How to enable more columns of data on PLX-DAQ — Parallax Forums
Hello
How to enable more columns of data on PLX-DAQ ? , I have only 9 now , what to do ?
  • The new PLX-DAQ should support 26 columns.
    https://www.parallax.com/package/plx-daq/
  • nbaever3nbaever3 Posts: 1
    edited 2021-11-11 14:29
    Hi , I used this code to display flow rate, liquid passed/sec and total liquid, I tried different Serial.print options to print them in three columns but it is either combining two data in the same column or ignoring one. It is showing five columns for time, timer, flow rate, liquid, total liquid but the displayed data is not the correct data. I tried using arduino code and it is giving the correct data on the serial monitor but the problem with the added lines relating to PLX-DAQ spice money login myfiosgateway
