ROM Dumping
in Propeller 1
Anyone used Propellor to dump ROMs from vintage chips. Microvision etc that use the TMS1000 chip. Thanks
Charles Harris
Charles Harris
If you connect the ROM data bus via 3k3 resistors to P0..P7 and up to 16-bits of address to P8..P23 for instance, and tie the OE low, then here is 2 lines of Tachyon code that will copy 32k of ROM into the upper part of the EEPROM (as a demo). With another line or two you could save it into a file on an SD card instead.
with another line you can make the ROM a memory device that the various DUMP utilities can handle
Then when you dump memory you can specify the ROM instead like this: Normally it's hub memory that gets dumped and that is also the default after every dump operation.
The first ROM@ is for bytes, and I just dummied up the 16-bit and 32-bit versions as you probably wouldn't use them although they are very simple to create from ROM@ itself.
Thanks for informative messages. Appreciated.
Who has done a actual dump from a TMS1000 ? these have a masked program accessible via Test Mode apparently. What result do you get. Copy or part copy ok. Anyone in New Zealand done this.
Charles
