INA syntax in spin2
ke4pjw
in Propeller 2
I have looked through the language reference and don't understand why why this does not compile.
dbus := INA[0..7]
I want to read p0-p7 into dbus but get the error that it is expecting a ] where .. is.
What am I doing wrong? Is there a more complete spin2 reference than this https://docs.google.com/document/d/16qVkmA6Co5fUNKJHF6pBfGfDupuRwDtf-wyieh_fbqw/edit#heading=h.nagbjtem5ytb
As always, thanks in advance.
--Terry
dbus := INA[0..7]
--Terry
dbus := INA[0..7] == Pinread(0 addpins 7, dbus rev 7)
Or
dbus := INA[7..0] == Pinread(0 addpins 7, dbus)
Bill M.
Also, as an OT comment, I absolutely *LOVE* the ansi_vgatext_demo! I have not thought about ANSI escape sequences in years. It's perfect for using as a debug output! Thank you for all of your work!
If I *ONLY* read the apins, I see random addresses displayed as expected from abus.
If I read apins and dpins, then the last octet of abus always equals dbus, and it is always 03.
If I read apins, dpins, and cpins, the first octet of abus is always random, the last octet of abus is 03, as is dbus and cbus.
What am I doing wrong. This is driving me crazy!
Andy
Similar results, except it is not 03. It is random but all three are the same.
Various configurations yield different results based on the order I perform the read. Something is not right, If I read only one of the three, it performs as expected.
Either my hardware is bad, but it works as expected when only reading one set of pins, or this is a compiler issue. I will try this on my P2 Edge board and see if I get similar results without ever attaching the pins to my hardware.
I don't know where to start. My code looks right. Maybe this is a problem in the ANSI display driver and the way it displays hex. Maybe it is a compiler problem. Maybe I don't know enough about what is really going on. I don't see a problem in either my code or the ANSI num or hex methods.
I can say that the last digit of all three outputs follows what the cbus inputs are. I just don't see how that can happening unless this is a hardware glitch or a memory bookeeping problem.
*OR* addpins doesn't work the way I would expect at all.
I don't think I am smart enough to figure it out. I have spent 10 hours on this and the solution eludes me.
try making abus and dbus longs also...
A Long: 01
D Long: 01
C Long: 01
Variables should be:
A Long: A0
D Long: FFFF
C Long: 01
If you comment out c := $01, then all three are then FFFF.
DAT
a long 0
d long 0
c long 0
you need to provide a value in dat sections else they refer to the same memory location, maybe word and byte will then work too...
There is a use-case for the syntax you're using, as I demonstrated in my Christmas light code. In this case I declared Colors without a value to use like an array to make the code easier to understand. Without a value, Colors has the same address as DimRed.
I know there is plenty of spin 1 code out there where the value is not declared in the DAT section.
Getting hung up on a syntax bugaboo like this is maddening. Thank you everyone for pointing this out!
Again, thanks everyone.
