SimpleIDE strange issue — Parallax Forums
msiriwardenamsiriwardena Posts: 301
edited 2021-11-20 13:04 in Robotics
I have files that were originally complied and stored in the original desk top desk top,
but when I try to load using SimpleIDE to a activity bot errors appear and will not load the EEPROM .
At the same time if I use the binary file the program loads.
If I copy the files to a thumb drive and load the SimpleIDE application, it loads to the activity bot.
I also have files compiled using a different desktop(old) and when transfered via local network or via thumb drive will not compile in the New desk top.
I reinstalled SimpleIDE and updated the workspace and the issue persists.
Please somebody help to sole this issue.
Attached is a screen shot the project opend via SimpleIDE - with the errors and left pans shows the same
project parallax binary all compiled and and it runs.
Can someone explain this abbarent behavior of SimpleIDE.
siri
ps: Iam using the abdrive360.h and not servo360.h as the error suggests.
  • Moderator,
    please move tis file to appropriate forum if it is posted in the wrong forum.
    Thank you,
    siri
  • msiriwardenamsiriwardena Posts: 301
    edited 2021-11-20 12:17
    Moderators,
    As there are no replies to the above issue can you move the discussion to Robotics.
    i have also sent a reqest to editor@parallax.com and the
    reqest has beenrejected.
    Thank you,
    siri
  • I have not seen this error myself but is sounds familiar.
    There is a problem with it finding cog_run and cog_end functions.
    Is it possible for you to share your program so that we can try it. What version of the libraries are you using.
  • @iseries
    Thanks for trying to help to resolve this issue.
    Attached is the zipped project.
    Thanks again;
    siri
  • Your right, it doesn't compile.
    I had to add a simple library to the project and then it compiles just fine.
    Add simple library: motor/libservo360 to the project and it should compile just fine.
