help me understand — Parallax Forums
help me understand
I have a rev b eval board.
When I run the simple program below the terminal values are correctly adding 1 with each iteration.
When I look at the leds, the values are inverted from what I would expect. I would think writing a "1" to the out register should turn on the LED.
Can someone explain to me why the LED values are inverted?
Thanks in advance
Greg
_clkfreq = 10_000_000
pub go() | LEDs
repeat
LEDs += 1
debug(ubin(LEDs), "'")
pinwrite(56 addpins 7, LEDs)
waitms(2000)
  • The LEDs on the evaluation board are active low.
    There's a buffer between the P2 and the LEDs.
  • Well thats an easy enough answer. Thanks quick answer.
    Why would active low LEDs be desirable?
  • groebke1 wrote: »
    I'm not sure but my guess would be they wanted an inexpensive buffer chip which wouldn't interfere with the I/O pins if the pins were used for other purposes.
    FWIW, active low LEDs are pretty common.
    Active low goes back in history when there was more drive current available by pulling a line low than driving it high.
    And now, often LEDs have a voltage drop around 3V which means they need to be tied to 5V so that the resistor can be calculated to set the current reliably.
  • cgraceycgracey Posts: 14,319
    I think in our case, we just spec'd an inverting 8-bit buffer. Maybe VonSarvas chose an inverting buffer because many of those top eight signals are active-low, like RX, TX, and SPI_CS. It's better for the lights to come on when something is happening, rather than during idle states.
  • Those two leds on P56 / P57 on the Edge module, are those active low, or active high?
    Tubular wrote: »
    They are active-high.
