hand solderable usb component
From time to time I create a custom board for my needs.
Up to now I had an USB mini connector, to be used for voltage supply, and in some cases programming.
like this one: https://www.mouser.it/ProductDetail/798-UX60A-MB-5ST/
USB mini are phasing out, micro are widely used and USB-C is looking like the new standard.
Could you suggest some connectors to be used on a custom board, that is reasonably easy to solder?
Thanks in advance,
Massimo
Thanks in advance,
Massimo
There are vertical micro USB that are all thru-pins, like this
https://lcsc.com/product-detail/USB-Connectors_Korean-Hroparts-Elec-U-D-M5DD-W-1_C145795.html
or there are full-4-stake ones like this
https://lcsc.com/product-detail/USB-Connectors_XKB-Connectivity-U254-051N-4BH806_C319170.html
the smd pins come out the back, so longer pads there could allow hand reflow soldering.
http://www.adam-tech.com/upload/USB-C31-A-D-VT-CS1.pdf
The 'bonus' is you get a USB A socket for free
Personally, I hate the micro USB. Breathe on it wrong and it's wiped out.
https://au.mouser.com/ProductDetail/TE-Connectivity/2129691-1/?qs=QzBtWTOodeUSdqmNsmjMeA%3D%3D
For sure there is an agreement about usb mini, and I don't really like them too.
The micro connector is very easy to solder, reasonably sturdy and with a good retention. I'll have to check some of the usb-C suggestions.
Thanks again,
Massimo
