Prop tool - cannot find Object"Debug_Lcd.spin -editor tab,work folder or library — Parallax Forums
msiriwardenamsiriwardena Posts: 301
edited 2022-11-11 21:04 in Propeller 1
I am trying to run (F10) and I keep getting this error.
I tried - retyping very carefully, copied the title and pasted on to the program also re-installed propeller
tool.
I see the file
in the library and in the work folder - in the search path.
I have had this issue before and copying the title and pasting it have solved this i ssue before.
I have tried these many times and still cannot get the file to execute.
Please I need help to resolve this issue.
Thank you.
Siri
  • If you're using a newer version of the Propeller Tool you will need to save your top-level file first. When we just had one Propeller, that wasn't required, but now it is.
  • @JonnyMac
    Thank you very much for your help.
    siri
