Dumbo BASIC - a curiosity for those of us who remember the '80s !
RossH
All,
I'm not getting as much time as I'd like to work on Catalina at the moment, but here is something I've been working on for a while in the background ... a new version of Dumbo BASIC. A version of Dumbo BASIC is already distributed as part of Catalina, but this version is much more complete. I'm posting it because it may be a while before I get a chance to release the next full version of Catalina.
Dumbo BASIC is a GWBASIC clone, written in C, which runs on Windows, Linux, and the Propeller (P1 and P2). Those of us who fondly remember the early days of PCs and GWBASIC might find it amusing.
On the P1 Dumbo BASIC is quite slow (because it must execute from XMM RAM) but on the P2 it is very usable. I have recently added most of the GWBASIC language, including all the file handling statements and functions, and now verified most of it against GWBASIC itself (the differences are explained in the README.TXT file).
Still missing are all the graphics functions, which are waiting on me getting a working version of a VGA tile driver and a graphics package for the P2. I plan to use Rayman's tile driver, but this may take me some time to complete. Then, Dumbo BASIC will be a complete GWBASIC clone.
Attached you will find the source (and a Windows executable!), and also a binary release of Catalyst (which includes Dumbo BASIC) that can be loaded onto an SD card and used on a P2_EVAL board. Along with the vi text editor, this makes dbasic quite a usable BASIC development system. It uses a serial terminal at 230400 baud. You will need a VT100 compatible terminal emulator (such as putty, or Catalina's own payload program).
Here is the README.TXT:
Note that this version should be compilable with any C compiler, but I have only tried compiling it with gcc and Catalina. If anyone gets it working with some of the other C compilers available, I'd be happy to incorporate any modifications you had to make.
Errata: When using the Catalyst vi text editor on some of the BASIC files, you may need to specify msdos formatting. Use a command like:
Also, I forgot to include the CR_ON_LF option when compiling, so if you are using putty as your terminal emulator, you will probably need to set the "Implicit CR in every LF" terminal option.
Ross.
Dumbo BASIC v1.0
Dumbo BASIC is a BASIC interpreter. It was initially written as a demo program
for Catalina/Catalyst, but it can also be used stand-alone, either on the
Propeller, or on Windows or Linux.
Dumbo BASIC implements a substantial subset of the GWBASIC language. The main
things missing are some of the very PC or MS-DOS specific features, such as
graphics and COM functions - but there may be Propeller equivalents added.
On the Propeller 1, Dumbo BASIC should be compiled using the LARGE memory
model (it can be compiled with the SMALL memory model but it would only be
able to execute very small BASIC programs). It requires 512KB XMM SRAM
(or 512KB of XMM FLASH plus at least 64KB of XMM SRAM) and an SD card.
On the Propeller 2, Dumbo BASIC can be compiled using the NATIVE or COMPACT
memory model. It requires an SD card.
Dumbo BASIC can also be compiled with gcc, either on Windows or Linux.
Unlike GWBSIC, Dumbo BASIC is not an interactive environment. It just loads
and executes a BASIC source file, which must be edited in another program.
If you are using Catalyst, the vi text editor can be used to create or edit
the program, and then Dumbo BASIC can be used to execute it.
Dumbo BASIC is loosely based on "Mini Basic" by Malcolm McLean, but has been
heavily modified and extended to add many common BASIC statements that Mini
Basic lacked (e.g. WHILE .. WEND, ON .. GOTO, ON..GOSUB) and also additional
types (Dumbo BASIC supports both integers and reals, whereas Mini Basic only
supports real variables). The token parsing and the expression parsing have
both been completely rewritten (Mini Basic failed to parse anything except
trivially simple expressions). Dumbo BASIC also supports statements without
line numbers, and multiple statements on the same line (Mini Basic supports
neither). File support has been added (Mini Basic had none). There are various
other tweaks to bring the overall syntax closer to that used by GWBASIC.
Dumbo BASIC currently executes BASIC programs at between 50 - 100 lines per
second on the Propeller 1 at 80Mhz, or about 5500 lines per second on the
Propeller 2 at 180 Mhz (or about 8000 lines per second at 260 MHz).
The reason Dumbo BASIC is so much slower (and so variable!) on the Propeller 1
is that it must execute from XXM RAM, and so the speed depends on the speed of
the XMM interface, the memory model (SMALL or LARGE), the cache size (1k - 8k)
etc. However, it is still fast enough to successfully run many BASIC programs,
and further speed improvements will be forthcoming in future versions.
This release of Dumbo BASIC (1.0) implements most of the GWBASIC statements
and functions, and can be used to execute real-world programs - for example,
it can execute the classic ELIZA psychoanalyst program - albeit a bit slowly
on the Propeller 1 (it can take up to 30 seconds for Eliza to respond to each
line of input).
As well as various small example programs, and Eliza, there are three different
BASIC versions of Startrek included - mostly "as is" but sometimes with a few
tweaks to make them GWBASIC compliant (they were originally written for other
BASIC interpreters). They are:
startrek.bas
trek15.bas
ut-trek.bas
NOTE: These programs all expect an 80 character terminal, and therefore may
not look very good on platforms that only have TV ouptut (such as the Hybrid)
where Dumbo BASIC has to use a 40 character screen.
Also, note that many old BASIC programs only recognize UPPER CASE input.
BUILDING DUMBO BASIC
To compile Dumbo BASIC for all Propeller platforms except Morpheus, use the
'build_all' script provided, specifying the platform on the command line (for
Morpheus, see the next section).
Note that you will need to specify the HMI option if you do not want to use
the default HMI on the platform, plus any other platform specific options,
such as the CPU to use.
For example:
build_all HYBRID
build_all DRACBLADE
build_all TRIBLADEPROP CPU_2 PC
build_all QUICKSTART PMC FLASH CACHED_1K
build_all P2_EVAL TTY VT100 MHZ_260
BUILDING DUMBO BASIC FOR MORPHEUS
On Morpheus, Dumbo BASIC requires the use of proxy drivers. There is a batch
file provided which builds both the interpreter and the proxy.
Use the command:
build_morphues
BUILDING DUMBO_BASIC FOR WINDOWS OR LINUX
Note that you can also build Dumbo BASIC to run under Windows or Linux. This
requires gcc to be installed. To compile Dumbo BASIC with gcc, use a command
similar to the following:
gcc -o dbasic -lm dumbo_basic.c basic.c tokenizer.c
RUNNING DUMBO BASIC
To run Dumbo BASIC on the Propeller 1 using Catalyst, first copy the Catalyst
programs to a FAT16 SD Card, and program the catalyst.bin into EEPROM. Then
copy the following files to the SD card, renaming them to fit into 8.3
filenames. The following names are recommended:
dbasic.binary -> DBASIC.BIN
proxy.binary -> PROXY.BIN (Morpheus only)
A script to do this (copy_all) is provided. It will also copy the example
basic programs. Note that depending on your version of Catalina, Catalyst
may already have a version of dbasic.bin - if so, overwrite it with this
version.
On the Propeller 2, the process is much the same, except that you do not need
to load Catalyst into EEPROM - it can execute directly from the SD Card.
On other platforms, simply execute the 'dbasic' program.
To load a basic program on all platforms except Morpheus simply specify the
basic file to load and execute on the command line. For example:
dbasic eliza.bas
If you do not specify a basic file to load and execute, Dumbo BASIC will
prompt for one.
On Morpheus, you must execute both the Dumbo BASIC interpreter and a proxy
driver. When Dumbo BASIC is loaded this way you cannot specify command line
parameters - so you must tell Dumbo BASIC the name of the BASIC file to load
when it prompts. Enter the commands:
boot_2 <- load the boot loader into CPU #2
@ <- to select CPU #2 for next load
dbasic <- load the client into CPU #2
proxy <- load the proxy server into CPU #1
IMPLEMENTATION STATUS
The core BASIC language is fully implemented. The following sections summarize
the current status of Dumbo BASIC versus GWBASIC.
CURRENTLY IMPLEMENTED GWBASIC STATEMENTS (FULLY OR PARTIALLY)
ABS
ASC
ATN (synonym for ATAN)
ACOS
ASIN
CLS
CDBL (currently equivalent to CSNG)
CHR$
CINT
COS
CSNG
CLOSE
CVS
CVI
CVD
DATA
DATE$
DEF FN
DEFINT
DEFSNG
DEFDBL (currently equivalent to DEFSNG)
DEFSTR
DIM
END
EXP
EOF
ERROR
ERL
ERR
FIX
FOR
FIELD
GOSUB
GOTO
GET#
HEX$
IF
INPUT
INPUT#
INSTR
INT
INKEY$
LINE INPUT
LINE INPUT#
LEFT$
LEN
LET
LOG
LOC
LOCK
LOF
MKD$
MKI$
MKS$
MID$
NEXT
OCT$
ON GOTO
ON GOSUB
ON ERROR GOTO
OPTION BASE
OPEN
POS
POW
PRINT (also ? is a synonym for PRINT)
PRINT USING (partial)
PUT#
PEEK
POKE
RANDOMIZE
READ
REM (also ' is a synonym for REM)
RETURN
RIGHT$
RESTORE
RESUME
RND
SGN
SIN
SPC
SQR
SPACE$
STOP
SWAP
TAB
TAN
TIMER
TRON
TROFF
VAL
VALLEN
WHILE
WEND
WIDTH
WRITE
WRITE#
NOT CURRENTLY IMPLEMENTED
BEEP
CALL
CHAIN
CIRCLE
COLOR
COM(n)
CSRLIN
DEF SEG
DEF USR
DRAW
ENVIRON
ENVIRON$
ERRDEV
ERRDEV$
EXTERR
ERASE
FRE
GET (except for files)
INP
IOCTL
IOCTL$
INPUT$
KEY
LINE
LPOS
LPRINT
LPRINT USING
LOCATE
LOCK
ON COM
ON KEY
ON PEN
OM PLAY
ON STRIG
ON TIMER
OPEN "COM(n)"
OUT
PAINT
PALETTE
PALETTE USING
PCOPY
PEN
PLAY
PLAY(n)
PMAP
POINT
POS
PRESET
SCREEN
SHELL
SOUND
STICK
STRIG
STRIG(n)
USR
UNLOCK
VARPTR
VARPTR$
VIEW
VIEW PRINT
WAIT
WINDOW
IMPLEMENTATION DIFFERENCES BETWEEN DUMBO BASIC AND GWBASIC
The following dfferences between Dumbo BASIC and GWBASIC may affect how
some BASIC programs behave:
1. In Dumbo BASIC, integers are 32 bits, not 16 bits.
2. In Dumbo BASIC, single precision and double precision floats are both 32
bits, not 32 bits for singles and 64 bits for doubles.
3. In Dumbo BASIC, the maximum number of dimensions for an array is 5.
4. In Dumbo BASIC, the maximum number of open files is hardcoded to 3.
This can be changed in the Dumbo BASIC source file "basic.c"
5. In Dumbo BASIC, the maximum record size for random access files is
hardcoded to 128. This can be changed in the Dumbo BASIC source file
"basic.c"
6. In Dumbo BASIC, the maximum number of user-defined functions is 32, and
the maximum number of arguments to a user defined function is 5. Both of
these can be changed in the Dumbo BASIC source file "basic.c".
7. In Dumbo BASIC, the maximum number of nested fors, whiles, or gosubs is
hardcoded to 32. Each of these can be changed in the Dumbo BASIC source
file "basic.c".
8. In Dumbo BASIC, file access modes and lock options specified in OPEN
statements are accepted but ignored.
9. In Dumbo BASIC, strings are normal C strings (i.e. terminated by a zero
character), except when a string variable is used in a FIELD statement.
This means that you should not put a zero character in a string variable
EXCEPT when the string variable represents a FIELD, and also that the LEN
function may return an incorrect length when used on a string variable that
is actually a FIELD, or one which contains a zero byte.
10. In Dumbo BASIC, the functions MKI$, CVI, MKS$, CVS, MKD$, CVD all work as
expected in conjunction with FIELDs (which is where they are mostly used),
but note that you must assign to FIELD variables using the LET or LSET
statements, not RSET. RSET will not work if the value being assigned
contains a zero character. This is a consequence of difference 9 (above).
11. Dumbo BASIC uses the size of C int and float types for the MKI$, MKS$ and
MKD$ functions on whatever platform it is running, not 2 bytes, 4 bytes
and 8 bytes as GWBASIC does. Similarly, the CVI, CVS & CVD functions all
expect strings of those sizes. This means (for example) that when Dumbo
BASIC is compiled with Catalina for the Propeller, integers, single and
double precision numbers are all 4 bytes long when converted to strings.
12. PEEK and POKE use a simple linear address on the Propeller, not the
segment address (DEF SEG is not implemented) and offset used in MS-DOS.
13. The USING clause of the PRINT and PRINT# statements is not yet fully
implemented.
The implemented options are:
! for printing just the first character of a string
\ \ for specifying a fixed length string field
& for specifying a variable length string field
# for specifying digits
. for specifying a decimal point
$$ for specifying a dollar sign
_ for specifying the character following the underscore
Not implemented are:
** for specifying numbers should be filled with * (not space)
^^^^ for specifying exponential formatting (this is automatic)
+ or - for forcing the printing of a sign (leading or trailing)
, for separating each group of 3 digits by a comma
% printed if the number exceeds the specified field length
vi -s fmt=msdos startrek.bas
Ross.
Hey Ross. I am a BASIC programmer from the 80's but that was when we got QuickBASIC and so I have never used the old line numbers, etc.
I just wish that I had the skills to port Micromite BASIC to P2.
A modern, structured BASIC interpreter where you have the possibility to throw some of your routines in to FlexBASIC, compile them and launch them in cogs from the Micromite interpreter
And you call yourself a real programmer???
Probably not worth posting a new version just for this, but if anyone is particularly interested, just let me know.
Ross.
