P2Eval <--> TinyFPGA — Parallax Forums
RaymanRayman Posts: 16,154
edited 2021-11-06 16:41 in Propeller 2
Trying to learn FPGA again and using the P2 Eval board to help.
Tried using some expensive FPGA boards before, but it's just too complex and became overwhelming and just too much work to figure anything out.
This time, using a very simple board, TinyFPGA.
Mentioning it here because using the P2 Eval board to help.
The P2 Eval provides power and a 16-bit interface for I/O with TinyFPGA
Made some notes on TinyFPGA here: http://www.rayslogic.com/TinyFPGA/TinyFPGA.htm
Notes on this interface are going here: http://www.rayslogic.com/TinyFPGA/TinyFPGA_To_P2Eval.htm
  • RaymanRayman Posts: 16,154
    I'm pretty sure we can also program the MachXO2 chip using the P2, but haven't figured out how yet.
    BTW: The goal in mind is to create a 4-bit CPU. Starting with a 4-bit ALU. Was thinking about doing it with ancient IC chips, but this is more interesting (and less work).
    Seems we have 16 I/O pins that we can easily use.
    So, current plan is to use 8 as inputs and 8 as outputs.
    Will make a program in FlexC that takes input via serial port and then shows the output.
    Could use for automated testing of future designs.
  • pik33pik33 Posts: 2,417
    edited 2021-11-08 08:32
    A simple CPU can be simply done in Verilog. Maybe I can find (and then place here) the code I did for my students at the university several years ago. The resulting 8-bit CPU eats up - if I can remember - about 600 (Edit: 379) LEs of Altera Cyclone 4
    edited 2021-11-08 08:29
    and there it is.
    module simple8(addr,din,dout,rw,md,irq,reset,clk,debug);
    //(c) 2017.04.15 Piotr Kardasz
    // pik33@o2.pl
    // license: GPL 2.0
    input wire [7:0] din;   // data in
    output reg [7:0] dout;  // data out
    output reg [7:0] addr;     // address
    output reg rw;             // 0 - write; 1 - read
    output reg md;          // 0 - memory, 1- device
    input wire irq;         // irqerrupt, negedge
    input wire clk;         // clock
    input wire reset;           // reset
    output [7:0] debug;
    reg [7:0] acc;              // accumulator
    reg [7:0] sp;               // program counter
    reg [7:0] pc;               // stack poirqer
    reg [1:0] flags, iflags;           // flags: IZC
    reg [1:0] irqreq;
    reg[7:0] arg,opcode;
    reg[3:0] phase;
    reg[7:0] ramaddr,ramdatain,ramdataout;
    assign debug=pc;
    (* ramstyle = "M9K" *) reg [7:0] ram[256];    // memory for the CPU
    initial
    begin
    acc<=0;
    sp<=8'hfe;
    pc<=0;
    flags<=0;
    iflags<=0;
    phase<=0;
    opcode<=0;
    rw<=1;
    $readmemh("ram.hex",ram);
    end
    always@(negedge clk)
    begin
    if ((rw==0) && (md==0)) ram[ramaddr]<=ramdataout;
    else ramdatain<=ram[ramaddr];
    end
    always@(posedge clk)
    begin
    if (~irq && irqreq==0) irqreq<=1;
    if (~reset) // standard: reset active low
      begin
      acc<=0;
      sp<=8'hfe; // ff=irqerrupt vector
      pc<=0;
      flags<=0;
      iflags<=0;
      phase<=0;
      opcode<=0;
      rw<=1;
      end
    else
      begin
      case (phase)
      0: // get an opcode
        begin
         if (irqreq==1) // interrupt acknowledge
           begin
            phase<=10;
            irqreq<=2;
            end
         else
           begin
           rw<=1;
           ramaddr<=pc;
           md<=0;
           pc<=pc+1;
          phase<=1;
            end
        end
      1: begin
         opcode<=ramdatain;
         phase<=2;
          end
      2: // decode address mode
        begin
         if (opcode[7:6]==2'b10 ) // imm
           begin
            rw<=1;
            ramaddr<=pc;
            md<=0;
           pc=pc+1;
            phase<=3;
            end
         else if (opcode[7:6]==2'b11 ) // abs
           begin
          rw<=1;
            md<=0;
            ramaddr<=pc;
           pc=pc+1;
            phase<=4;
            end
         else
           phase<=6; // acc or imp
         end
      3: begin
         arg<=ramdatain;
         phase<=6;
          end
      4: begin
         ramaddr<=ramdatain;
          rw<=1;
          pc<=0;
         phase<=5;
          end
      5: begin
         arg<=ramdatain;
         phase<=6;
          end
      6: // execute the opcode
        begin
         case (opcode)
           8'h29:       // ret
            begin
              sp<=sp+1;
          ramaddr<=sp+1;
          rw<=1;
          md<=0;
              phase<=7;
              end
            8'h2a:       // iret
              begin
              sp<=sp+1;
              ramaddr<=sp+1;
              rw<=1;
              md<=0;
              flags<=iflags;
              phase<=7;
             irqreq<=0;
              end
            8'h41:       // shl a
              begin
              flags[0]<=acc[7];
              acc<=acc<<1;
              phase<=0;
              end
           8'h42:       // shr a
              begin
              flags[0]<=acc[0];
              acc<=acc>>1;
              phase<=0;
              end
            8'h61:       // bne a
              begin
              if (flags[1]==0) pc<=acc;
              phase<=0;
              end
           8'h62:       // bcs a
              begin
              if (flags[0]==1) pc<=acc;
              phase<=0;
              end
            8'h64:       // jmp a
              begin
              pc<=acc;
              phase<=0;
              end
            8'h68:       // call a
              begin
              ramaddr<=sp;
              ramdataout<=pc;
              rw<=0;
              md<=0;
              sp<=sp-1;
              pc<=acc;
              phase<=0;
              end
            8'h71:       // push a
              begin
              ramaddr<=sp;
              ramdataout<=acc;
              rw<=0;
              md<=0;
              sp<=sp-1;
              phase<=0;
              end
            8'h72:       // pop a
              begin
              sp<=sp+1;
          ramaddr<=sp+1;
              rw<=1;
              md<=1;
              phase<=8;
              end
            8'h81, 8'hc1:  // adc #, adc abs
              begin
              {flags[0],acc}<=acc+arg+flags[0];
              flags[1]<=~(&(acc+arg+flags[0]));
              phase<=0;
              end
            8'h82, 8'hc2:       // sbc #, sbc abs
              begin
              {flags[0],acc}<=acc-arg-flags[0];
              phase<=0;
              end
            8'h84, 8'hc4:       // and #, and abs
              begin
              acc<=acc&arg;
              flags[1]<=~(&(acc&arg));
              phase<=0;
              end
            8'h85, 8'hc5:       // or #, or abs
              begin
              acc<=acc|arg;
              flags[1]<=~(&(acc|arg));
              phase<=0;
              end
            8'h86, 8'hc6:       // xor #, xor abs
              begin
              acc<=acc^arg;
              flags[1]<=~(&(acc^arg));
              phase<=0;
              end
            8'h91, 8'hd1:       // lda #, lda abs
              begin
              acc<=arg;
              phase<=0;
              end
           8'hd2:              // sta abs - sta # is nonsense
              begin
              ramaddr<=arg;
              ramdataout<=acc;
              rw<=0;
              md<=0;
              phase<=0;
              end
            8'h94, 8'hd4:       // in #, in abs
              begin
              addr<=arg;
              rw<=1;
              md<=1;
              phase<=9;           // need to wait for i/o
          end
            8'h95, 8'hd5:       // out #, out abs
              begin
              addr<=arg;
              rw<=0;
              md<=1;
              dout<=acc;
              phase<=0;
              end
            8'ha1, 8'he1:       // bne #, bne abs
              begin
              if (flags[1]==0) pc<=arg;
              phase<=0;
              end
           8'ha2, 8'he2:       // bcs #, bcs abs
              begin
              if (flags[0]==1) pc<=arg;
              phase<=0;
              end
            8'ha4, 8'he4:       // jmp #, jmp abs
              begin
              pc<=arg;
              phase<=0;
              end
            8'ha8, 8'he8:      // call #, call abs
              begin
              ramaddr<=sp;
              ramdataout<=pc;
              rw<=0;
              md<=0;
              sp<=sp-1;
              pc<=arg;
              phase<=0;
              end
            default:
              phase<=0;
              endcase
            end
      7: // get the pc from RAM
        begin
         pc<=ramdatain;
         phase<=0;
         end
      8: // get the acc from RAM
        begin
         acc<=ramdatain;
         phase<=0;
         end
      9: // get the data from the device
         begin
        acc<=din;
         phase<=0;
         end
      10: // interrupt phase 1 - save flags and return address
         begin
        iflags<=flags;
         ramaddr<=sp;
         ramdataout<=pc;
         rw<=0;
         md<=0;
         sp<=sp-1;
         phase<=11;
         end
      11: // interrupt phase 2 - get vector from $FF
         begin
        ramaddr<=255;
         rw<=1;
         md<=0;
         phase<=12;
         end
      12: // interrupt phase 3 - get vector from $FF
         begin
         pc<=ramdatain;
         phase<=0;
         end
         endcase
      end
    end
    endmodule
  • Piotr, what is the maximum clock frequency ?
    edited 2021-11-09 07:18
    I don't remember now. I did this thing for the student's lecture. (I teached basics of FPGA) - but generally this kind of thing works up to 100..200 MHz in Cyclone IV (DE2-115)
    The goal was to show students how to make a CPU and peripherals in FPGA, so I also wrote some peripherals (switch input, LED output, 7-segment output) and address decoder, then I connected all of this using Quartus GUI to show the structure of such a system
    This CPU has 8-bit (!) memory address space using FPGA's internal memory and separate, 8-bit I/O address space.
    Got a 74181 ALU coded up in Verilog.
    Going to use P2 to do some automated testing to see if it's right.
    Found some C code for 74181 in an old version of Mame: https://github.com/mamedev/historic-mame/blob/master/src/emu/machine/74181.c
    Can compare the output of that with FlexProp C to what the fpga is putting out.
    The 74181 is actually fairly complex for such an old chip.
    And, getting the Verilog to match took a fair amount of time.
    I probably made some mistakes somewhere, so this is going to be a big help.
  • I've got an old VHDL textbook wherein one chapter is entirely replicating an AM2901 (4-bit ALU) in an FPGA. S.
  • There is the MiSTer project that implements 80/90ies home computers and game consoles using FPGA. Including 68K processors. See eg https://github.com/MiSTer-devel/Minimig-AGA_MiSTer
    edited 2021-11-10 19:24
    The P2 was a big help with testing the 74181 in verilog.
    Found several bugs.
    My carry out is wrong (always 0) when doing logic functions.
    I think this is how it should be, but the actual chip doesn't care about M when outputting the carry...
    Also, I think there was a bug in the carry out in that Mame code, that I fixed.
    Don't know enough about their code to say for sure, but had to change something to match what I think is correct.
    This page is very helpful with that: http://www.righto.com/2017/03/inside-vintage-74181-alu-chip-how-it.html
