P2 running FPGA code on P2 Edge — Parallax Forums
Quick question about VGA example from FPGA boards…see code below:
'* VGA 640 x 480 x 8bpp-lut *
CON
intensity = 80 '0..128
fclk = 80_000_000.0
fpix = 25_000_000.0
fset = (fpix / fclk * 2.0) * float($4000_0000)
vsync = 0 'vsync pin (all FPGA boards now)
DAT org
' Setup
hubset #$FF 'set clock to 80MHz
rdfast #0,##$1000-$400 'load .bmp palette into lut
rep @.end,#$100
rflong y
shl y,#8
wrlut y,x
add x,#1
.end
rdfast ##640*480/64,##$1000 'set rdfast to wrap on bitmap
setxfrq ##round(fset) 'set transfer frequency to 25MHz
'the next 4 lines may be commented out to bypass level scaling
setcy ##intensity << 24 'r set colorspace for rgb
setci ##intensity << 16 'g
setcq ##intensity << 08 'b
setcmod #%01_0_000_0 'enable colorspace conversion
wrpin dacmode,#3<<6 + 0 'enable dac modes in pins 0..3
' Field loop
field mov x,#33 'top blanks
call #blank
mov x,#480 'set visible lines
line call #hsync 'do horizontal sync
xcont m_rf,#0 'visible line
djnz x,#line 'another line?
mov x,#10 'bottom blanks
call #blank
drvnot #vsync 'sync on
mov x,#2 'sync blanks
call #blank
drvnot #vsync 'sync off
jmp #field 'loop
' Subroutines
blank call #hsync 'blank lines
xcont m_vi,#0
_ret_ djnz x,#blank
hsync xcont m_bs,#0 'horizontal sync
xcont m_sn,#1
_ret_ xcont m_bv,#0
' Initialized data
dacmode long %0000_0000_000_1010000000000_01_00000_0
m_bs long $7F010000+16 'before sync
m_sn long $7F010000+96 'sync
m_bv long $7F010000+48 'before visible
m_vi long $7F010000+640 'visible
m_rf long $7F080000+640 'visible rlong 8bpp lut
x res 1
y res 1
' Bitmap
orgh $1000 - $436 'justify pixels at $1000, pallete at $1000-$400
file "bitmap2.bmp" '640 x 480, 8pbb-lut
If this code is ran on the P2 Edge…what are the pins assignments?
I think it’s pins 0 through 4, but I’m not sure what pins are R,G,B,H, and V
  • RaymanRayman Posts: 15,800
    edited 2020-12-23 17:37
    I don't think the Edge module has a VGA port, does it?
    Maybe whatever you are plugging it into has one?
    Anyway, VGA RGB&Hsync have to be on consecutive pins starting from a multiple of 4. HSync comes first.
    VSync can be on any pin...
  • P2 Edge Mini breakout board and the Jon Mac board both have breakout pins for the A/V board from the Accessory Kit.
    There are VGA examples for P2 in the pnut download. Haven’t looked but likely with PropTool 2.4 and later.
  • The FPGA code will not run on the edge board without a few changeds,
    The streamer modes changed from Rev A(FPGA) to Rev B/C silicon.
    Also the HUBSET value nedds changing too.
  • Thank you for the help. I’ve now got the pin mapping figured out, but the change needed for the streamer is going to be a real challenge. I’ve never worked with smart pins before and the P2 has a lot of setup variations. Is there a P2 edge vga example that displays a bitmap graphic? All the examples I’ve found so far seem to be text type graphics
  • evanhevanh Posts: 16,870
    edited 2020-12-24 07:59
    Interesting, I'd not noticed those examples had vanished from newer Pnut downloads.
    FPGA/Pnut v33 is for the RevB silicon. Those ones should have correct streamer modes. Only thing to fix up is the HUBSET mode to get matching 80 MHz in finished silicon.
    PS: I've attached example from v33k.
    edited 2020-12-24 14:24
    There really should be a simple VGA example that works...
    Seems we lost these simple examples...
    Couldn't find any that work with new Prop Tool...
    So, remade them here:
    http://forums.parallax.com/discussion/172624/simple-vga-wvga-spin2-examples
