Class module for Waveshare LCD + utilities — Parallax Forums
UnsoundcodeUnsoundcode Posts: 1,532
edited 2022-06-01 19:54 in micro:bit & Mai-Z:bot
1 The Module
For a very reasonable cost it is possible to include a TFT LCD into your projects and have a good looking color display by which to view all different kinds of information. In particular I want to share what I have learnt about the Waveshare 1.8 inch display module for microbit
https://www.waveshare.com/1.8inch-lcd-for-micro-bit.htm
This information is not limited to the Waveshare module but will work for other modules that have the ST7735 driver
https://www.amazon.com/HiLetgo-ST7735R-128160-Display-Arduino/dp/B00LSG51MM/ref=asc_df_B00LSG51MM/?tag=hyprod-20&linkCode=df0&hvadid=198064456940&hvpos=&hvnetw=g&hvrand=15540617363296329196&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9013259&hvtargid=pla-350878433908&psc=1
https://www.ebay.com/itm/115094405925?hash=item1acc294325:g:3~wAAOSw3S5hkHhW&amdata=enc:AQAHAAAA4Dq7+7kT8mY6Yl47XL9UUVMXmyHQoU3IhtBHvsvoBedeZSLi4OtXjlNAoOccAuqzsVAFvrijl95TNybpSGQiAIIKBSfAufBqvPAfrwuAr8bSmsVo6trhr4MRfn7tDiWi0Ljtt4iZaxjjLL09uRARJei0E7TmgCwQkntVy9m/ljeywPME4Q34wepcU09i1jRuzKqUEvzFB272zI2WGl/9jj22+msgMkcNq0VKXMRvZUG3OKkLXutFNjt6MKwxaEu6z16b/zU88xPNw1jB0EaWpy1etFSsh8idsuS4geWcw0Mu|tkp:BFBMlL6dl6Jg
The Waveshare module is great for plug and play and has a decent amount of SRAM to help us out. Display and ram are accessed through a SPI connection.
So that we keep to the same page the class module below should be saved as a file called TFT.py, we can rename these files to whatever we want at a future date. The name is important for now because we are going to import the module into our test programs. If you need more information on importing modules into you programs then that is something we can discuss. The test program can be saved as a python file with any name you choose.
Module Code
# TFT.py .... a class module for initializing the 1.8 inch Waveshare/microbit LCD
from microbit import *
# spi.init(baudrate=10000000, bits=8, mode=0, sclk=pin13, mosi=pin15, miso=pin14)
# uBit pin 1 = lcd backlight an analog signal
# uBit pin 2 = sram cs pin low for select
# uBit pin 8 = lcd reset pin
# uBit pin 12 = lcd data/command hi for data low for command
# uBit pin 16 = lcd cs pin low for select
LCD_WIDTH = 160
LCD_HEIGHT = 128
FONT_WIDTH = const(6)
FONT_HEIGHT = const(11)
FONT_PIXEL_CNT = const((FONT_WIDTH * FONT_HEIGHT) * 2)
SRAM_READ = 0x03
class LCD:
    def __init__(self,spi):
        self.spi = spi
    def init_lcd(self):
        pin8.write_digital(1)
        sleep(1)
        pin8.write_digital(0)
        sleep(1)
        # ST7735R Frame Rate
        self.WriteReg(0xB1)
        self.WriteData_8Bit(0x01)
        self.WriteData_8Bit(0x2C)
        self.WriteData_8Bit(0x2D)
        self.WriteReg(0xB2)
        self.WriteReg(0xB3)
        self.WriteReg(0xB4)  # Column inversion
        self.WriteData_8Bit(0x07)
        # ST7735 Power Sequence
        self.WriteReg(0xC0)
        self.WriteData_8Bit(0xA2)
        self.WriteData_8Bit(0x02)
        self.WriteData_8Bit(0x84)
        self.WriteReg(0xC1)
        self.WriteData_8Bit(0xC5)
        self.WriteReg(0xC2)
        self.WriteData_8Bit(0x0A)
        self.WriteData_8Bit(0x00)
        self.WriteReg(0xC3)
        self.WriteData_8Bit(0x8A)
        self.WriteData_8Bit(0x2A)
        self.WriteReg(0xC4)
        self.WriteData_8Bit(0xEE)
        self.WriteReg(0xC5)  # VCOM
        self.WriteData_8Bit(0x0E)
        # ST7735 Gamma Sequence
        self.WriteReg(0xE0)
        self.WriteData_8Bit(0x0F)
        self.WriteData_8Bit(0x1A)
        self.WriteData_8Bit(0x18)
        self.WriteData_8Bit(0x2F)
        self.WriteData_8Bit(0x28)
        self.WriteData_8Bit(0x20)
        self.WriteData_8Bit(0x22)
        self.WriteData_8Bit(0x1F)
        self.WriteData_8Bit(0x1B)
        self.WriteData_8Bit(0x23)
        self.WriteData_8Bit(0x37)
        self.WriteData_8Bit(0x10)
        self.WriteReg(0xE1)
        self.WriteData_8Bit(0x17)
        self.WriteData_8Bit(0x33)
        self.WriteData_8Bit(0x29)
        self.WriteData_8Bit(0x2E)
        self.WriteData_8Bit(0x30)
        self.WriteData_8Bit(0x39)
        self.WriteData_8Bit(0x3F)
        self.WriteData_8Bit(0x03)
        self.WriteReg(0xF0)  # Enable test command
        self.WriteReg(0xF6)  # Disable ram power save mode
        self.WriteReg(0x3A)  # 65k mode (RGB 565)
        self.WriteData_8Bit(0x05)
        self.WriteReg(0x36)  # MX, MY, RGB mode
        self.WriteData_8Bit(0xF7 & 0xA0)  # RGB color filter panel (result = A0)
        self.WriteReg(0x11)
        sleep(1)
        self.WriteReg(0x29) # Turn LCD on
    def clear(self, color=0xFFFF):
        self.set_window(0, 0, LCD_WIDTH, LCD_HEIGHT)
        self.set_color(color, LCD_WIDTH + 2, LCD_HEIGHT + 2)
    def set_backlight(self, level=1000):
        pin1.write_analog(level)
    def WriteReg(self, register):
        pin12.write_digital(0)  # EN LCD command
        pin16.write_digital(0)  # EN LCD CS
        self.spi.write(bytearray([register]))
        pin16.write_digital(1)  # remove LCD CS EN
    def WriteData_8Bit(self, data):
        pin12.write_digital(1)  # EN LCD data
        self.spi.write(bytearray([data]))
    def WriteData_Buf(self, color, length):
        col = bytearray(3)
        col = color.to_bytes(2, "big")
        for i in range(length):
            self.spi.write(bytearray([col[0]]))
            self.spi.write(bytearray([col[1]]))
    def set_window(self, Xstart, Ystart, Xend, Yend):
        # set the X coordinates
        self.WriteReg(0x2A)
        self.WriteData_8Bit((Xstart & 0xFF) + 1)
        self.WriteData_8Bit(((Xend - 1) & 0xFF) + 1)
        # set the Y coordinates
        self.WriteReg(0x2B)
        self.WriteData_8Bit((Ystart & 0xFF) + 2)
        self.WriteData_8Bit(((Yend - 1) & 0xFF) + 2)
        self.WriteReg(0x2C)
    def set_color(self, color, width, height):
        self.WriteData_Buf(color, width * height)
    def lcd_fast_write(self, buff):
        for val in buff:
            spi.write(bytearray([val]))
    def draw_pixel(self, x, y, color):
        self.set_window(x, y, x+1, y+1)
        self.WriteData_8Bit(color >> 8)
        self.WriteData_8Bit(color & 0xFF)
    def draw_point(self, Xpoint, Ypoint, color, Dot_Pixel):
        for XDir_Num in range(Dot_Pixel):
            for YDir_Num in range(Dot_Pixel):
                self.draw_pixel(
                    Xpoint + XDir_Num - Dot_Pixel, Ypoint + YDir_Num - Dot_Pixel, color
    def draw_hline(self, x_0, y_0, length, color):
        self.set_window(x_0, y_0, x_0 + length, y_0)
        col = bytearray(3)
        for val in range(length):
    def draw_vline(self, x_0, y_0, length, color):
        self.set_window(x_0, y_0, x_0 + 1 , y_0 + length)
        col = bytearray(3)
    def draw_char(self, x_0, y_0, char_id=0):
        offset = char_id * FONT_PIXEL_CNT
        buf = self.ram_read(offset, FONT_PIXEL_CNT)
        self.set_window(x_0, y_0, x_0 + FONT_WIDTH, y_0 + FONT_HEIGHT)
        for val in buf:
            self.spi.write(bytearray([val]))
# Memory
    def ram_read(self, addr, read_cnt=1):
        address = bytearray(3)
        address = addr.to_bytes(3, "big")
        pin2.write_digital(0)  # CS ram
        spi.write(bytearray([SRAM_READ]))
        spi.write(bytearray([address[0]]))
        spi.write(bytearray([address[1]]))
        spi.write(bytearray([address[2]]))
        RD_Byte = spi.read(read_cnt)
        pin2.write_digital(1)  # remove ram CS
        return RD_Byte
Test Code
# Circle.py
# TFT-LCD demo
import math
from TFT import LCD
WHITE = 0xFFFF
BLACK = 0x0000
BLUE = 0x001F
RED = 0xF800
MAGENTA = 0xF81F
GREEN = 0x07E0
CYAN = 0x07FF
YELLOW = 0xFFE0
GRAY = 0x9492
lcd = LCD(spi)
lcd.init_lcd()
lcd.set_backlight(1000)
lcd.clear(GRAY)
def draw_circle(center_x, center_y, radius, color):
    for i in range(360):
        rads = math.radians(i)
        x1 = center_x + math.sin(rads) * radius
        y1 = center_y - math.cos(rads) * radius
        lcd.draw_pixel(int(x1), int(y1), color)
draw_circle(50, 68, 15, BLUE)
draw_circle(50, 68, 16, BLUE)
draw_circle(85, 68, 15, BLACK)
draw_circle(85, 68, 16, BLACK)
draw_circle(120, 68, 15, RED)
draw_circle(120, 68, 16, RED)
draw_circle(68, 83, 15, YELLOW)
draw_circle(68, 83, 16, YELLOW)
draw_circle(105, 83, 15, GREEN)
draw_circle(105, 83, 16, GREEN)
  • 2 Methods
    With everything we do with the microbit conserving program and storage space should be at the back of our mind, initialization of the module and its associated methods is a necessity any other modules are more likely to be program dependent.
    The following is a list of methods I have been using in the TFT module, the list is not set in stone they are just the functions I have found most useful for me.
    init_lcd(spi):
    Initializes the LCD takes spi as argument
    clear():
    Clears the whole display and takes a 16 bit color value as an argument, if no argument is passed the color defaults to white.
    set_backlight():
    Sets the lcd backlight level and takes an int value from 0 – 1024, if no value is passed the value defaults to 1000.
    set_window(Xstart, Ystart, Xend, Yend):
    Defines a window (rectangle) as a drawing area.
    set_color(color, width, height)
    Fills a rectangle defined by "set_window()" with color, width and height are the dimensions of the window.
    draw_pixel(x, y, color):
    Draws a pixel at coordinates x y with the defined color.
    draw_point(Xpoint, Ypoint, color, Dot_Pixel):
    Draws a group of 1 to 4 pixels at x y with the defined color and the group number defined by Dot_Pixel
    draw_hline(x_0, y_0, length, color):
    Draws a horizontal line starting at x_0 y_0, the length is defined by length and color is defined by color. The line should be drawn left to right.
    draw_vline(x_0, y_0, length, color):
    Draws a verticall line starting at x_0 y_0, the length is defined by length and color is defined by color. The line should be drawn top to bottom.
    draw_char(x_0, y_0, char_id=0):
    Draws a font character at point x_0 y_0, the char_id references the characters position in ram.
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2022-06-01 18:06
    3 Images and Utility
    With the information we have so far we can initialize our LCD and draw some graphics maybe even create a few stick fonts. Images take things to another level and over the next two posts I would like to show how we can display our own images. First we need somewhere to store the images so using the Waveshare microbit device I will use the onboard SRAM.
    This will involve extracting the image data from an image file and saving this data to a new file. Then we can use our micropython editor to read and write this new data file to the SRAM memory.
    There a a couple of things to consider before we create this new file. First lets keep the file size below 15 Kbytes so that we dont run into out of memory issues with the microbit. The number of bytes our file will be is proportional to the number of pixels our image has. Here are two examples, the first image is 160 pixels wide and 45 pixels high, 160 x 45 = 7200, there are two color bytes for each pixel so the final file size for image 1 is 14400 bytes which is within the 15 K range, the second image is a full screen 160 x 128 which equals 20,480 pixels so that is 40960 bytes, way over limit. There are ways to get around this but for now lets keep within the 15 K range.
    The microbit micropython editor won't be able create the new image data file so you will need to run the following code on a computer that has the full version of Python.
    Usage is straight forward, I try to stick with source files that have the .png extension and I usually name the destination file with the .bin extension.
    The following code is very basic so keep source and destination files in the same folder as the utility, there is no need to type in the full path. The libraries used in the app are very common modules and most come packaged with Python.
    Utility
    from tkinter import *
    from tkinter import ttk
    from tkinter import messagebox
    from PIL import Image
    import numpy as np
    root=Tk()
    screen_width= root.winfo_screenwidth()
    screen_height= root.winfo_screenheight()
    root_width=270
    root_height=150
    x_location=(screen_width/2) - (root_width/2)
    y_location=(screen_height/2) - (root_height/2)
    root.geometry(f"{root_width}x{root_height}+{int(x_location)}+{int(y_location)}")
    root.title("Data from Image")
    root.resizable(False,False)
    var_list=[]
    source_var = StringVar()
    destination_var = StringVar()
    def get_params():
        source_var=source_entry.get()
        destination_var=destination_entry.get()
        var_list.append(source_var)
        var_list.append(destination_var)
        create_img_data(var_list)
    def rgb_hex565(red, green, blue):
       return "0x%0.4X" % ((int(red / 255 * 31) << 11) | (int(green / 255 * 63) << 5) | (int(blue / 255 * 31)))
    def create_img_data(var_list):
        var_list=var_list
        src_file=var_list[0]
        destination=var_list[1]
        if src_file=="" or destination =="":
            img_msg()
            return
        try:
            bin_img = Image.open(src_file)
        except:
            bad_file_msg()
            return
        img_map = np.array(bin_img)
        f = open(destination, 'wb')
        for y in range(bin_img.height):
            for x in range(bin_img.width):
                pix_color=img_map[y][x]
                value = pix_color[0]
                value2=pix_color[1]
                value3=pix_color[2]
                newcolor=rgb_hex565(value,value2,value3)
                bin1=int(newcolor,base=16)>>8 & 0xFF
                bin2=int(newcolor,base=16) & 0xFF
                f.write(bin1.to_bytes(1,"big"))
                f.write(bin2.to_bytes(1,"big"))
        f.close()
        messagebox.showinfo("Info", "File Operation Completed")
        close_app()
    def img_msg():
        messagebox.showerror("Error", "Source and Destination must contain a valid filename")
    def bad_file_msg():
        messagebox.showerror("Error", "Source not found")
    def close_app():
        root.destroy()
    def on_closing():
        if messagebox.askokcancel("Quit", "Are you sure you want to exit?"):
           close_app()
    root.protocol("WM_DELETE_WINDOW", on_closing)
    btn_CreateFile=Button(root,text="Create File",width=10,command=lambda:get_params())
    btn_CreateFile.grid(row=4,column=1,pady=15,sticky='w')
    btn_Exit=Button(root,text="Exit",width=10,command=lambda:on_closing())
    btn_Exit.grid(row=5,column=1,sticky='w')
    source_entry=Entry(root)
    source_entry.grid(row=0,column=1)
    destination_entry=Entry(root)
    destination_entry.grid(row=1,column=1)
    lbl_source=Label(root,text="Source File",pady=10,padx=20)
    lbl_source.grid(row=0,column=0)
    lbl_destination=Label(root,text="Destination")
    lbl_destination.grid(row=1,column=0)
    root.mainloop()
  • Loader
    Hopefully you now have a binary file containing the data for your image. I am posting here the micropython code we need to write the image data file to SRAM, I will refer to this code as the "Loader", also I am posting a small micropython code to test the success of loading the image to SRAM.
    As long as we maintain power to the microbit and don't over write the image data we can switch between program sketches and access our image at any time.
    I will describe the actions in a step by step fashion and hopefully it will be easy to understand.
    step #1 Remove all files from the microbit file system
    step #2 Copy the image file (mine is called logo.bin and is 14400 bytes) onto the microbit file system.
    step #3 Close the file system and copy the "Loader" code into the micropython code editor.
    step #4 At the very top of "Loader" are three fields we must fill in, FILENAME , START_ADDRESS and END_ADDRESS. For now this info has already been filled in but its important to note that END_ADDRESS = START_ADDRESS + the file length which in my case is 50000 + 14400 = 64400
    step #5 Flash "Loader" to the microbit
    step #6 Open REPL then press the microbit reset button, the program will start to run. REPL lets you see when the program has finished.
    step #7 It takes a minute but eventually you willl see the text "*********** Write Finished ***********"
    step #8 Close REPL and open the microbit file system
    step #9 Remove the image file and replace it with the TFT class module
    step #10 Flash the test program to the microbit and hopefully your image will load
    Loader
    # Loader.py .... writes files to sram
    import machine
    FILENAME = "logo.bin"
    START_ADDRESS = 50000
    # The end address will be the sum of the start address + the number of bytes to write
    END_ADDRESS = 64400
    # SRAM opcodes
    SRAM_CMD_WRMR = const(0x01)  # write mode register
    SRAM_CMD_WRITE = const(0x02)
    SRAM_CMD_READ = const(0x03)
    # SRAM modes
    SRAM_BYTE_MODE = const(0x00)
    SRAM_SEQUENTIAL_MODE = const(0x40)
    SRAM_PAGE_MODE = const(0x80)
    def ram_write(addr, buff):
        pin2.write_digital(0)  # CS fram
        spi.write(bytearray([SRAM_CMD_WRITE]))
        spi.write(bytearray([buff]))
        pin2.write_digital(1)  # remove fram CS
    def ram_set_mode(mode):
        spi.write(bytearray([SRAM_CMD_WRMR]))
        spi.write(bytearray([mode]))
    ram_set_mode(SRAM_SEQUENTIAL_MODE)
    with open(FILENAME, mode='rb') as file:
        for idx in range(START_ADDRESS, END_ADDRESS):
            data = file.read(1)
            int_val = int.from_bytes(data, "big")
            ram_write(idx, int_val)
    print('\r')
    print("***********  Write Finished  ***********")
    print('\r')
    Test
    from TFT import LCD
    lcd=LCD(spi)
    WHITE = 0xFFFF
    BLACK = 0x0000
    BLUE = 0x001F
    RED = 0xF800
    MAGENTA = 0xF81F
    GREEN = 0x07E0
    CYAN = 0x07FF
    YELLOW = 0xFFE0
    lcd.clear(BLUE)
    lcd.set_window(0, 0, 160, 45) # create a window the same size and position as the image
    buffer = lcd.ram_read(50000, 14400) # read the image data from ram into buffer
    lcd.lcd_fast_write(buffer) # sequentially write image data to window
    buffer=None # free buffer space
