Will Parallax sell the 2 x 6 Harwin m20-7810645r connectors
in Propeller 2
Will Parallax sell the 2 x 6 Harwin m20-7810645r connectors for about
the price Mouser or Digikey would?
I was looking at the 6x2 smt connectors used on the P2 evaluation
boards to make a quick proto boards by soldering the Harwin 6x2
smt to a perf board.
The PCB layout specs in the data sheet makes it look like it is
possible. But since I don't have a Harwin m20-7810645r
connector in my hands to measure, I am just guessing.
According to the data sheet there are 2 plastic locating pins
that might be able to be cut or sanded off. Hopefully cutting
or sanding off the pins is easier than Sir Shakealot drilling a
centered hole in the perfboard?
Bill M.
Bill M.
You can cut down longer 1x?? while wasting a pin.
Will you place the first order if we add these to our site?
I have a box of small double sided perf boards, that would be perfect
for small test circuits and my ebay module collection.
I am hoping that it will be a cleaner solution to my solder globs
I have created in the past.
Bill M.
