Tachyon NEON V5 (FAT32 and Ethernet Servers in 32kB EEPROM!)
1192021222325»
  • Peter,
    Sounds great! Did you forward these files to Bob?
    Jim
  • MJB - You mentioned a long time back that you had a tachyon 'language definition' for Notepad++
    Any chance of a copy please?
    Regards, Bob
  • bob_g4bby wrote: »
    Regards, Bob
    yes please!
  • MJBMJB Posts: 1,195
    Shawn Lowe wrote: »
    bob_g4bby wrote: »
    Regards, Bob
    yes please!
    yes - really long ago.
    I will have a look when I am at the other computer tomorrow
    edited 2020-11-12 - 20:33:48
    MJB wrote: »
    Shawn Lowe wrote: »
    bob_g4bby wrote: »
    Regards, Bob
    yes please!
    @Shawn Lowe , @bob_g4bby
    OK - this is from 2014-08-10
    --- just testet it with EXTEND and looks ok.
    Tachyon has changed a bit since then.
    So you might want to go through the keywords lists and update them.
    This can easily be done directly from Notepad++ menu Language/user defined language/Define your language
    after putting this file as NPP Tachyon Style File.xml in the \Notepad++\userDefineLangs folder.
    CORRECTION: you need to use IMPORT for the XML, that was created with EXPORT
    I you make a better / newer version please repost here for everyone.
    can'T see how to attach a file here ... strange
    so I put it inside a CODE block
    <NotepadPlus>
        <UserLang name="TachyonForth" ext="fth" udlVersion="2.1">
            <Settings>
                <Global caseIgnored="no" allowFoldOfComments="yes" foldCompact="no" forcePureLC="0" decimalSeparator="0" />
                <Prefix Keywords1="no" Keywords2="no" Keywords3="no" Keywords4="no" Keywords5="no" Keywords6="no" Keywords7="no" Keywords8="no" />
            </Settings>
            <KeywordLists>
                <Keywords name="Comments">00\ 01 02 03{ 04}</Keywords>
                <Keywords name="Numbers, prefix1">#</Keywords>
                <Keywords name="Numbers, prefix2">$</Keywords>
                <Keywords name="Numbers, extras1"></Keywords>
                <Keywords name="Numbers, extras2"></Keywords>
                <Keywords name="Numbers, suffix1"></Keywords>
                <Keywords name="Numbers, suffix2"></Keywords>
                <Keywords name="Numbers, range"></Keywords>
                <Keywords name="Operators1">- * / +</Keywords>
                <Keywords name="Operators2"></Keywords>
                <Keywords name="Folders in code1, open">: compiler definer pub pri</Keywords>
                <Keywords name="Folders in code1, middle"></Keywords>
                <Keywords name="Folders in code1, close">;</Keywords>
                <Keywords name="Folders in code2, open"></Keywords>
                <Keywords name="Folders in code2, middle"></Keywords>
                <Keywords name="Folders in code2, close"></Keywords>
                <Keywords name="Folders in comment, open"></Keywords>
                <Keywords name="Folders in comment, middle"></Keywords>
                <Keywords name="Folders in comment, close"></Keywords>
                <Keywords name="Keywords1">DROP DUP ?DUP OVER PICK ROLL ROT SWAP 0&lt; 0 0&gt; U&lt; D&lt; MAX MIN AND XOR OR MOD /MOD ABS NEGATE U* U/MOD D+ DNEGATE INKEY U R&gt; &gt;R ! @</Keywords>
                <Keywords name="Keywords2">IF ELSE THEN DO LOOP +LOOP I I&apos; J LEAVE BEGIN UNTIL WHILE REPEAT , C,</Keywords>
                <Keywords name="Keywords3">BASE VARIABLE ASCII DECIMAL CREATE CONSTANT DOES&gt; RUNS&gt; C ALLOT [ ] EXIT EXECUTE CALL ABORT QUIT TABLE</Keywords>
                <Keywords name="Keywords4">BEEP IN OUT VIS CLS AT HERE PAD SLOW FAST LINE PLOT LOAD SAVE VERIFY BLOAD BSAVE BVERIFY INVIS INKEY CR</Keywords>
                <Keywords name="Keywords5">IFDEF IFNDEF</Keywords>
                <Keywords name="Keywords6"></Keywords>
                <Keywords name="Keywords7"></Keywords>
                <Keywords name="Keywords8"></Keywords>
                <Keywords name="Delimiters">00( 01 02) 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23</Keywords>
            </KeywordLists>
            <Styles>
                <WordsStyle name="DEFAULT" fgColor="000000" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="COMMENTS" fgColor="800080" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="LINE COMMENTS" fgColor="008000" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="NUMBERS" fgColor="0000FF" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="KEYWORDS1" fgColor="804000" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="KEYWORDS2" fgColor="800040" bgColor="FFFFFF" fontName="Courier New" fontStyle="3" fontSize="10" nesting="0" />
                <WordsStyle name="KEYWORDS3" fgColor="FF0000" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="KEYWORDS4" fgColor="800000" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="KEYWORDS5" fgColor="FF8000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="KEYWORDS6" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="KEYWORDS7" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="KEYWORDS8" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="OPERATORS" fgColor="0000FF" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="FOLDER IN CODE1" fgColor="0000FF" bgColor="FFFFFF" fontName="Courier New" fontStyle="1" fontSize="10" nesting="0" />
                <WordsStyle name="FOLDER IN CODE2" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="FOLDER IN COMMENT" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS1" fgColor="0000FF" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS2" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS3" fgColor="000000" bgColor="FFFFFF" fontName="" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS4" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS5" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS6" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS7" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
                <WordsStyle name="DELIMITERS8" fgColor="000000" bgColor="FFFFFF" fontStyle="0" nesting="0" />
            </Styles>
        </UserLang>
    </NotepadPlus>
    p.s.: if you want to change it - it is good to have a large forth file open - I recommend EXTEND. Then you can immediately see the changes you make.
    actually I am just at it ;-)
  • I have a highlighter for VS Code that I modified from a general Forth grammar if you want it. I keep it in my Tachyon Dropbox but I will move it to a more easily accessed folder in the root under utilities.
  • bob_g4bbybob_g4bby Posts: 118
    edited 2020-11-13 - 14:33:20
    Many thanks for the 2 options, both. I'll have a go with the Notepad++ file and repost any updated version.
  • I'm looking to get started with Tachyon with my QuickStart board while I am waiting for my RetroBlade2 and P2D2 to come in. Do you have a binary I could load up?
    Alternatively, I have:
    DemoBoard
    PropDongle
    ProtoBoard USB
    Initially I just want something that I can play with over usb/serial without dependence on a SDcard.
    I downloaded the 500+MB of Peter's "The LOT" link above, but that is a bit of bewildering overkill to figure out a simple way to get started. I looked at sourceforge, and was similarly confused as to where to start.
    Any help appreciated.
  • hinv wrote: »
    DemoBoard
    PropDongle
    ProtoBoard USB
    There are a lot of links in my sig but you can use this copy here.
  • There are a lot of links in my sig but you can use this copy here.
    Yes, there are. That is the problem, information overload and not a clear place to start for someone with no experience with it.
    Thanks for the binary, but proploader won't load it. It just gives "internal error". I'm guessing it is too big to fit in ram so proploader just dies with a poor error description. Is that a .eeprom file instead?
    I would like to dump the contents of the eeprom that are there first so I can put it back later, and was going to use your message on ROM dumping to do it https://forums.parallax.com/discussion/171064/rom-dumping. Do you have a binary to get me up and running in ram so I can dump the eeprom with that?
  • I just tried this binary with BST and also Proptool, so I'm not sure what loader you are using. However if the loader has some kind of limitation then maybe this 32k version of the binary might work.
    Yes, thanks! That worked great. Now I just need to learn Tachyon. Seems pretty cool! The stack looks upside down compared to my HP calculator.
  • Peter JakackiPeter Jakacki Posts: 9,811
    edited 2020-11-16 - 02:58:43
    Compared to anything it's different :)
    The top of the stack is the top and the bottom is the bottom.
    TF5> 12 34 56 ---  ok
    TF5> .S ---  Data Stack (3)
    $0000.0038 - 56
    $0000.0022 - 34
    $0000.000C - 12
    If you are using an ANSI terminal then Tachyon will detect this at reset and switch to ANSI mode for bold and colors.
    Use WORDS for a plain text listing of the dictionary or use WWORDS for a formatted colored listing.
    Unlike other Forth's, whatever you type in interactively is compiled word by word in a temporary area, so you can't backspace to the previous word (hit esc to cancel the whole line), and once you hit the enter key it will execute the compiled code. Because it is compiled it means that you can use all the stuff that you normally would inside a definition such as DO LOOP IF THEN etc. Try this:
    $7F $20 DO I EMIT LOOP
    Check the wiki and blogs on my Source Forge page as well as the other links for some more intro stuff.
    Use number prefix to force hex $F000 or binary %1011 otherwise the default is decimal.
    edited 2020-11-16 - 13:35:07
    Message removed
