debug(udec_reg_array(#CogVar01,10)) Syntax question
in Propeller 2
Why do I get 4 more registers than what is asked for in the following Code. I should get 10 but 14 values are returnded the first 10 are what I expected. Thanks in advance.
Regards
Bob (WRD)
CON
_clkfreq = 200_000_000
VAR
long adrHubVar01[10]
long adrCogVar01[10]
PUB main()|x
regload(@CogCodePrm)
call(@strtCogCode1)
getregs(@adrCogVar01,#CogVar01,10)
repeat x from 0 to 9
adrHubVar01[x] := adrCogVar01[x]+1 'add 1 to make data different than sent
setregs(@adrHubVar01,#CogVar02,10)
waitms(2000)
call(@strtCogCode2)
debug(udec_long_array(@adrHubVar01,10))
debug(udec_long_array(@adrCogVar01,10))
debug(udec_long_array(@CogVar01,10))
debug(udec_long_array(@CogVar02,10))
repeat
DAT
ORGH
CogCodePrm word strtCogCode1,endCogCode-strtCogCode1-1
ORG 0
strtCogCode1 nop
ret
strtCogCode2 nop
debug(udec_reg_array(#CogVar02,10))
ret
CogVar01 long 10,11,12,13,14,151,16,17,18,19
CogVar02 long "A"[10]
endCogCode
Because it needs to be
debug(udec_reg_array(#CogVar02,#10))
, otherwise it will get the array length from address 10Pasm syntax verses Spin syntax.
Bob (WRD)
