$5 AC Ammeter Sale?
This seller has a "$5 off" sale on certain items now. Seems too good to be true, but if course I ordered. Seller might come to his senses and stop the sale and/or cancel orders, but pounce if you're a gamblin' man! Add to cart to see discount. I'll bet they meant 5% off, not $5...
$5 clamp-on AC ammeter (US shipper!): https://www.ebay.com/itm/Digital-LED-Clamp-Meter-Tester-AC-Volt-Amp-Multimeter-Current-Resistance-Tester/164248259970
$2 2" LCD SPI display: https://www.ebay.com/itm/2-2inch-240x320-TFT-LCD-DisplaySPI-ILI9341-for-51-AVR-STM32-ARM-PICArduino/164252531768
Also check the "see other $5 off items" link on those pages.
I already received the two I ordered for $5, so it's not a scam!
https://www.ebay.com/itm/1280Pcs-Metal-Film-Resistor-1R-10M-64-Models-Resistors-Assortment-Kit-Durable/164212130241
(Don't ask how I know this....)
High currents and voltages definitely call for using a clamp on ammeter and great care.
https://www.grainger.com/product/3ZH94
Yes! Very important factoid. I use this technique 5 days a week on some high power machines. Sometimes a surprise awaits you.
Am I correct to assume these machines don't have a third ground wire?
A fault which sends the current back down the ground wire wouldn't show up using this technique, right?
But generally speaking you are right that a merger would tell if you have an issue to ground but not between windings
