Shop Learn P1 Docs P2 Docs Events
Propeller Tool's File and Filter Pane — Parallax Forums
Hello,
I noticed recently that upon startup of the Propeller Tool that one of spin's files "mouse.spin" appears in the list in bold letters. Does this have any significance? I recently used this as an object in one of my attempts to write code which I store in another directory so not to make any changes to the "tool library".
  • It has been selected as your Top Object which lets you compile it without having it the open tab. I don't like this feature, but it's there, so I set my top object to a file that will do nothing -- just in case I accidently download and run the Top Object File. You can reset your Top Object file from the File menu or with Ctrl+T.
