Propeller IDE not working
bambino69
in Propeller 2
Finally get some dev time and have been programming away for a couple days.
I fire up the machine tonight and get errors and no prop tool.
I have uninstalled and downloaded a fresh IDE, but it too will not run.
I will look thru my files for an older ide, as I don't want to waste my time off mucking around with windows.
Anyone else having an issue.
That sounds like the registry issue…
Might need to delete prop tool stuff from registry…
Try searching this site for how to do that.
I’m thinking happens when you open files from removable media…. Especially top level object .
But I’ve seen registry deletion of parallax entries fix this before
As in here:
https://forums.parallax.com/discussion/175220/propeller-tool-2-9-3
That did the trick, Thanks Rayman.
