Operating backhoes and front end loaders is an art. When you see efficient and smooth movements you are watching a master at work. I have often wondered if a miniature arm with encoders at each joint beside the seat would be a simpler way to control the motion of the exterior one.
It would likely be easy for the first half hour of use. Once a person is used to operating the real controls, I'd think they'd be much faster with the inputs than trying to manipulate a miniature arm.
I'd think once a person had enough practice, the motions would come without having to think about.
The problem is the relative cost of hydraulic proportional valves vs hand operated. I have had moderate success with PWM-ing the coils of a basic directional valve (open-loop) but I need to give it a jolt of 100% current just to get the spool moving. From there, it's really nice. I can regulate the velocity from a creep to full-tilt. I intend to pursue this because at the very least, I can eliminate hydraulic flow controls on machines that I retrofit, without having to spend $1,500 to $2,000 per proportional valve.
Yes, the price difference between a regular valve and a proportional one was a bit of a surprise when I started working on servo-hydraulic systems. The first valve I replaced was $4895.00. Amazing what they could do though.
Ah but a very useful tool application for laying down electrical conduit I wish I had something like that about a month ago when I was doing this project
Or the caption could be "Just you wait until your ______________________ gets home!!"
..........................................................................(politically (in)correct parental unit here)
dots here because forum seems to dump leading spaces.
dgately
Seriously though, I think I could dig the trench faster by hand, but it wouldn't be as much fun.
Komatsu PC01
$79 at Kohls....
Bang-bang to proportional control
So, I'm reading this thread and it occurs to me my shirt is appropriate to this discussion!
Doc
