Learning P2 Assembly
                                  in Propeller 2
        I spent today learning P2 Assembly.
Hugely interesting.
First I read the main documentation.
Then I read this excellent tutorial for the P1.
http://www.rayslogic.com/propeller/Programming/DeSilvaAssemblyTutorial.pdf
I understand many of the concepts are similar.
What else do you recommend reading?
I will say it is very different from traditional programming.
Most interesting and enlightening.
Chris
Yeah, I think to understand the P2 one has to start with the P1.
DeSilva is very good, I recommend to read all the source of @JonnyMac produced objects, everything in the Parallax GitHub starting with JM_ is golden to understand the concepts of P1 or P2.
A lot of things are similar but a lot of things evolved out of the unusual thinking you need to change your programming style from single execution line to really parallel running processes.
It is in no way similar to threading used in modern languages and processors. It is different, confusing and way more simple once you - hmm - see the light?
The major point is that the execution of one COG (=Core) can not affect the execution or timing of another one. You usually have one main program running in one COG and communicating with other processes running in other GOG's via share HUB memory locations, usually called mailboxes here.
Say you have a video driver, it has its main loop, providing hsync, vsync and the data needed to write to VGA/TV/whatever. That COG/core/process has some idle time while constantly refreshing the screen and reads its mailbox then to - say put a string somewhere on the screen. It does it whenever it can squeeze it in, still providing perfect timing for the video signal.
The COG/core/process USING it does not need to be aware of any timing constrains of the Video signal on the pins, it just talks to the mailbox and says - hey put that string there.
So you decouple things and the things itself get simpler.
The P2 is a step beyond that so you do not just(?) have 8 parallel working COGs/cores/processes but on top of that 64 independent little co processors in each pin. those smart-pins.
So instead of looping one process to pulse out a PWM signal to a servo and try to keep your loop under 50ms or so, you just tell the pin what you need and the pin will do that while your program can do other things.
so you are completely right in saying "I will say it is very different from traditional programming"
Enjoy!
You're always too kind to me, Mike. I'm not as gifted at PASM as so many of our forum friends are, but the thing is that the Propeller family was designed by a real-world embedded programmer, not a committee at a giant corporation. That does make it different, and programmer-friendly -- especially the P2. As I have been porting P1 code to the P2 I find that most PASM2 instructions are easier to use. To be candid, though, I wish the P2 had the free-running timers available in the P1 (that are not connected to a pin). Still, the smart pins really shake things up.
@lozinski : Since Mike brought up P2 smart pins here's a bit of code that I wrote over the weekend to let the P2 control LX-16a "bus servos." These do servo-like things but work in a multi-drop configuration. The half-duplex serial connection is at 3.3V so it's directly compatible with the Propeller. I put a 1K resistor between the P2 and the LX-16A, just to prevent an accident while developing code. I also added a pull-up to the line to keep it idle while the Propeller is booting up or not transmitting. Since the transactions are so short I made this code cogless -- it runs inline. So far I've tested it with a couple features of the LX-16a and it works fine. Even the manufacturer is interested (I reached out to fill some gaps in their protocol specification).
For me, the ability to toss PASM code into my P2 projects without launching a separate cog is a lot of fun. It certainly makes experimenting with PASM2 much easier than experimenting with PASM1. Have fun, and welcome to the forums.
con TX_UART = P_ASYNC_TX | P_OE ' smart pin tx uart RX_UART = P_ASYNC_RX ' smart pin rx uart pri lx_coms(pin, mode, p_tx, p_rx) : rxlen | baudtix, x, txlen, tocount '' Handle serial coms with LX bus servo '' -- pin is serial io to lx servo '' -- mode is M_TX (transmit only) or M_TXRX (transmit/recieve) '' -- p_tx is pointer to transmit buffer '' -- p_rx is pointer to recieve buffer (for mode TXRX) bytefill(p_tx, $55, 2) ' add header to tx packet calc_checksum(p_tx, true) ' add checksum to tx packet baudtix := clkfreq / 115_200 ' ticks per bit org cmp mode, #M_TX wcz if_e jmp #tx_config cmp mode, #M_TXRX wcz if_e jmp #tx_config jmp #done ' exit if not a transmit request tx_config fltl pin ' release pin wrpin #TX_UART, pin ' set to tx uart mov x, baudtix ' setup baud shl x, #16 or x, #(8-1) ' and bits wxpin x, pin wypin #0, pin drvl pin ' activate tx uart rep #1, #10 ' idle for 1 byte period waitx baudtix transmit mov x, p_tx ' get data length add x, #LX_DLEN rdbyte txlen, x tjz txlen, #done ' abort if no length in packet add txlen, #3 ' set tx packet length (2x header + cs) drvh #LED1 ' tx led on (debugging) tx_loop rdbyte x, p_tx ' get packet byte add p_tx, #1 ' advance pointer wypin x, pin ' load into sp uart waitx baudtix ' let tx get started rdpin x, pin wc ' verify busy flag if_c jmp #$-1 ' let byte finish djnz txlen, #tx_loop ' if not end of packet, do next byte drvl #LED1 ' tx led off cmp mode, #M_TXRX wcz ' expecting response from this packet? if_ne jmp #done turn_around fltl pin ' clear tx configuration wrpin #RX_UART, pin ' setup for rx drvl pin mov rxlen, #0 mov tocount, #60 ' 60 bit periods = ~500us .ta_loop testp pin wc ' test for response if_c jmp #get_byte waitx baudtix djnz tocount, #.ta_loop mov rxlen, ##TIMEOUT ' no packet, return timeout error jmp #done rx_loop mov tocount, #15 ' set time-out counter check_rx testp pin wc ' anything waiting? if_c jmp #get_byte ' yes, get byte from rx uart waitx baudtix ' check for time-out djnz tocount, #check_rx jmp #done get_byte drvh #LED2 ' rx led on (debugging) rdpin x, pin ' read new byte shr x, #24 ' align lsb wrbyte x, p_rx ' write to buffer add p_rx, #1 ' bump pointer add rxlen, #1 ' bump rx bytes received jmp #rx_loop ' wait for next byte done drvl #LED2 ' rx led off ret endI agree that bottom up design is much better.
I have looked at so many chips over so many years but this one is way way better. The first one I am jumping on.
I am tempted to write a comparison and compliments, but I do not want to name the potential competitors.
Chip is only the second person I know of, in all of history who both designed a chip and a language. Usually the chip designers target C, and the language designers also target C.
Your point about the advantages of this chip was most helpful. And also explained to me why this architecture evolved in the real-time area. Clearly great for IoT, but not just for IoT.
There is two C compilers for the Prop2:
EDIT: Eric just recently showed me recommended use of assembly in Flexspin C - https://forums.parallax.com/discussion/comment/1525050/#Comment_1525050
Correct me if I am wrong, but aren't the "mailboxes" some shared addresses between 0-1, 2-3, 4-5, and 6-7.
I think you are confusing it with LUT where a COG can access the LUT of its twin.
The mailboxes are just hub ram locations defined for the purpose to exchange information between two or more COGs. These can be everywhere in the HUB and of any size. As I am aware there isn't any standard to present day. A few forumistas have had a debate on this several times but no standard was agreed.
