Com Port trouble
Carol Hazlett
in Propeller 1
With the P2 out now I decided to renew my long dead Spin skills. But I am stuck at the starting gate. I am using the Propeller Microcontroller book and a Propeller 1 Demo board with software ver. 2.4. Since I am using the demo board I am also using the Parallax Demo board driver for the Com port. What is happening is when I verify the board it gives back the proper info and com port but when I try to load it to ram it says "no propeller found on serial port".
I tried different drivers but no joy. Can anybody help me?
Since PropTool 2.4 is in beta for the P2, I wonder if it might be better to use a known version that works with P1.
My version is 1.3.2 although I'm not certain that was the latest for P1 only.
I have not had any issues with drivers tho I do know others had problems with the FTDI drivers and required re-installation. I am presuming the Demo Board uses the FT232RL or you are using a PropPlug with the FT232RL?
I tried to upload the zip file but the forum refuses to accept it
If you PM me your email (use -dot- and -at- to obscure a little) I'll email the zip P8X32A-Setup-Propeller-Tool-v1.3.2.zip
