P2-EVAL remote reset? — Parallax Forums
Can the P2 be reset by means of the USB port, please? I haven't found the circuit diagram for the P2-EVAL.
  • There is a DIP switch that switches USB reset on and off. One of the USB/RS232 handshake lines is used, so RTS or DTR.
  • Thank you, I can toggle one of those.
    DTR is used to reset the P2-EVAL. This is how download works by resetting the P2. I don’t recall there being an enable/disable switch on that pcb for this.
  • RaymanRayman Posts: 16,205
    My Rev.C eval board has a switch labelled "USB RES". I'd guess that enables it...
    edited 2021-05-17 19:22
    Yep, that's it, just checked. But, the Edge module replaces that for an LED enable switch. This makes sense since the Edge doesn't have USB serial.
