Does FlexProp support C++?
I'm not in favor of C++ myself, but as I understand it, TensorFlow Lite for microcontrollers is using C++. See https://www.tensorflow.org/lite/microcontrollers
Now I'm using Arduino-devices for Machine Learning projects, but I'd love to be able to use P2 for it.
Kinda a little bit but not really. Looked at the code for 5 seconds, not gonna happen. Though the P2 LLVM port might be worth trying.
FlexProp supports a few C++ extensions to C, enough for some mild Arduino programs, but nowhere near all of C++11. So no, the tensorflow code isn't going to work on FlexProp.
As Ada mentioned there is a P2 LLVM project which should support C++. There's also the risc-v p2 compiler, which turns the RISC-V GCC compiler into a P2 compiler.
Ok, would be interested to check out the LLVM project, but I don't have the bandwidth or knowledge. As IoT and tinyML is quite hot now, I believe a P2 board, equipped with some Click or other sensors, would be a good fit.
