...and there is no executable for Windows or the Mac either. Fixing that is beyond what I have time for now.
I wonder how they compiled for win32... I use it (esptool-ck windows version) in my dos batch file I posted earlier in this thread.
The Makefile has instructions for building it under Windows. I just don't have time to install the cross tools to do it. If someone else wants to try, I'd be happy to merge their changes.
@"Clock Loop" I just pushed changes to build esptool-ck, add it to the release folder, and use it in the flash scripts. Please check to see if this works for you.
YOU DID IT ALL!!!!! I didn't need to edit a single file.
GIT to flash! Like a nice wrapped up gift presented on a silver platter, NICE JOB, Thank you.!
BTW, in case it isn't obvious, the Parallax-ESP build assumes a 2MB module. Even if the actual module is 4MB, only the first 2MB is used. This is because Parallax had some 2MB and some 4MB modules and I'm not sure if any of the 2MB modules made it into the field other than prototypes so we are being conservative.
I have more bad news.
When powering on any of my esp's (they all have the working firmware from the last working commit) and then connecting to them in ap mode.
When I navigate to the Networks page the module will do a hard crash and restart.
It will only do this when you first access the network page after it powers on, repeated accessing the page will not crash the module.
Heres the debug pin output. From power on, you can see where it crashes.
It has a E:M 2056 and a E:M 2096, I don't normally see those.
This is the parallax WX esp8266 module.
When it crashes, my webbrowser times out, my pc immediately reconnects(like it didn't even disconnect to the ap)
And I then click the esp address bookmark again and then the network page, and it doesn't crash.
Flash config restore ok
108> Reset Pin: 13
109> RX Pullup: 0
115> DISCOVER: initialized
115> Version v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)
115> Using pin 13 for reset
116> 2MB flash: base 00100000, size 1048576
120> Flash filesystem mounted!
124> Httpd init
125>
126> Ready
127> mode : softAP(xx:xx:xx:xx:xx:xx)
131> add if1
133> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
140> bcn 100
47679> add 1
47679> aid 1
47679> station: xx:xx:xx:xx:xx:xx join, AID = 1
80281> Conn req from 192.168.4.2:60624, using pool slot 0
80283> URL = /
80286> Pool slot 0 is done. Closing.
80286> Pool slot 0: socket closed.
80291> Conn req from 192.168.4.2:60626, using pool slot 0
80292> URL = /index.html
80295> Heatshrink compressed file; decode parms = b4
80323> Pool slot 0 is done. Closing.
80324> Pool slot 0: socket closed.
80427> Conn req from 192.168.4.2:60628, using pool slot 0
80428> URL = /style.css
80428> Heatshrink compressed file; decode parms = b4
80474> Pool slot 0 is done. Closing.
80474> Pool slot 0: socket closed.
80477> Conn req from 192.168.4.2:60630, using pool slot 0
80478> URL = /logo.png
80524> Pool slot 0 is done. Closing.
80524> Pool slot 0: socket closed.
80531> Conn req from 192.168.4.2:60632, using pool slot 0
80532> URL = /wx/setting?name=module-name
80532> GET args = name=module-name
80534> GET 'module-name' --> 'PCB1'
80539> Pool slot 0 is done. Closing.
80542> Pool slot 0: socket closed.
80546> Conn req from 192.168.4.2:60634, using pool slot 0
80550> URL = /favicon.ico
80552> Heatshrink compressed file; decode parms = b4
80563> Conn req from 192.168.4.2:60636, using pool slot 1
80564> URL = /wx/setting?name=version
80565> GET args = name=version
80568> GET 'version' --> 'v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)'
80576> Pool slot 1 is done. Closing.
80578> Pool slot 0 is done. Closing.
80581> Pool slot 1: socket closed.
80584> Pool slot 0: socket closed.
82823> Conn req from 192.168.4.2:60640, using pool slot 0
82824> URL = /wifi/wifi.html
82825> Heatshrink compressed file; decode parms = b4
82858> Conn req from 192.168.4.2:60642, using pool slot 1
82859> URL = /wifi/style.css
82860> Heatshrink compressed file; decode parms = b4home page
82862> Conn req from 192.168.4.2:60644, using pool slot 2
82867> E:M 2056
82869> URL = /wifi/140medley.min.js
82872> Heatshrink compressed file; decode parms = b4
82877> E:M 2096
82878> Fatal exception 29(StoreProhibitedCause):
82883> epc1=0x4000df64, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92home page
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 80MHz
SPI Mode : QIO
SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
112> Reset Pin: 13
112> RX Pullup: 0
118> DISCOVER: initialized
118> Version v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)
118> Using pin 13 for reset
120> 2MB flash: base 00100000, size 1048576
124> Flash filesystem mounted!
127> Httpd init
129>
129> Ready
131> mode : softAP(xx:xx:xx:xx:xx:xx)
134> add if1
136> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
144> bcn 100
5603> add 1
5603> aid 1
5603> station: xx:xx:xx:xx:xx:81 join, AID = 1
10174> Conn req from 192.168.4.2:60646, using pool slot 0
10176> URL = /wifi/140medley.min.js
10177> Heatshrink compressed file; decode parms = b4
10195> Pool slot 0 is done. Closing.
10195> Pool slot 0: socket closed.
10202> Conn req from 192.168.4.2:60648, using pool slot 0
10203> URL = /wx/setting?name=wifi-ssid
10203> GET args = name=wifi-ssid
10206> GET 'wifi-ssid' --> ''
10211> Pool slot 0 is done. Closing.
10212> Pool slot 0: socket closed.
14471> Conn req from 192.168.4.2:60650, using pool slot 0
14472> URL = /
14474> Pool slot 0 is done. Closing.
14474> Pool slot 0: socket closed.
14502> Conn req from 192.168.4.2:60652, using pool slot 0
14503> URL = /wx/setting?name=module-name
14503> GET args = name=module-name
14505> GET 'module-name' --> 'PCB1'
14511> Pool slot 0 is done. Closing.
14512> Pool slot 0: socket closed.
14517> Conn req from 192.168.4.2:60654, using pool slot 0
14521> URL = /wx/setting?name=version
14524> GET args = name=version
14527> GET 'version' --> 'v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)'
14534> Pool slot 0 is done. Closing.
14536> Pool slot 0: socket closed.
15993> Conn req from 192.168.4.2:60656, using pool slot 0
15994> URL = /wifi/wifi.html
15995> Heatshrink compressed file; decode parms = b4
16034> Conn req from 192.168.4.2:60658, using pool slot 1
16035> URL = /wifi/style.css
16036> Heatshrink compressed file; decode parms = b4
16048> Pool slot 1 is done. Closing.
16048> Pool slot 1: socket closed.
16051> Pool slot 0 is done. Closing.
16052> Pool slot 0: socket closed.
16056> Conn req from 192.168.4.2:60660, using pool slot 0
16058> URL = /wx/setting?name=wifi-ssid
16061> GET args = name=wifi-ssid
16065> GET 'wifi-ssid' --> ''
16069> Pool slot 0 is done. Closing.
16071> Pool slot 0: socket closed.
16080> Conn req from 192.168.4.2:60662, using pool slot 0
16081> URL = /wx/setting?name=module-name
16083> GET args = name=module-name
16086> GET 'module-name' --> 'PCB1'
16091> Pool slot 0 is done. Closing.
16093> Pool slot 0: socket closed.
16097> Conn req from 192.168.4.2:60664, using pool slot 0
16102> URL = /wx/setting?name=wifi-mode
16105> GET args = name=wifi-mode
16108> GET 'wifi-mode' --> 'AP'
16112> Pool slot 0 is done. Closing.
16115> Pool slot 0: socket closed.
16119> Conn req from 192.168.4.2:60666, using pool slot 0
16124> URL = /wx/setting?name=station-ipaddr
16127> GET args = name=station-ipaddr
16130> GET 'station-ipaddr' --> '0.0.0.0'
16135> Pool slot 0 is done. Closing.
16138> Pool slot 0: socket closed.
16142> Conn req from 192.168.4.2:60668, using pool slot 0
16147> URL = /wx/setting?name=station-macaddr
16150> GET args = name=station-macaddr
16154> GET 'station-macaddr' --> 'xx:xx:xx:xx:xx:xx'
16160> Pool slot 0 is done. Closing.
16162> Pool slot 0: socket closed.
16176> Conn req from 192.168.4.2:60670, using pool slot 0
16177> URL = /wx/setting?name=softap-ipaddr
16177> GET args = name=softap-ipaddr
16180> GET 'softap-ipaddr' --> '192.168.4.1'
16185> Pool slot 0 is done. Closing.
16188> Pool slot 0: socket closed.
16192> Conn req from 192.168.4.2:60672, using pool slot 0
16196> URL = /wx/setting?name=softap-macaddr
16200> GET args = name=softap-macaddr
16203> GET 'softap-macaddr' --> 'xx:xx:xx:xx:xx:xx'
16209> Pool slot 0 is done. Closing.
16212> Pool slot 0: socket closed.
This is the olimex esp8266 module, same exact crash output it looks like.
116> Reset Pin: 13
116> RX Pullup: 0
122> DISCOVER: initialized
123> Version v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)
123> Using pin 13 for reset
124> 2MB flash: base 00100000, size 1048576
128> Flash filesystem mounted!
131> Httpd init
133>
134> Ready
135> mode : softAP(xx:xx:xx:xx:xx:xx)
139> add if1
140> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
148> bcn 100
238395> add 1
238395> aid 1
238395> station: xx:xx:xx:xx:xx:xx join, AID = 1
259860> Conn req from 192.168.4.2:60264, using pool slot 0
259861> URL = /
259864> Pool slot 0 is done. Closing.
259865> Pool slot 0: socket closed.
259870> Conn req from 192.168.4.2:60266, using pool slot 0
259872> URL = /index.html
259873> Heatshrink compressed file; decode parms = b4
259902> Pool slot 0 is done. Closing.
259902> Pool slot 0: socket closed.
260048> Conn req from 192.168.4.2:60268, using pool slot 0
260049> URL = /style.css
260050> Heatshrink compressed file; decode parms = b4
260097> Pool slot 0 is done. Closing.
260098> Pool slot 0: socket closed.
260101> Conn req from 192.168.4.2:60270, using pool slot 0
260102> URL = /logo.png
260149> Pool slot 0 is done. Closing.
260149> Pool slot 0: socket closed.
260155> Conn req from 192.168.4.2:60272, using pool slot 0
260156> URL = /wx/setting?name=module-name
260156> GET args = name=module-name
260159> GET 'module-name' --> 'PCB2'
260164> Pool slot 0 is done. Closing.
260167> Pool slot 0: socket closed.
260171> Conn req from 192.168.4.2:60274, using pool slot 0
260175> URL = /favicon.ico
260177> Heatshrink compressed file; decode parms = b4
260182> Conn req from 192.168.4.2:60276, using pool slot 1
260188> URL = /wx/setting?name=version
260190> GET args = name=version
260193> GET 'version' --> 'v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)'
260204> Pool slot 1 is done. Closing.
260205> Pool slot 1: socket closed.
260212> Pool slot 0 is done. Closing.
260213> Pool slot 0: socket closed.
261528> Conn req from 192.168.4.2:60280, using pool slot 0
261530> URL = /wifi/wifi.html
261531> Heatshrink compressed file; decode parms = b4
261564> Conn req from 192.168.4.2:60282, using pool slot 1
261565> URL = /wifi/style.css
261566> Heatshrink compressed file; decode parms = b4
261569> Conn req from 192.168.4.2:60284, using pool slot 2
261574> E:M 2056
261576> URL = /wifi/140medley.min.js
261579> Heatshrink compressed file; decode parms = b4
261583> E:M 2096
261585> Fatal exception 29(StoreProhibitedCause):
261589> epc1=0x4000df64, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 80MHz
SPI Mode : QIO
126> Reset Pin: 13
126> RX Pullup: 0
132> DISCOVER: initialized
132> Version v1.0 (2020-09-06 03:18:16 37-xxxxxxxx)
132> Using pin 13 for reset
134> 2MB flash: base 00100000, size 1048576
138> Flash filesystem mounted!
141> Httpd init
143>
143> Ready
145> mode : softAP(xx:xx:xx:xx:xx:xx)
148> add if1
150> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
157> bcn 100
274> add 1
274> aid 1
274> station: xx:xx:xx:xx:xx:xx join, AID = 1
784> Conn req from 192.168.4.2:60286, using pool slot 0
785> URL = /wifi/140medley.min.js
786> Heatshrink compressed file; decode parms = b4
804> Pool slot 0 is done. Closing.
805> Pool slot 0: socket closed.
10116> Conn req from 192.168.4.2:60288, using pool slot 0
10117> URL = /wx/setting?name=wifi-ssid
10117> GET args = name=wifi-ssid
10119> GET 'wifi-ssid' --> ''
10124> Pool slot 0 is done. Closing.
10126> Pool slot 0: socket closed.
Because i cannot get the old commit from github to build properly (wtf?)
I flashed it to the parallax WX module, and I cannot get it to crash at first boot on the wifi page no matter what I try.
The older firmware seems to choke a bit in ap mode when you join it.
121> Reset Pin: 13
121> RX Pullup: 0
127> DISCOVER: initialized
127> Version v1.0 (2020-09-03 02:47:12 29-xxxxxxxx)
127> Using pin 13 for reset
128> 4MB flash: base 00100000, size 3145728
133> Flash filesystem mounted!
136> Httpd init
137>
138> Ready
140> mode : softAP(xx:xx:xx:xx:xx:xx)
143> add if1
145> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
153> bcn 100
30819> add 1
30819> aid 1
30819> station: xx:xx:xx:xx:xx:xx join, AID = 1
75740> station: xx:xx:xx:xx:xx:xx leave, AID = 1
75740> rm 1
89843> add 1
89843> aid 1
89843> station: xx:xx:xx:xx:xx:xx join, AID = 1
134742> station: xx:xx:xx:xx:xx:xx leave, AID = 1
134742> rm 1
144825> add 1
144825> aid 1
144825> station: xx:xx:xx:xx:xx:xx join, AID = 1
170114> Conn req from 192.168.4.2:33532, using pool slot 0
170116> URL = /
170119> Pool slot 0 is done. Closing.
170119> Pool slot 0: socket closed.
170125> Conn req from 192.168.4.2:33534, using pool slot 0
170127> URL = /index.html
170128> Heatshrink compressed file; decode parms = b4
170156> Pool slot 0 is done. Closing.
170156> Pool slot 0: socket closed.
170295> Conn req from 192.168.4.2:33536, using pool slot 0
170296> URL = /style.css
170296> Heatshrink compressed file; decode parms = b4
170341> Pool slot 0 is done. Closing.
170341> Pool slot 0: socket closed.
170345> Conn req from 192.168.4.2:33538, using pool slot 0
170346> URL = /logo.png
170390> Pool slot 0 is done. Closing.
170390> Pool slot 0: socket closed.
170395> Conn req from 192.168.4.2:33540, using pool slot 0
170396> URL = /wx/setting?name=module-name
170397> GET args = name=module-name
170400> GET 'module-name' --> 'PCB1'
170405> Pool slot 0 is done. Closing.
170408> Pool slot 0: socket closed.
170411> Conn req from 192.168.4.2:33542, using pool slot 0
170416> URL = /favicon.ico
170418> Heatshrink compressed file; decode parms = b4
170423> Conn req from 192.168.4.2:33544, using pool slot 1
170429> URL = /wx/setting?name=version
170431> GET args = name=version
170434> GET 'version' --> 'v1.0 (2020-09-03 02:47:12 29-xxxxxxxx)'
170445> Pool slot 1 is done. Closing.
170446> Pool slot 1: socket closed.
170454> Pool slot 0 is done. Closing.
170454> Pool slot 0: socket closed.
171780> Conn req from 192.168.4.2:33546, using pool slot 0
171781> URL = /wifi/wifi.html
171782> Heatshrink compressed file; decode parms = b4
171813> Conn req from 192.168.4.2:33548, using pool slot 1
171815> URL = /wifi/style.css
171815> Heatshrink compressed file; decode parms = b4
171818> Conn req from 192.168.4.2:33550, using pool slot 2
171824> URL = /wifi/140medley.min.js
171827> Heatshrink compressed file; decode parms = b4
171838> Pool slot 0 is done. Closing.
171838> Pool slot 1 is done. Closing.
171838> Pool slot 0: socket closed.
171841> Pool slot 2 is done. Closing.
171845> Pool slot 1: socket closed.
171848> Pool slot 2: socket closed.
171856> Conn req from 192.168.4.2:33552, using pool slot 0
171857> URL = /wx/setting?name=wifi-ssid
171860> GET args = name=wifi-ssid
171863> GET 'wifi-ssid' --> ''
171866> Pool slot 0 is done. Closing.
171869> Pool slot 0: socket closed.
171876> Conn req from 192.168.4.2:33554, using pool slot 0
171878> URL = /wx/setting?name=module-name
171881> GET args = name=module-name
171884> GET 'module-name' --> 'PCB1'
171890> Pool slot 0 is done. Closing.
171891> Pool slot 0: socket closed.
171899> Conn req from 192.168.4.2:33556, using pool slot 0
171900> URL = /wx/setting?name=wifi-mode
171903> GET args = name=wifi-mode
171906> GET 'wifi-mode' --> 'AP'
171910> Pool slot 0 is done. Closing.
171913> Pool slot 0: socket closed.
171917> Conn req from 192.168.4.2:33558, using pool slot 0
171922> URL = /wx/setting?name=station-ipaddr
171925> GET args = name=station-ipaddr
171929> GET 'station-ipaddr' --> '0.0.0.0'
171933> Pool slot 0 is done. Closing.
171936> Pool slot 0: socket closed.
171940> Conn req from 192.168.4.2:33560, using pool slot 0
171945> URL = /wx/setting?name=station-macaddr
171948> GET args = name=station-macaddr
171952> GET 'station-macaddr' --> 'xx:xx:xx:xx:xx:xx'
171958> Pool slot 0 is done. Closing.
171961> Pool slot 0: socket closed.
171964> Conn req from 192.168.4.2:33562, using pool slot 0
171969> URL = /wx/setting?name=softap-ipaddr
171973> GET args = name=softap-ipaddr
171976> GET 'softap-ipaddr' --> '192.168.4.1'
171981> Pool slot 0 is done. Closing.
171984> Pool slot 0: socket closed.
171989> Conn req from 192.168.4.2:33564, using pool slot 0
171993> URL = /wx/setting?name=softap-macaddr
171996> GET args = name=softap-macaddr
172000> GET 'softap-macaddr' --> 'xx:xx:xx:xx:xx:xx'
172005> Pool slot 0 is done. Closing.
172008> Pool slot 0: socket closed.
I am now going to try to flash the NEW firmware with the new esptool.py instead of the old c version, to see if the new firmware still crashes.
It could be the new boot v1.7, I can try using the older 1.6 after I test with the newer esptool.py.
I have posted the new and old firmware files, with all the script / batch file and data files needed to program any esp in windows or linux in my thread.
I figured out I kinda did, I called ser.str(string("POLL")) WITHOUT a COLON. :
The module responds with a Reply: '=N,0,0'
When it should respond with a Reply: '=E,1' ?
Heres the poll command I sent in TEXT FORM.
ser.tx(254) 'Begin marker
ser.str(string("POLL")) 'Tell the module to listen to ANY protocol/path.
ser.tx(13) 'End marker
Heres the poll command in TOKEN FORM.
ser.str(string($EC)) 'Tell the module to listen to ANY protocol/path.
When in TEXT FORM, i get NO reply, but TOKEN FORM, I get a reply.
Am I doing something wrong in TEXT FORM?
CON
_CLKMODE=XTAL1 + PLL16X ' The system clock spec
_XINFREQ = 5_000_000 ' Crystal
Rx = 31 'serial in from wx device
Tx = 30 'serial out to wx device
OBJ
ser: "FullDuplexSerial.spin"
VAR
long Stack1[100]
Pub Main
cognew(Comms, @Stack1)
Pub Comms | CommandMode
ser.Start(RX, TX, 0, 115200) 'Cog #2
waitcnt(80_000_000 + cnt) 'wait 1 second fpr serial to start.
Repeat
ser.str(string(27)) 'Set ansi command mode in putty.
ser.str(string("[2J")) 'Clear putty telnet screen.
If CommandMode == 1 'Turn command mode on in spin.
ser.str(string("[2;3f")) 'Set Position in putty.
ser.str(string("Command Mode is On. ")) 'Tell putty command mode is on.
ser.str(string("[1;1f")) 'Set Position in putty to put cursor at 0
waitcnt(80_000_000 + cnt) 'wait 1 second for serial to stop.
ser.Stop 'Turn off serial to send break.
dira[TX]~~ ' Set direction to output
outa[TX]:= 0 ' Set TX low.
waitcnt(80_000_000 + cnt) 'wait 1 second for command mode to start in the module.
dira[TX]~ ' Set direction to input
waitcnt(80_000_000 + cnt) 'wait 1 second for serial to start.
ser.str(string("LISTEN:HTTP,/tpfm")) 'Tell the module to listen to a specific path on http port 80.
Repeat 5
ser.str(string("POLL")) 'Tell the module to listen to a ANY protocol/path. TEXT FORM DOESN'T WORK. Comment out to test token form.
'ser.str(string($EC)) 'Tell the module to listen to ANY protocol/path. TOKEN FORM WORKS. Uncomment to test.
ser.str(string("SET:cmd-enable,0")) 'Turn command mode off in the WX module.
CommandMode := 0 'Turn command mode off in spin.
waitcnt(80_000_000 + cnt) 'Wait for 1 s
ser.str(string("Command Mode is Off.")) 'Tell putty command mode is off. '
ser.str(string(27)) 'Set ansi command mode in putty. '
Repeat 5
CommandMode := 1 'Turn command mode on in spin.
The token and the command string shouldn't work differently. I'll take a look at this.
Another thing I thought of is that there is a "patch" program that gets used to patch the boot binary before it is put into the release folder. Is it possible that the locations that are patched needs to change when moving from boot_v1.6.bin and boot_v1.7.bin?
I was going to ask you about that "patch" and what it did, it concerned me.
You may be right because I just crashed the module again by overloading the available handlers.
I used the html code posted above (val-from-micro.html)
And the spin code above (with the correct POLL: command)
And I hit the update button, many times when the module was NOT in command mode.
89470> [89470] sscp: disconnecting 6
89472> Conn req from 192.168.4.2:55091, using pool slot 0
89493> URL = /tpfm
89493> [89493] listener: matching '/tpfm' with '/tpfm'
89493> sscp: no connections available for /tpfm request
89701> Pool slot 0 is done. Closing.
89701> Pool slot 0: socket closed.
90373> Conn req from 192.168.4.2:55092, using pool slot 0
90392> URL = /tpfm
90393> [90393] listener: matching '/tpfm' with '/tpfm'
90393> sscp: no connections available for /tpfm request
90602> Pool slot 0 is done. Closing.
90602> Pool slot 0: socket closed.
90745> Pool slot 2: socket closed.
90745> [90745] sscp: disconnecting 7
90748> Conn req from 192.168.4.2:55093, using pool slot 0
90762> URL = /tpfm
90763> [90763] listener: matching '/tpfm' with '/tpfm'
90763> sscp: no connections available for /tpfm request
90968> Pool slot 0 is done. Closing.
90968> Pool slot 0: socket closed.
91484> Conn req from 192.168.4.2:55094, using pool slot 0
91502> URL = /tpfm
91503> [91503] listener: matching '/tpfm' with '/tpfm'
91503> sscp: no connections available for /tpfm request
91517> UART break detected. Switching on SSCP command parsing.
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 80MHz
SPI Mode : QIO
129> Reset Pin: 13
129> RX Pullup: 0
135> DISCOVER: initialized
135> Version v1.0 (2020-09-06 09:20:49 40-xxxxxxxx)
136> Using pin 13 for reset
137> 2MB flash: base 00100000, size 1048576
141> Flash filesystem mounted!
144> file 0: val-from-micro.html 1408
148> Httpd init
150>
150> Ready
152> mode : softAP(xx:xx:xx:xx:xx:xx)
155> add if1
157> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
165> bcn 100
2097> add 1
2097> aid 1
2097> station: xx:xx:xx:xx:xx:xx join, AID = 1
2165> Conn req from 192.168.4.2:55105, using pool slot 0
2180> URL = /tpfm
2181> /tpfm not found. 404!
2388> Pool slot 0 is done. Closing.
2389> Pool slot 0: socket closed.
4902> Conn req from 192.168.4.2:55104, using pool slot 0
9906> Pool slot 0: socket closed.
I can't get my ESP to fail on startup on the Network page. How do you reproduce this problem again.
After power up of the module, you connect to it when its already in AP mode. (its in this mode if you freshly flash it with flash-all.sh / .bat)
Then when you visit the wifi page, the debug port will show it crashed and rebooted.
Are you compiling it yourself? Or did you use my zip?
Did you use the latest git of Parallax-ESP code?
Are you viewing the debug (DBG) (IO2) pin on the parallax ESP module?
Okay, here is what is going on with POLL. If you use "POLL:", the parser thinks that you passed one parameter after the colon which is the empty string. It converts that to an integer to form the channel mask and ends up with zero. That is why you get an "N" response, no channels with activity match the zero mask. The parser isn't very smart. I guess it could check to see if there are any digits in the argument before calling atoi. On the other hand, you should probably be able to just use "POLL" without the colon. That would result in a 0xffffffff mask which would catch activity on any channel.
That would let the code work properly in the spin examples in the obex then. (except for them all missing the break to enter command mode)
The "patch" program patches the SPI mode and speed and the flash size into the boot image. This is something that is done by esptool.py but not by esptool-ck. At least that was true of esptool.py at the time that I wrote the code.
If you have a version that skips the patch, i can test with esptool.py. Or tell me what code to comment out to make a non-patch file.
I have a dongle that I use to program the ESP module and have it connected to XCTU software which has a terminal program that allows sending packets of text or binary data to test each of the different commands.
I don't know what do tell you, i can't see what you are ACTUALLY sending to the module, i can't snoop your TX/RX, but if you hook up a prop and run my code, you will see that POLL without a colon doesn't work properly, you will get a Reply: '=N,0,0' when you setup a "LISTEN:HTTP,/tpfm" And then activate the listen with your webpage.
I just added some debug code and it looks like "POLL" and "POLL:" produce the same channel mask, 0xffffffff and hence they should behave identically. Are you not seeing that?
Geez. Im loosing my mind, now I am seeing it reply properly with 'POLL'
What led me onto this is this POLL command.
ser.str(string("POLL:HTTP,/tpfm")) 'Tell the module to listen to a specific path on http port 80.
It replies with '=N,0,0'
I was probably formatting my filter wrong? But I don't know if that wrong filter, put the module into a bug state.
And I tried that and cannot repeat it, now I see why you and iseries are not seeing it.
I also don't know if this is a bug that only shows up after the very first flash-all boot, I will try to recreate it if I can.
Poll takes a numeric argument which which is interpreted as a mask that indicates which of the connections to listen to. This command is likely interpreted as a zero mask and the alpha characters are ignored.
Yea I don't know, why i cannot recreate my issue, and I had the problem for DAYS until I formatted the POLL properly,
and THEN it still showed up with just POLL, until I used POLL: and then I cannot even recreate the issue.
I hate this. (oh but i love it)
Its like willy wonkas, "theres no way of knowing which way we are going"
I've put quite a bit of time in on this over the long holiday weekend. Unfortunately, I'm back to work tomorrow and probably won't be able to do much other than merge pull requests for a while. Is there any other serious problem that needs addressing today?
I do have 2.
The version number on the Home page of the module configuration. It always says 1.0 even with all these new changes.
And the date only reflects the compile date, so it doesn't help one to determine the version of software the module is running.
With the change to the HOSTNAME, and the addition of the ability to change what pin the RESET signal comes from on the module, those changes would merit a 2.0 or something.
And everything PAST this commit in 2020, should say 3.0? (but changing all that previous code to reflect this, isn't gonna happen?) https://github.com/parallaxinc/Parallax-ESP/tree/a5bcb63560c3be18806231ba25700cf70a0f6f3a
So wouldn't it be wise to START changing the version with all these MAJOR updates and sdk changes?
(yea yea, i know, where was i in 2016?)
If we cannot change the previous code version to reflect the changes, how can I do it for my own compiles of previous code? (what code do i change?)
2. Instructions on how to compile previous code would be nice, because when I try to checkout previous commits before the new sdk, I get a bad upload to the module, the TX light just blinks rapidly. I am doing something wrong when I change the head... is it related to the sub modules?
Maybe i need to do a 'git reset --hard <hash-or-ref>' and then git submodule init and git submodule update? I just tried to do a git reset --hard <hash-or-ref>' and then git submodule init and git submodule update, then compiled it all, and flashed the esp, and it DOES work, so I was doing it wrong by not doing a --hard.
Sounds good! I don't even know if esptool.py provides any REAL benefit over esptool-ck.
I posted this earlier in this thread, but I will repost.
The new firmware:
https://forums.parallax.com/discussion/comment/1505814/#Comment_1505814
The old firmware:
https://forums.parallax.com/discussion/comment/1505874/#Comment_1505874
This should make it easy for users to test both.
ser.tx(254) 'Begin marker ser.str(string("POLL")) 'Tell the module to listen to ANY protocol/path. ser.tx(13) 'End markerHeres the poll command in TOKEN FORM.
You can use the html HERE to prove it. (upload this html to your ParallaxWX module --> https://github.com/parallaxinc/propeller/blob/master/libraries/community/p1/All/WX ESP8266 SPIN Get Started/val-from-micro.html
Heres the full prop code in TEXT FORM
CON _CLKMODE=XTAL1 + PLL16X ' The system clock spec _XINFREQ = 5_000_000 ' Crystal Rx = 31 'serial in from wx device Tx = 30 'serial out to wx device OBJ ser: "FullDuplexSerial.spin" VAR long Stack1[100] Pub Main cognew(Comms, @Stack1) Pub Comms | CommandMode ser.Start(RX, TX, 0, 115200) 'Cog #2 waitcnt(80_000_000 + cnt) 'wait 1 second fpr serial to start. Repeat ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[2J")) 'Clear putty telnet screen. If CommandMode == 1 'Turn command mode on in spin. ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[2;3f")) 'Set Position in putty. ser.str(string("Command Mode is On. ")) 'Tell putty command mode is on. ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[1;1f")) 'Set Position in putty to put cursor at 0 waitcnt(80_000_000 + cnt) 'wait 1 second for serial to stop. ser.Stop 'Turn off serial to send break. dira[TX]~~ ' Set direction to output outa[TX]:= 0 ' Set TX low. waitcnt(80_000_000 + cnt) 'wait 1 second for command mode to start in the module. dira[TX]~ ' Set direction to input ser.Start(RX, TX, 0, 115200) 'Cog #2 waitcnt(80_000_000 + cnt) 'wait 1 second for serial to start. ser.tx(254) 'Begin marker ser.str(string("LISTEN:HTTP,/tpfm")) 'Tell the module to listen to a specific path on http port 80. ser.tx(13) 'End marker waitcnt(80_000_000 + cnt) 'wait 1 second Repeat 5 ser.tx(254) 'Begin marker ser.str(string("POLL")) 'Tell the module to listen to a ANY protocol/path. TEXT FORM DOESN'T WORK. Comment out to test token form. 'ser.str(string($EC)) 'Tell the module to listen to ANY protocol/path. TOKEN FORM WORKS. Uncomment to test. ser.tx(13) 'End marker waitcnt(80_000_000 + cnt) 'wait 1 second ser.tx(254) 'Begin marker ser.str(string("SET:cmd-enable,0")) 'Turn command mode off in the WX module. ser.tx(13) 'End marker CommandMode := 0 'Turn command mode off in spin. waitcnt(80_000_000 + cnt) 'Wait for 1 s ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[2;3f")) 'Set Position in putty. ser.str(string("Command Mode is Off.")) 'Tell putty command mode is off. ' ser.str(string(27)) 'Set ansi command mode in putty. ' ser.str(string("[1;1f")) 'Set Position in putty to put cursor at 0 Repeat 5 waitcnt(80_000_000 + cnt) 'Wait for 1 s CommandMode := 1 'Turn command mode on in spin.ALL of the example code located here: https://github.com/parallaxinc/propeller/tree/master/libraries/community/p1/All/WX ESP8266 SPIN Get Started
Has POLL with no COLON, thus FAILS.
DO YOUR PART!
What prop code are you using?
If you are using something connected directly to the module (like a PropPlug) and issuing serial terminal commands, how are you entering Command Mode?
ser.tx(254) 'Begin marker ser.str(string("POLL:HTTP,/tpfm")) 'Tell the module to listen to a specific path on http port 80. ser.tx(13) 'End markerIt replies with '=N,0,0'I was probably formatting my filter wrong? But I don't know if that wrong filter, put the module into a bug state.
Oh well, on ward!
About that patch....
ser.str(string("POLL:HTTP,/tpfm")) 'Tell the module to listen to a specific path on http port 80.and THEN it still showed up with just POLL, until I used POLL: and then I cannot even recreate the issue.
I put them back in and it works now.
I haven't even gotten around to using UDP for anything ... YET.. So I didn't test this functionality.
I do have 2.
So everything PAST this commit in 2016, should say 2.0? (but changing all that previous code to reflect this, isn't gonna happen?)
https://github.com/parallaxinc/Parallax-ESP/tree/d8c785eb616226c809348c2a892d071fd27cb952
