PropTool 2.4
bambino69
After upgrading to this version the formatting was off. The same is true if I use the 2.3 alpha mod as well.
Has any else seen this and if not how do I correct it?
Edit: On closer inspection, it actually looks like the Prop Tool is rendering the text with weird spacing. I have no idea how to fix that...
If I enable line numbers only the left most digit is readable.
I reinstalled proptool still no font!
It still works properly.
Nobody else had this problem?
The gremlin king strikes again!
UPDATE - All servers are not created equal, slow transfer rates could be a problem and they somehow just time out. - Another served downloaded the Prop Tool 2.4 just fine.
Chip says he will have it fixed soon. Till then, downloading the 2.4 will be a headache to read anyway.
The latest version probably won't be 2.4 either by then. We just need to sit tight till parallax post's the fix.
You have to manually remove it via command line [or reinstall the Parallax.ttf font]. This is the log entry from the installation of 2.4r3 (as suggested by the developer):
2020-11-24 21:05:57.692 Dest filename: \Program Files (x86)\Parallax Inc\Propeller Tool\Parallax.ttf
2020-11-24 21:05:57.705 Time stamp of our file: 2020-11-24 08:28:06.000
2020-11-24 21:05:57.705 Installing the file.
2020-11-24 21:05:57.910 Successfully installed the file.
2020-11-24 21:05:57.911 -- File entry --
2020-11-24 21:05:57.912 Dest filename: C:\WINDOWS\Fonts\Parallax.ttf
2020-11-24 21:05:57.912 Time stamp of our file: 2020-11-24 08:28:06.000
2020-11-24 21:05:57.912 Dest file exists.
2020-11-24 21:05:57.912 Skipping due to "onlyifdoesntexist" flag.
This is an 'ls Para*' from the directory:
-a---- 1/25/2006 8:34 AM 1444060 Parallax.ttf
Once the 1.3.2 parallax.ttf file has been manually removed, everything works as expected.
Hope this helps.
https://www.parallax.com/package/propeller-tool-software-for-windows-spin-assembly-2/
