FlexProp: a complete programming system for P2 (and P1) - Page 49 — Parallax Forums
1464749515262
  • evanhevanh Posts: 17,095
    edited 2023-06-19 17:10
    Here's the compiled pasm using -O1 --fcache=0. It has inlined the whole call path. I suspect maybe the TESTP needs a spacer in front of it ...
    '     ser.str(string("Press any key to skip count down : ")) 'tell user to press a key to avoid waiting
        mov local02, ##@LR__0041
    '   REPEAT WHILE ((c := byte[s++]) <> 0)
    LR__0011
        rdbyte  arg01, local02 wz
        add local02, #1
     if_e   jmp #LR__0013
    '     tx(c)
    '   wypin(tx_pin, val)
        wypin   arg01, #62
    '   txflush() 'rja
    '   repeat
    LR__0012
    '     z := pinr(tx_pin)
        testp   #62 wc
     if_ae  jmp #LR__0012
        jmp #LR__0011
    LR__0013
  • RaymanRayman Posts: 16,098
    @ersmith Is there any way to get the internal PST compatible terminal from the command line?
    edited 2023-06-19 17:29
    Yeah, with the constants, the code has optimised down so much that an existing hidden bug in smartpin handling has emerged.
    Rayman,
    Something like this is a workaround:
    PUB tx(val)    ' send one byte
      wypin(tx_pin, val)
      pinr(tx_pin)
      txflush() 'rja
    EDIT: I guess in fairness, it's probably not the compiler's job to know the pipeline effects on a smartpin.
    loadp2 -T -b <baud rate here> <the file you want to load (or not)> (notice the uppercase T)
    @Wuerfel_21 Thanks, that does it.
  • pik33pik33 Posts: 2,417
    edited 2023-06-19 18:19
    This is a txflush that works with -O1
      wypin(tx_pin, val)
      txflush(tx_pin) 'rja
    PUB txflush(txpin)  | z    ' wait for character sent
        asm
    p1  rdpin z,txpin wc
        if_c jmp #p1
        endasm
    Edit: I read the listing. Now this txflush is done in the fcache. That introduces a delay for fcache loading and it can be this delay that makes it work.
    edited 2023-06-20 00:50
    Pik,
    That one will work anyway since RDPIN uses the smartpin's specialised bus rather than the IN bit via TESTP. However they are functionally a little different. RDPIN WC looks at shifter [not] empty flag whereas TESTP WC looks at buffer [not] full flag. This affects tx performance. TESTP is more desirable.
    There is an input staging register on INA/INB signals between the smartpins and the cogs (Just like there is between the custom pad-ring and the smartpins). This is likely all it took to create our timing headache.
    edited 2023-06-20 21:47
    I've used a slightly different approach in my own routines when I wrote similar handlers before Spin2 was written. I chose the greatest buffering method, where the execution path is stalled only when there is a new character to be placed in the buffer but the buffer is still full. It's a little more complex than the exit-when-buffer-is-not-full approach above.
    putch
    '  input:  PB
    ' result:  (none)
    'scratch:  (none)
            rqpin   inb, #DIAGTXPIN  wc 'transmiting? (C high == yes)  *Needed to initiate tx
            testp   #DIAGTXPIN  wz      'buffer free? (IN high == yes)
    if_nc_or_z  wypin   pb, #DIAGTXPIN      'write new byte to Y buffer
    if_nc_or_z  ret wcz         'restore C/Z flags of calling routine
            jmp #putch          'wait while Smartpin is both full (nz) and transmitting (c)
    A beneficial side effect of its structure, which I didn't appreciate, is it has plenty of time from WYPIN to TESTP.
    edited 2023-06-21 11:46
    The next glitch detected. This is still the same project:
    https://gitlab.com/pik33/P2-retromachine/-/tree/main/Propeller/Basic - the file is https://gitlab.com/pik33/P2-retromachine/-/blob/main/Propeller/Basic/basic003.bas
    function expr(ct as integer) as expr_result,integer
    ' On input: ct = current token position
    ' On output: expression result value and a new ct
    dim t1, t2 as expr_result
    dim op as integer
    t1,ct = muldiv(ct)                      ' call higher priority operator check. It will itself call getval/getvar if no multiplies or divides
    op = lparts(ct).token               ' that idea is from github adamdunkels/ubasic
    do while (op = token_plus orelse op = token_minus orelse op = token_and orelse op=token_or)
      ct+=1
      t2,ct = muldiv(ct)
      select case op
        case token_plus
          t1=do_plus(t1,t2)
        case token_minus
          t1=do_minus(t1,t2)
        case token_and
          t1=do_and(t1,t2)
        case token_or
          t1=do_or(t1,t2)
      end select
      loop
    return t1,ct
    end function
    There are 3 other functions that are declared as fun(integer) as expr_result, integer. And the result is
    "C:/Users/Piotr/Downloads/flexprop-6.1.5/flexprop/bin/flexspin" -2  --tabs=8 -D_BAUD=230400 -O1    --charset=utf8 -I "C:/Users/Piotr/Downloads/flexprop-6.1.5/flexprop/include"  "D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas" -DFF_USE_LFN -DFF_CODE_PAGE=852
    Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2023 Total Spectrum Software Inc. and contributors
    Version 6.1.9-beta-v6.1.8-14-g3fac69b7 Compiled on: Jun 18 2023
    basic003.bas
    |-hg009.spin2
    |-|-psram.spin2
    |-|-|-psram16drv.spin2
    |-psram.spin2
    |-usbnew.spin2
    |-audio093b-8-sc.spin2
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/hg009.spin2:363: warning: used spaces for indentation (previous lines used tabs)
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/hg009.spin2:955: warning: used spaces for indentation (previous lines used tabs)
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:536: error: inconsistent return values from function expr: expected 4 elements but found 2
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:568: error: inconsistent return values from function muldiv: expected 4 elements but found 2
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:592: error: inconsistent return values from function getvalue: expected 4 elements but found 2
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:604: error: inconsistent return values from function getvar: expected 4 elements but found 2
    child process exited abnormally
    Finished at Wed Jun 21 13:35:43 2023
    All these lines where the error was detected are exatly the same: return t1,ct
    This is the result from the newest github commit; the previous version I used (6.1.6) crashed with a segmentation error on this code.
    edited 2023-06-21 13:24
    Another problem. The simplified test code:
    union eresult
      dim iresult as integer
      dim uresult as ulong
      dim lresult as longint
      dim ulresult as ulongint
      dim fresult as double
      dim sresult as string
      end union
    class expr_result
    dim result as eresult
    dim result_type as ubyte
    end class
    class part
      dim part$ as string
      dim token as integer
      dim priority as integer
    end class
    type parts as part(125)
    dim lparts as parts
    dim ct as integer
    dim t1 as expr_result
    const token_decimal=512
    print "Expected result=2, result type=1"
    print
    lparts(0).part$="2"
    lparts(0).token=token_decimal
    ct=0
    t1=expr()
    print "Expression result="; t1.result.uresult
    print "Result type=";t1.result_type
    function expr() as expr_result
    t1 = muldiv()
    print "in expr: result=";t1.result.uresult
    print "in expr: result type=";t1.result_type
    print
    return t1
    end function
    function muldiv() as expr_result
    t1 = getvalue()
    print "in muldiv: result=";t1.result.uresult
    print "in muldiv: result type=";t1.result_type
    print
    return t1
    end function
    function getvalue() as expr_result
    dim op as integer
    op=lparts(ct).token
    select case op
      case token_decimal
        t1.result.uresult=val%(lparts(ct).part$): t1.result_type=1
        print "in getvalue: result=";t1.result.uresult
        print "in getvalue: result type=";t1.result_type
        print
      end select
    return t1
    end function
    The result:
    ( Entering terminal mode.  Press Ctrl-] or Ctrl-Z to exit. )
    in getvalue: result=2
    in getvalue: result type=1
    in muldiv: result=2147489292
    in muldiv: result type=10
    in expr: result=4127513600
    in expr: result type=76
    Expression result=0
    Result type=0
    Edit: tried using different var names are different in every function, the result is the same. Compiled with Version 6.1.9-beta-v6.1.8-14-g3fac69b7 Compiled on: Jun 18 2023
    The latest commit now gives (a bunch of) these errors:
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:518: error: Unable to multiply assign this target
    D:/Programowanie/P2-retromachine-1/Propeller/Basic/basic003.bas:518: error: Too many elements on right hand side of assignment
    in lines that call the functions like this:
    t1,ct=expr(ct)
    The test program from post #1451 still produces improper results
    This is even more simplified test code. No complex class, no nested class, no unions.
    class expr_result
      dim uresult as integer
    end class
    print
    t1=expr()
    print "Expression result="; t1.uresult
    dim t2 as expr_result
    t2 = muldiv()
    print "in expr: result=";t2.uresult
    print "in expr: result type=";t2.result_type
    print
    return t2
    end function
    dim t3 as expr_result
    t3 = getvalue()
    print "in muldiv: result=";t3.uresult
    print "in muldiv: result type=";t3.result_type
    print
    return t3
    end function
    dim t4 as expr_result
    dim op as integer
    t4.uresult=2: t4.result_type=1 ' todo token_int64
    print "in getvalue: result=";t4.uresult
    print "in getvalue: result type=";t4.result_type
    print
    return t4
    end function
    in muldiv: result=10
    in muldiv: result type=136
    in expr: result=-167718803
    in expr: result type=136
    Expression result=0
    Result type=0
    In the test code above, if t2, t3, t4 are declared global at the start of the program, the result is:
    in muldiv: result=0
    in muldiv: result type=0
    in expr: result=0
    in expr: result type=0
    Expression result=0
    Result type=0
    The more interesting thing happens if
    class expr_result
    end class
    dim t1,t2,t3,t4 as expr_result
    print
    t1=expr()
    'dim t2 as expr_result
    t2 = muldiv()
    print
    return t2
    end function
    'dim t3 as expr_result
    t3 = getvalue()
    print
    return t3
    end function
    'dim t4 as expr_result
    print
    t3=t4
    t4.uresult=12345
    return t4
    end function
    The result is:
    in muldiv: result=2
    in expr: result=0
    Expression result=0
    Result type=0
    The simplest code:
    class expr_result
    end class
    dim t3,t4 as expr_result
    print muldiv().uresult
    t3.uresult=23456
    print "Returned uresult: ";getvalue().uresult
    t3 = getvalue()
    print "Assigned uresult:";t3.uresult
    print
    return t3
    end function
    t4.uresult=2
    return t4
    end function
    gives
    Returned uresult: 2
    Assigned uresult:23456
    23456
    However I can assign a single field and it works
    class expr_result
    end class
    t3.uresult=23456
    t3.uresult = getvalue().uresult
    print
    return t3
    end function
    t4.uresult=2
    return t4
    end function
    Returned uresult: 2
    Assigned uresult:2
    2
    edited 2023-06-22 10:04
    Oops, about the serial TX flags, I got their function a little wrong in my description above. IN (TESTP) is a buffer empty rather than a buffer full flag. The difference suits events and interrupts which have data initiation from another routine so as to transition the TX buffer handling from idle to active, and naturally falls back to idle once data is transmitted.
    So that's why my handler needs the extra RQPIN WC to get it going without using events. The extra complexity wasn't an oversight in smartpin wiring.
  • @pik33 : There are a whole bunch of bugs in function return and multiple assignment :(. For now I'd offer the following advice to avoid these bugs:
    (1) Don't try to use any structures or unions in a multiple assignment (that is, in a, b = foo(b) neither a nor b should be a class). Use BYREF function parameters instead.
    (2) Try to use only 4 byte or 8 byte sized items in classes that will be returned from functions: no ubyte or ushort in classes that will be returned from functions.
    I hope to fix at least some of the bugs soon, but there are several intersecting issues so it's complicated.
    edited 2023-06-23 11:54
    When changed ubyte to ulong, the last simple test code works.
    Edit: more than 3 elements in the class, even if they are 4 bytes, fails.
  • FlexProp 6.2.1 is available now. This has a revamped system for method pointers, support for having multiple littlefs file systems (including both flash and RAM disks), a new BASIC interface class system, and the ability to run with no window.
    Note that the config file format has changed, so the FlexProp 6.2.1 config (things like the baud rate, optimization options, and so on) will be reset to the default when you first start it up. Older FlexProp config files can co-exist with the new one (they have different names).
  • MicksterMickster Posts: 2,906
    edited 2023-07-13 09:28
    @ersmith
    Hello Eric :+1:
    P2 Edge Rev B
    rem simple program to toggle a pin
    const pin = 56
    direction(pin) = output
    do
    output(pin) = not output(pin) 'With both FB 6.1.2 and now 6.2.1, The LED goes off and never changes
    'pintoggle(pin)       'I replace the above with pintoggle and I get a flashing LED
    pausems 1000
    loop
    Loving littlefs, BTW :)
  • Same problem with:
    const pin = 56
    dim state
    state = 0
    do
    pausems 500
    state = not state
    output(pin)=state
    pausems 500
    loop
    Craig
  • Thanks @Mickster , there was a problem with constant pins above 32 not working correctly because of some 64 bit constant changes; that's actually been around for a while. It'll be fixed in the next release.
    edited 2023-07-13 13:51
    Right-o :+1:
    Bit intrigued by the mention of "RAM disk" :| Couldn't find any details in the Basic.pdf
    Edit: Guessing that "RAM" is the onboard flash and the "flash" is the SD card.
    Rgds,
    Craig
    edited 2023-07-13 14:54
    RAM is a HUB RAM, flash is a (part of a) flash :) These use littlefs. SD card is SD card, it uses FAT32. A PSRAM can make a good ramdisk... but this is yet to be written...
    Maybe we need something like in 8-bit Atari OS: you can define a block device, write read block and write block procedure, and then mount it. We have already a character devices implemented in FlexBasic (SendRecvDevice), so maybe it can be also done for block devices? Something like this:
    mount "/dev", _vfs_open_blockdevice(init,readblock,writeblock,close,fstype)
  • @Mickster said:
    Right-o :+1:
    RAM is either HUB RAM or an external add-on RAM (like hyperram). There's an example in the samples/shell/shell.c file that comes with FlexProp.
  • Just started to play with double precision and expecting clock cycles to be gobbled-up.... Doesn't happen :) is this Ada or Eric wizardry? :D
    Craig
    edited 2023-07-13 19:56
    There is no double precision floats yet. You can declare and use them, but the computation is done in single resolution.
    However, 64bit integers already work.
  • ersmithersmith Posts: 6,262
    edited 2023-07-13 21:26
    I took some PSRAM code from @Wuerfel_21 's MegaYume project, but it doesn't seem to be working, no doubt due to my screwing something up. It's in include/spin/psram*.spin2. @rogloh 's HyperRam/HyperFlash driver does work though for the ramdisk. The existing LittleFS config structure is used to set up alternate drivers; that is, you can call _vfs_open_littlefs_flash(fmt, config) where fmt is a flag (0 = do not format the storage) and config is either 0 (to use the default flash driver) or a block of data as follows:
    config(0) = flash page size in bytes (typically 256)
    config(1) = erase page size in bytes (typically 4K or 64K; use the config(0) value for RAM disks)
    config(2) = starting offset within flash, must be a multiple of config(1)
    config(3) = size of area to use, must be a multiple of config(1)
    config(4) = pointer to block device info, or 0 for default device; see below
    config(5) = pin mask low; mask indicating which pins the driver will use
    config(6) = pin mask high; mask indicating which pins the driver will use
    config(7) = reserved, set to 0
    The block device structure has 7 words and looks like:
    class block_device
      dim blk_read as function(dst as any ptr, flashAddr as uinteger, size as uinteger) as integer
      dim blk_write as function(src as any ptr, flashAdr as uinteger) as integer  ' write 1 block
      dim blk_erase as function(flashAdr as uinteger) as integer                  ' erase 1 block
      dim blk_sync as function() as integer
      dim read_cache as ubyte ptr  ' points to a config(0) sized scratch area
      dim write_cache as ubyte ptr ' points to another config(0) sized scratch area
      dim look_cache as ubyte ptr  ' points to a third config(0) sized scratch area
    end class
    edited 2023-07-13 21:37
    Boy am I red faced 🤣😂
    I guess the good news is that I don't really need them because I get more precision than I can use :+1:
    Already using 64bit integers to extend my encoder counter. I guess it might roll over in a few thousand years but hey, I'll worry about it (much) later 😂🤣
    Craig
    Yea, I saw you did something there... Main takeaway is that the delay values used for roger's driver setup aren't actually correct in the emulators because I gave up on trying to keep them synced with the custom access code. Also, they need to be tuned based on clkfreq. There's a tester program out there somewhere that helps identify the ideal range. Speaking of custom access code, for a ramdisk in the ususal sort of synchronous C file I/O framework, just make some simplified read/write functions and run them in fcache instead of wasting a cog on it. If the application brings it's own cog mode RAM driver for advanced usage it can hook up the ramdisk functions itself. Though I haven't really written RAM init code yet, but that shouldn't be too hard, either.
  • I've uploaded binary releases of FlexProp 6.2.3 to both github and my Patreon page. The changes from 6.2.1 are:
    Version 6.2.3
    - Added strpbrk(), strcoll(), strspn() functions for the C library
    - Fixed a potential crash in Spin2 parsing of @func()
    - Fixed taking the difference of a pointer and generic value
    Version 6.2.2
    - Fixed some 64 bit constant issues with DIR/OUT/IN manipulation
    - Make sure garbage collector does not reclaim BASIC I/O wrapper
    - Reverted waitatn() change from 6.2.0
    @ersmith A PSRAM based file system would be pretty neat. Lot of moving parts to make that work I think. Not exactly sure how practical for use it is, but interesting to think about.
    I'd personally target the 16-bit interface like that Parallax Edge board has. That would have a speed advantage over flash/uSD I think.
    The littlefs for extra flash space though is really nice. I do want to try that out soon.
