Piezo buzzer drivin'
Wuerfel_21
in Propeller 2
Just thought that it would be really funny to play some obnoxiously tinny audio out of one of these motherboard piezo buzzers. They conveniently fit right onto a normal pin header...
It does infact work, but even if I drive it differential across two DAC pins (124R_3V vs 75R_2V seems to make no major difference), it's kind of disappointingly quiet.
How do PC motherboards drive these to make them obnoxiously loud? Might be using that 12V juice...
For a laser tag accessory, I use an N-FET to drive it with the other side connected directly to the battery (~7v). I don't know about PC motherboards.
Here are a couple things you can do to increase loudness:
Add a series inductor to your piezo circuit. This will increase the drive voltage to the device.
Create a resonance chamber around the piezo device. This will allow standing waves within the chamber to build up and enhance the transfer of energy to the air. I used this technique with the Parallax SoundPAL. The resonator was made of shrink tubing:
That works? I thought these are capacitor-like devices (which would need to be driven back up?)
I checked with the piezo vendor and they said it was okay to drive single-ended with a square wave. Ultimately, though, we went with a model with an internal driver that simply needs on-off control. We don't need to control frequency, we just need the box to beep.
Huh. Only have FETs laying around though, which IIRC aren't terribly great at amplifying analog signals. Oh well.
I did however figure out that raising the amplitudes being output by a factor of 6 doesn't really cause major distortion. Maybe I just can't hear how distorted it is through the tiny buzzer, but that gets it up to usable volume levels, though still rather quiet.
If you sweep slowly through the frequency range you might find some spots where it resonates loudly. I had some that liked around 2kHz (and became piercingly loud).
BTW, when I designed the SoundPAL, I did not use a piezo transducer but, rather, a miniature magnetic speaker. It was driven from an nMOSFET. With the resonator attached, it was quite loud.
