P2 PASM PropellerTool OBJ include?
pic18f2550
                                  in Propeller 2
        How do I tell the "coginit #16, ##@NEWCOG" in a pure PASM project that "NEWCOG" is in another file?
The integration in Propellertool with "OBJ" does not seem to work.
I don't think that's possible: a pure PASM project in propellertool must all be in the same file.
(In flexspin you can use #include, but that isn't implemented in PNut/propellertool.)
That is annoying.
So I can only integrate pre-compiled binary files into the project via the file function.
Let's see when the first pure P2 assembler appears.
End of year 2015 I would say:
https://forums.parallax.com/discussion/162962/qasm-a-p2-assembler-written-in-c#latest
This has evolved into P2ASM which is used in FlexProp now.
No, p2asm, PNut, and flexspin are all independent assemblers (and so they're useful for checking each other
). You may be thinking of loadp2, another of Dave Hein's tools which I did adopt in FlexProp.
Oh, sorry then, Eric. So Flexprop uses its own Assembler.
I think it's the GCC hack for P2 that uses P2ASM. Anyway I'm pretty sure you can use P2ASM as a standalone assembler for P2, or just use FlexProp with its preprocessor capabilities for pure PASM2 code.
