P2-EVAL remote reset?
bob_g4bby
in Propeller 2
Can the P2 be reset by means of the USB port, please? I haven't found the circuit diagram for the P2-EVAL.
There is a DIP switch that switches USB reset on and off. One of the USB/RS232 handshake lines is used, so RTS or DTR.
Thank you, I can toggle one of those.
DTR is used to reset the P2-EVAL. This is how download works by resetting the P2. I don’t recall there being an enable/disable switch on that pcb for this.
My Rev.C eval board has a switch labelled "USB RES". I'd guess that enables it...
Yep, that's it, just checked. But, the Edge module replaces that for an LED enable switch. This makes sense since the Edge doesn't have USB serial.
