I just dug up a jpeg decoder that worked under GCC on P1...
It seems to choke on initializing the 2D int array in the attached...
Gives this error: >fft.c:3: error: wrong kind of initializer for array type
Should one be able to declare a 2D array like this:
int fft[64][64]={
+8192, +8192, ... (lots of more integers here)
Yes, that is still legal C (although I think it's deprecated in favor of grouping the numbers into the appropriate sub-arrays). As it happens I'm working on the initializer code now to support C99 designators like ".x = 2" or "[1] = 99" to initialize specific struct or array elements, and I've fix that as well.
Is ftell() something that FatFs should be providing?
Not fatfs per se, but rather the higher level code: stdio is currently missing fseek() and ftell(). These should be easy to implement in terms of the lower level lseek() function.
I've attached an updated fastspin with these changes. fseek() and ftell() are in include/libc/stdio/fseek.c, and are completely untested. Caveat emptor!
which will be turned on/off by defining USE_DEBUG on the command line or in a header file.
Note the double parens to make the whole contents of the macro into one symbol. You could make this cleaner by using a varargs macro, but I can never remember the syntax for those.
Possible bug in fastspin, compiling code with secondary object that contains inline assembly...
Although I'm able to compile JonnyMac's "jm_time_200.spin2" file on its own, I get compile errors when that file is used as an object from another spin2 file such as: "jm_rgbx_pixel_demo.spin2". Sources from GIT OBEX are attached:
jm_time_200.spin2 compiled on its own:
"flexgui/bin/fastspin" -2 -l -D_BAUD=230400 -O1 -I "flexgui/include" -I "flexgui/include/spin" -I "source/propeller/libraries/community/p2/All/jm_serial" -I "source/propeller/libraries/community/p2/All/jm_full_duplex_serial" -I "source/spin2cpp/include" "Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2"
Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2020 Total Spectrum Software Inc.
Version 4.3.1 Compiled on: Aug 26 2020
jm_time_200.spin2
jm_time_200.p2asm
Done.
Program size is 1336 bytes
Finished at Sat Sep 12 05:42:40 2020
jm_time_200.spin2 compiled as an object from jm_rgbx_pixel_demo.spin2:
"flexgui/bin/fastspin" -2 -l -D_BAUD=230400 -O1 -I "flexgui/include" -I "flexgui/include/spin" -I "source/propeller/libraries/community/p2/All/jm_serial" -I "source/propeller/libraries/community/p2/All/jm_full_duplex_serial" -I "source/spin2cpp/include" "Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_rgbx_pixel_demo.spin2"
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:113: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:114: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:116: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:117: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:118: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:119: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:120: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:121: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:122: error: Variable ms must be placed in memory (probably due to an @ expression) and hence cannot be accessed in inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:124: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:125: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:126: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:129: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:130: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:131: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:132: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:133: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:134: error: Operand too complex for inline assembly
Desktop/jm_rgbx_pixel/jm_rgbx_pixel_demo/jm_time_200.spin2:135: error: Operand too complex for inline assembly
|-jm_time_200.spin2
|-jm_rgbx_pixel.spin2
|-|-jm_gamma8.spin2
child process exited abnormally
Finished at Sat Sep 12 05:43:28 2020
@dgately : That inline assembly is using array references, and in fastspin arrays are placed in hub memory. It's going to be some time before I can correct it. The "submodule" issue is a red herring, the method using that inline assembly was being removed before.
@Rayman : wordfill does not change its first argument. My guess is that it's overrunning the provided buffer and corrupting the stack or something like that.
There's something I don't understand going wrong with this 16bpp bmp example if I move the VGA.start() to before uSD mounting...
If this section is moved first:
[b //Start up VGA
int cf = _clockfreq();
printf("clock freq= %d\n", cf);
Vga.Start(); //Note: cog# and basepin are currently set in VGA_16bpp.spin2 (also note that clock setting there must match what is here).[/b]
The embedded bitmap file appears to have been moved in memory (but I think this is unlikely).
Update: It looks like Vga. just needs to be called before mounting uSD. I added this simple function to set the cog# for VGA and it works when I call it before mounting uSD.
Also, I'm trying to figure out how to pass the clock frequency from C into Spin2 in order to calculate fset value...
Currently doing it like this in CON section:
Sorry, one other strange thing...
I've made vsync an assembly register instead of a constant.
Then, I set it to actual value before starting the assembly driver cog.
You can use #define and #include in both C and Spin2, so the easiest way is to make a header file "freq.h" like:
#define RUNFREQ 200000000
and then #include this in both your C and Spin2 code, and use RUNFREQ everywhere that you used to use the constant 200_000_000. NOTE: do not put any comments into the freq.h header file, C and Spin have different kinds of comments!
This works like this:
vsync long 1
but not like this:
vsync res 1
Shouldn't it work either way?
No, because if you're setting it before starting the cog then you need to have storage for it. Basically anything defined with "res" is only valid *inside the cog code where it is defined*; outside of it it's undefined.
What do you make of the order of calling sd code and vga code making a difference?
I have no idea what's going on there, and haven't really had time to look at it. Maybe there's a timing dependence? Or one is accidentally writing into memory that the other one is using?
@Rayman : I can't see your code, the link you posted just points at a picture (.png).
@dgately : I've updated github with some fixes to inline assembly which may help with your object. At least, it compiles now, although I don't have hardware to test it.
pBuff is a local variable, so as soon as the Start() function returns it's no longer valid (other things could be written on the stack). That means the VGA cog might get the wrong data for it. To avoid this, either put a short delay after the coginit(), or use a variable in the VAR section to pass the information to the COG. I also see the COG reads two longs from ptra, but only the first one is actually valid (there's only one piece of data located at address @pBuff, namely the value "@BmpBits+70".
The picojpeg code I'm working in does include on a C file like this:
#include "stb_image.c"
I've never seen this before... Web seems to say it's not so good. But, from my understanding I don't see anything wrong with it and it seems to work...
I'm a bit tempted to do more of that to clean up my main C file to just have main() in it...
How bad is this?
Any chance of one day getting something like GDB working with FlexC?
If not, maybe some kind of interactive thing in the terminal?
I really hope Parallax (i.e. Chip I guess) makes a real debugger for the P2. The Spin2 DEBUG() statement is nice, but it's really just a fancy form of printf debugging. If that happens then I'll try to support it in fastspin.
How bad is this?
It's legal and it will work, but it seems to be considered poor style. OTOH for your code you should do what you want.
I added in 64 sets of braces and seems to be working...
These codes both seem to use fseek and ftell... the later just to get the filesize, which seems like a roundabout way of doing that...
Great news! I'm glad you got it to work. fastspin C is getting a little more usable every day, thanks for your bug reports.
Not in C; "debug" is a Spin only feature.
The usual approach in C is to do something like: and then insert statements like:
debug(("the value of x is %d", x));which will be turned on/off by defining USE_DEBUG on the command line or in a header file.Note the double parens to make the whole contents of the macro into one symbol. You could make this cleaner by using a varargs macro, but I can never remember the syntax for those.
jm_time_200.spin2 compiled as an object from jm_rgbx_pixel_demo.spin2: This code builds completely in PNut.v34z
dgately
I have this:
It appears to be modifying the value of pBuff after use... That's not right, is it?
#define P2_TARGET_MHZ 240 #include "sys/p2es_clock.h" // ----------------------------------------------------------------------------- int main() { //set the clock _clkset(_SETFREQ, _CLOCKFREQ);@Rayman : wordfill does not change its first argument. My guess is that it's overrunning the provided buffer and corrupting the stack or something like that.
[b //Start up VGA int cf = _clockfreq(); printf("clock freq= %d\n", cf); Vga.Start(); //Note: cog# and basepin are currently set in VGA_16bpp.spin2 (also note that clock setting there must match what is here).[/b]The embedded bitmap file appears to have been moved in memory (but I think this is unlikely).
Files are here: https://forums.parallax.com/plugins/FileUpload/images/file.png
I've tried a few ways of calculating fset in Spin2, but nothing seems to work...
Maybe because it's floating point...
I guess I can figure this out myself, but just thought you might already know how to do this...
but not like this:
Seems to mess up address of bmp file include...
Try here: http://forums.parallax.com/discussion/172026/flexc-with-visual-studio#latest
PUB Start()|pBuff pBuff:=@BmpBits+70 coginit(vga_cog,@VgaOrigin, @pBuff)pBuff is a local variable, so as soon as the Start() function returns it's no longer valid (other things could be written on the stack). That means the VGA cog might get the wrong data for it. To avoid this, either put a short delay after the coginit(), or use a variable in the VAR section to pass the information to the COG. I also see the COG reads two longs from ptra, but only the first one is actually valid (there's only one piece of data located at address @pBuff, namely the value "@BmpBits+70".//Configure VGA driver cog and pins float fpix = 25000000; float fclk = _clockfreq(); float fset = (fpix / fclk * 2.0) * ((float)(0x40000000)); //pixel transfer frequency int iset = (int)fset; int VgaCog = 1; int VgaBasePin = 0; Vga.Config(VgaCog, VgaBasePin, iset);//Config(cog, basepin, xfreq)'Thinking it's better this way...
Thx!
Or, do I need to make a structure for that?
How bad is this?
You need to make a structure.
