SOLVED - Some I2C chips not detected by Taqoz Reloaded?
"It's quiet - maybe too quiet, pardner" I expect all you 1000's of Taqoz programmers are too busy coding to post anything recently.
I'm coding a driver for the MS5611 air pressure sensor - it's said to be good for altimeter applications. I already had 3 i2c chips connected to the P2 and they all show up as a list when Taqoz starts. When an MS5611 is added, Taqoz does not detect it. Anyone else had an i2c chip fail to be detected?
I have two of these chips on breakout boards. I can read the six calibration constants from each chip - each chip has a unique set and they read consistently, so the chips are connected up and working OK.
I wish TAQOZ had that level of active users. That would be really fantastic but...to the point.
I have not experienced that. A chip not recognized correctly - yes, but not detected - not yet.
I have a sensor board from ST - yet untouched - so I may give it a try today once i get home. Will post the results.
An update without an actual results.
It turned out I was unable to check the sensor board due to the fact my KISS board loaded with TAQOZ (@"Christof Eb." version patched for the 25Mhz crystal) apperently does not like minicom terminal on my linux box and returns garbage. The board boots fine but I suspect it's the linux character encoding that is causing the problem. Will check tomorrow with the TeraTerm on windows.
@maciek, I am using minicom on Linux with the KISS board with no issues at all. Silly question, did you set the baud speed in minicom conf (or start minicom with -b parameter) ?
Silly question indeed
. The KISS board and the TAQOZ are both functioning perfectly.Yes, the serial terminal settings are correct. Moreover, I have checked on windows with Tera Term - no issues. Everything works as it should. The characters display properly and all is well. I will investigate further during the weekend.
A good friend suggested this modified version of the 'lsi2c' word that:-
1. Successfully detects the MS5611 chip
2. Displays an estimated maximum i2c clock speed for each chip detected on the bus
3. Recognises a few more chips and displays their names
--- Modified lsi2c - 19th Feb 2022 pri DEV? 1 SWAP FOR CASE@ I2C.START I2C.WR 0= i2C.STOP 25 us $FE I2CRD AND NEXT ; pri .I2C ( adr8 -- ) SWITCH \ AT i2cdev C! 100 I2C.KHZ $FF I2CRD I2C.STOP --- Check for ack and exit if none CASE@ I2C.START I2C.WR 0= I2C.STOP 5 us I2C.STOP 0EXIT --- Print the address on a new line CRLF+ CASE@ .B 100 6000 200 DO I I2C.KHZ 3 DEV? 11 COG@ 0<> AND IF 100 + ELSE LEAVE THEN 50 us 100 +LOOP 100 I2C.KHZ TAB PRINT PRINT" kHz" TAB TAB \ CR TAB TAB TAB --- and try to identify it pri (.I2C) \ SWITCH $36 CASE 0 SFR@ DROP $B5 SFR@ $36 = IF PRINT" P2D2 UB USB+SUPPORT UUID:" .UUID THEN BREAK --- Could be RTC but check ID register in case this is not a P2D2 $A4 CASE 0 RTC@ DROP $28 RTC@ $33 = IF PRINT" RV-3028 RTC " RDRTC 100 us .FDT THEN BREAK $DE CASE PRINT" MCP79410 RTC " BREAK $1A CASE PRINT" QMC5883 Magnetic Field Sensor" BREAK CASE@ $A0 $AE WITHIN IF .EEPROM BREAK CASE@ $C0 $CE WITHIN IF PRINT" Si5351A Clock Generator" BREAK CASE@ $D0 $DC WITHIN IF PRINT" DS3231 compatible RTC" BREAK $EC CASE PRINT" BMP280 Pressure Sensor or MS5611 Pressure Sensor with pin CSB=1" BREAK $EE CASE PRINT" MS5611 Pressure Sensor with pin CSB=0" BREAK CASE@ $30 $3E WITHIN IF PRINT" MCP9808 Temperature Sensor" BREAK CASE@ $40 $4E WITHIN IF PRINT" I/O Expander" BREAK PRINT" UNKNOWN DEVICE" ; pub lsi2c CRLF PRINT" I2C DEVICES" CRLF PRINT" Address Max clock Identity" I2C? IF 128 FOR I 2* .I2C NEXT CRLF THEN ;
