Ublox GPS to Propeller — Parallax Forums
Hi All,
I am working on using a Ublox GPS module with the Propeller. With @JRoark 's help I have the module configured and outputting a simple NEMA sentence. All my project requires is the time and date. I can trap for the beginning of the sentence ($GNMC) but the time is coming across as nonsense. I suspect that the time is output as a long or something. I attach the code and will try to cut and paste inline although I don't see the "C" button that used to let you post inline code with the formatting intact.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
LF = 10
CR = 13
input = 0
output = 1
gpsBaud = 9600
gpsMode = 0
gpsOut = 3
gpsIn = 16
VAR
byte month, day, hours, minutes, second
byte gpsData[77]
OBJ
gps : "fullduplexserialplus"
pst : "Parallax Serial Terminal"
' nixies : "SPI Engine"
'rf : "Simple_Serial"
PUB init | i
dira[15] := output
gps.start(gpsIn,gpsOut,gpsMode,gpsBaud)
pst.Start(115_200)
pst.clear
pst.home
wait_ms(2000)
pst.str(string("GPS Timebase..."))
pst.newline
pst.str(string("Version 0.2"))
wait_ms(1000)
repeat
get_gps
pst.newline
repeat i from 0 to 10
pst.dec(gpsData[i])
pst.str(string(","))
' pst.dec(hours)
'wait_ms(1000)
pub get_gps | i, temp1
' gpsSynch := 0
longfill(@gpsData,0,77)
wait_for_char("$")
wait_for_char("G")
wait_for_char("N")
wait_for_char("M")
wait_for_char("C")
gpsData[i] := gps.rxtime(1000)
if gpsData[i] == -1
gps_error
return
hours := gpsData[2]
minutes := gpsData[3]
' pst.str(string("got GPS..."))
return
pub wait_for_char(b): temp | t
repeat until temp == b
temp := gps.rxtime(1300)
if temp == -1
gps_error
return
pub gps_error
pst.clear
pst.home
pst.str(string("GPS not responding..."))
wait_ms(2000)
'init
return
PUB wait_ms(ms) '
waitcnt(cnt+(clkfreq / 1_000) * ms)
RETURN
PUB wait_us(us)
waitcnt(cnt+(clkfreq / 1_000_000) * us)
RETURN
  • JRoarkJRoark Posts: 1,215
    edited 2021-08-01 23:24
    Easy fix: To delineate your code blocks, preface them with three consecutive backticks and a CR. At the end of the code block do the same.
    What is a $GNMC message? I’ve never seen that one and Google is silent about that too. There is nothing in the uBlox docs either. This appears to be a non-standard proprietary message. You might use the $GPZDA message instead. This is the format:
    $GPZDA - Date & Time
    Gives UTC, day, month, year, and local time zone.
    $GPZDA,hhmmss.ss,xx,xx,xxxx,xx,xx
    hhmmss.ss = UTC
    xx = Day, 01 to 31
    xx = Month, 01 to 12
    xxxx = Year
    xx = Local zone description, 00 to +/- 13 hours
    xx = Local zone minutes description (same sign as hours)
    All the best…
    EDIT: ah! You are thinking of the $GPRMC message maybe? If so, look closely at your code. You are missing the “R”. :)
    EDIT2: All NMEA-183 messages are strings and not binary data. They appear just as if you had typed them on a keyboard. So you need to convert from string to int (or whatever). I’d be a lot more help if I knew Spin, but alas I’m a creature of FlexBASIC. If you want to use BASIC, I’ve got code I can share.
  • Are you sure 9600 baud is correct? NMEA sentences are typically at 4800 baud. But some modules allow you to change that.
    The people from Switzerland are known to speak very slowly but their GPS is speaking faster than usual. Their standard baudrate is really 9600.
  • I am at work for my 50 hour shift and so am away from the project.
    @JRoark , I will check that it is indeed a $GNMC message. I think so. It is passing the trap. I am so out of the loop that I am not familiar with flexbasic but I would love whatever sample code you have as I did do a lot of basic programming at one time. I could either use flexbasic or translate it to Spin.
    It is odd, the output does change with the seconds ticking away but just rolls through a short pattern. When I am home I will screen shot some of it.
    @"Phil Pilgrim (PhiPi)" Yes, the module is set to 9600 baud, which is its default. If I hook a propplug up with the Parallax Serial terminal set to 9600 baud I see the NEMA sentence as I should. It is something to do with my picking those bytesw up and displaying them that is going wrong.
    Thanks for the help. I know it is something simple.
  • When I've done GPS code, I used the "Binary" mode on a Skytraq GPS. It was much easier to parse in SPIN. It may be worth looking to see if Ublox has a documented binary comm mode.
  • Week has been blowing by and I have to back to work early this week for a 72 hour shift.
    @Circuitsoft , I will look and see if the ublox has a binary mode. That is what I used on the old GPS for this project. I'm also going to go take a look for flexbasic.
  • JonathanJonathan Posts: 1,023
    edited 2021-08-12 15:29
    Aha. Looking at the data stream this morning I realized that I am in fact getting the bytes. They are in ASCII, with each number seperated, as in if the hours are 14 I get 49,52. I thought this is how my old one did it and that my code should deal with it. Sadly, I wrote it a long time ago and haven't used fullduplexserialplus for ages so I am having trouble doing the conversion. What I want to do is take the ASCII char pairs and put them together in a dec. I have done that in the past but I am still befuddled now.
    EDIT: Man, have I forgotten a lot! Goes to show use it or lose it. Of course I can just subtract 48 to convert to dec! Now I just have to remember how to combine the two numbers, like 1 and 4 into 14.
    EDIT 2: Glad I got back here before anyone wasted their time. Multiply the first char by 10 then add the second char.
