Surprise ! Draw your own conclusions. — Parallax Forums
  • That's from here.
  • ErNaErNa Posts: 1,851
    What was the update? Change for clock setting?
  • MaciekMaciek Posts: 696
    edited 2021-08-30 08:04
    I haven't run the diff so do no really know, but I know for sure that TAQOZ Reloaded (not the ROM version) already had that option and that is "clkfreq!" - works with the 20 MHz step IIRC but i only used it at 120 MHz or more up to 340 MHZ.
    The terminal session and baud rate is preserved and you are still maintaining the interactive session with the TAQOZ after the change.
