P2 HDMI - Page 3 — Parallax Forums
P2 HDMI
13»
  • RaymanRayman Posts: 16,109
    edited 2020-11-11 01:48
    Maybe try with the new prop tool?
    I haven’t seen these kind of errors before ...
    What folder is pnut in?
  • Power for 7-inch LCD.
    1. To get +5V at a P2 EVAL board's expansion pin groups you must bridge the ACC HDR 5V jumper on the board. Without that jumper you will not have 5V at the 12-pin headers.
    2. Connect the 4-wire plug to an external 5V power supply. The P2 EVAL board I have--Rev B--does not provide enough power (about 0.5A) at the expansion pins labeled 5V. Red wire to ground; white wire to +5V.
    Spiral-colors demo working just fine. Cheers and stay well. --Jon
