. That indicates the number of video clocks per WAITVID tile. So by setting 2 << 12 + 32, you only actually get the first 16 pixels.
  • Ok.
    I couldn't recognise this connection in the translated texts.
    Thank you.
    vscl_pixel long 2 << 12 + 64 '2 pixelclock per pixel and 32 pixels per set
