Propeller Tool's File and Filter Pane
Hello,
I noticed recently that upon startup of the Propeller Tool that one of spin's files "mouse.spin" appears in the list in bold letters. Does this have any significance? I recently used this as an object in one of my attempts to write code which I store in another directory so not to make any changes to the "tool library".
It has been selected as your Top Object which lets you compile it without having it the open tab. I don't like this feature, but it's there, so I set my top object to a file that will do nothing -- just in case I accidently download and run the Top Object File. You can reset your Top Object file from the File menu or with Ctrl+T.
