When will the P2 Edge be available again? - Page 2 — Parallax Forums
2»
  • Version 2.4 is having problems at the moment. You can get the .exe for 2.3 and drop it into the folder of your existing installation (1.3.2) and it will run fine.
  • Correct, @doggiedoc - It's 2.4, not 4.2!
  • K2K2 Posts: 695
    The P2 Edge is remarkable! I had fond hopes of a P2 header board from Parallax, and Edge clearly exceeds expectation. The synergy with JonnyMac's design just adds to the amazement. In the voice of Julia Collin Davidson, "Good job!!"
  • cgraceycgracey Posts: 14,319
    I have one wish, each, for the P2 Edge and JonnyMac board:
    On the Edge, white LEDs instead of green. This is underway.
    On the JonnyMac, narrower and longer rubber feet so that they can be placed at the distal edges of the board, inhibiting it from levering up under Edge insertion.
