Propeller C (SimpleIDE) functions/commands webpage — Parallax Forums
There used to be a webpage that listed all the Propeller C commands and functions, explained what they did, how they worked, what parameters they took, and what values they returned.
I remember the link to it in Learn was not in an obvious place.
I looked in the SimpleTools library on GitHub but I could not find Propeller.h
A program used CLKSET and the first number is some hex value which I am guessing chooses XTAL1 and PLL16 since the 2nd value is 5 Million for 5 MHz.
Also I have never used fdserial so I am not familiar with it's functions.
I am not familiar with compilers so is the nuts and bolts of Propeller C written in C or PASM and where on GitHub is that code located?
  • SimpleIDE is the front end for propgcc that compiles your program into pasm code for the P1.
    SimpleIDE
    propgcc
    In addtion the functions used by it are contain in Simple Libraries
    When in simpleIDE under help Simple Library Reference show information on the Simple Libraries.
  • I see that fdserial is listed as one of the Propeller C Simple Protocols Tutorials but that was a Yahoo search.
    The help in SimpleIDE is great but I need to find that website link.
  • The source code for all the simple tools can be found in the learn folder.
    SimpleIDE\Learn\Simple Libraries\TextDevices\libfdserial
    fdserial uses some spin code under the covers to work.
    Not sure if you found the answer you were looking for here, but I believe you can find the information on what you want from the html files associated with the simple libraries folder you are using. world of knowledge in those.
