STREAMER - I beg you example ! - Page 3 — Parallax Forums
13»
  • evanhevanh Posts: 16,856
    edited 2021-04-02 01:37
    Oh, bugger, the "a" bit doesn't work that way either! I think I got it right now:
    eg:  Shifting out %1000_1100_1110_1111_0111_0011_0001_0000 in 4-bit elements:
      Step | D3  D2  D1  D0       ( "a" mode bit set, some messed up big-endian in a little endian system )
    -------+-----------------     ( Streamer mode:  %0110 dddd eppp p101 )
        1  |  0   0   0   1
        2  |  0   0   0   0
        3  |  0   1   1   1
        4  |  0   0   1   1
        5  |  1   1   1   0
        6  |  1   1   1   1
        7  |  1   0   0   0
        8  |  1   1   0   0
      Step | D3  D2  D1  D0       ( "a" mode bit clear, little-endian )
    -------+-----------------     ( Streamer mode:  %0110 dddd eppp p100 )
        1  |  0   0   0   0
        2  |  0   0   0   1
        3  |  0   0   1   1
        4  |  0   1   1   1
        5  |  1   1   1   1
        6  |  1   1   1   0
        7  |  1   1   0   0
        8  |  1   0   0   0
  • I am testing the three 4-bit modes and I am not able to see any difference between them:
    0110 dddd eppp p00a <long> imm 8 x 4 -> 4-pin + 4-DAC1 4 out %dddddddd_cccccccc_bbbbbbbb_aaaaaaaa
    0110 dddd eppp p01a <long> imm 8 x 4 -> 4-pin + 2-DAC2 4 out %00000000_00000000_dcdcdcdc_babababa
    0110 dddd eppp p10a <long> imm 8 x 4 -> 4-pin + 1-DAC4 4 out %00000000_00000000_00000000_dcbadcba
    This is the test code. What am I doing wrong ??
    CON
      _clkfreq = 4_000_000
      DOWNLOAD_BAUD = 115_200
      rx_pin   = 63
      tx_pin   = 62
      baud     = 115_200
      OUTPIN   = 36     ' Using Pins 36 to 39 (D0..D3)
    OBJ
      ser: "spin/SmartSerial"
    PUB main() | md, i
      ser.start(rx_pin, tx_pin, 0, baud)
      waitms(4000)
      org
            setxfrq ##536                       'streamer freq: 1 Hz
      end
      org
            drvl    #OUTPIN                      'pin 36 D0 = output, low
            drvl    #OUTPIN +1                   'pin 37 D1 = output, low
            drvl    #OUTPIN +2                   'pin 38 D2 = output, low
            drvl    #OUTPIN +3                   'pin 39 D3 = output, low
      end
      waitms(40)
      md := %0110_0000_1100_1000<<16 + $FFFF  'streamer mode: imm 8x4, 4-pin, %dddddddd_cccccccc_bbbbbbbb_aaaaaaaa
      ser.printf("md : %x\n", md)
      org
            xinit   md, ##%1100_1100_1100_1100_1100_1100_1100_1100  '
            'xinit   md, ##%1111_0000_1111_0000_1111_0000_1111_0000  '
      end
      waitms(10000)
      md := %0110_0000_1100_1010<<16 + $FFFF  'streamer mode: imm 8x4, 4-pin, %00000000_00000000_dcdcdcdc_babababa
      org
      end
      waitms(10000)
      md := %0110_0000_1100_1100<<16 + $FFFF  'streamer mode: imm 8x4, 4-pin, %00000000_00000000_00000000_dcbadcba
      org
      end
      waitms(10000)
      repeat
        org
            nop
        end
    The only difference in those modes is the data patterns to the four DAC channels. Which needs the DACs enabled. For logic output, they're all the same mode.
  • Oh, Thank you!
