Piezo buzzer drivin' — Parallax Forums
Just thought that it would be really funny to play some obnoxiously tinny audio out of one of these motherboard piezo buzzers. They conveniently fit right onto a normal pin header...
It does infact work, but even if I drive it differential across two DAC pins (124R_3V vs 75R_2V seems to make no major difference), it's kind of disappointingly quiet.
How do PC motherboards drive these to make them obnoxiously loud? Might be using that 12V juice...
  • For a laser tag accessory, I use an N-FET to drive it with the other side connected directly to the battery (~7v). I don't know about PC motherboards.
    edited 2022-07-16 22:09
    Here are a couple things you can do to increase loudness:
    1. Add a series inductor to your piezo circuit. This will increase the drive voltage to the device.
    2. Create a resonance chamber around the piezo device. This will allow standing waves within the chamber to build up and enhance the transfer of energy to the air. I used this technique with the Parallax SoundPAL. The resonator was made of shrink tubing:
    That works? I thought these are capacitor-like devices (which would need to be driven back up?)
  • JonnyMacJonnyMac Posts: 9,450
    edited 2022-07-16 22:44
    I checked with the piezo vendor and they said it was okay to drive single-ended with a square wave. Ultimately, though, we went with a model with an internal driver that simply needs on-off control. We don't need to control frequency, we just need the box to beep.
  • Huh. Only have FETs laying around though, which IIRC aren't terribly great at amplifying analog signals. Oh well.
  • Wuerfel_21Wuerfel_21 Posts: 5,571
    edited 2022-07-16 22:51
    I did however figure out that raising the amplitudes being output by a factor of 6 doesn't really cause major distortion. Maybe I just can't hear how distorted it is through the tiny buzzer, but that gets it up to usable volume levels, though still rather quiet.
  • roglohrogloh Posts: 5,995
    edited 2022-07-17 00:53
    If you sweep slowly through the frequency range you might find some spots where it resonates loudly. I had some that liked around 2kHz (and became piercingly loud).
  • BTW, when I designed the SoundPAL, I did not use a piezo transducer but, rather, a miniature magnetic speaker. It was driven from an nMOSFET. With the resonator attached, it was quite loud.
