debug(udec_reg_array(#CogVar01,10)) Syntax question
in Propeller 2
Why do I get 4 more registers than what is asked for in the following Code. I should get 10 but 14 values are returnded the first 10 are what I expected. Thanks in advance.
Regards
Bob (WRD)
CON _clkfreq = 200_000_000 VAR long adrHubVar01[10] long adrCogVar01[10] PUB main()|x regload(@CogCodePrm) call(@strtCogCode1) getregs(@adrCogVar01,#CogVar01,10) repeat x from 0 to 9 adrHubVar01[x] := adrCogVar01[x]+1 'add 1 to make data different than sent setregs(@adrHubVar01,#CogVar02,10) waitms(2000) call(@strtCogCode2) debug(udec_long_array(@adrHubVar01,10)) debug(udec_long_array(@adrCogVar01,10)) debug(udec_long_array(@CogVar01,10)) debug(udec_long_array(@CogVar02,10)) repeat DAT ORGH CogCodePrm word strtCogCode1,endCogCode-strtCogCode1-1 ORG 0 strtCogCode1 nop debug(udec_reg_array(#CogVar01,10)) ret strtCogCode2 nop debug(udec_reg_array(#CogVar02,10)) ret CogVar01 long 10,11,12,13,14,151,16,17,18,19 CogVar02 long "A"[10] endCogCode
Because it needs to be
debug(udec_reg_array(#CogVar02,#10))
, otherwise it will get the array length from address 10Pasm syntax verses Spin syntax.
Bob (WRD)
