I guess the next question is whether the firmware still works with this modified code. One thing that I saw in the changes from iseries was an increase in a buffer size. I recall that there were RAM constraints when we first wrote this code which is one reason we didn't just use the Arduino ESP libraries. I assume this buffer size change has not broken wifi downloads?
By wifi downloads, do you mean to the prop chip? Or uploading a html file? Or uploading a new OTA file?
I have done them all and they all work, but I HAVE NOT bulk filled a .spin file yet so it uses all the RAM space of a propeller chip and tested that, I will do that asap.
If you want to use the c version of esptool, i can test it and see if anything needs to be changed (other than the filename) with the original flash-all.sh
The c version of esptool seems to work ok with your original flash-all.sh file (with the new file name change)
I am testing the module now.
/Parallax-ESP/release/release$ ./flash-all.sh
Using port /dev/ttyUSB0
Uploading 4080 bytes from boot_v1.7.bin to flash at 0x00000000
.... [ 100% ]
Uploading 324164 bytes from httpd.user1.bin to flash at 0x00001000
................................................................................ [ 25% ]
................................................................................ [ 50% ]
................................................................................ [ 75% ]
............................................................................. [ 100% ]
Uploading 4096 bytes from blank.bin to flash at 0x0007E000
.... [ 100% ]
Uploading 4096 bytes from blank.bin to flash at 0x0007F000
.... [ 100% ]
Uploading 128 bytes from esp_init_data_default_v08.bin to flash at 0x001FC000
. [ 100% ]
Uploading 4096 bytes from blank.bin to flash at 0x001FE000
.... [ 100% ]
Uploading 4096 bytes from blank.bin to flash at 0x001FA000
.... [ 100% ]
Uploading 4096 bytes from blank.bin to flash at 0x00100000
.... [ 100% ]
Maybe I should add esptool-ck as a submodule under Parallax-ESP.
Not a bad idea, I had a hard time figuring this out at first because I couldn't find the c version.
I could only find the python version of esptool. Thats why I re-did all the flash-all.sh code.
The c version doesn't show up in google searches easily.
The python version just has more utilities, like to find the flash chip size.
./esptool.py flash_id
I suppose the only benefit to that is you can auto get the flash size on the esp.
But they should be using the Parallax module with 4mb
I pushed the flash script changes. I'll look into adding esptool-ck next. It is unfortunate that they chose the same name as the Python tool since the command line arguments are completely different.
I added esptool-ck as a submodule under Parallax-ESP but I still haven't incorporated it into the build process. At present, the user will have to build it separately and put it in his/her executable path before running the flash scripts.
I think I should figure out how to get esptool.py working on my Ubuntu system and use that instead of esptool-ck. It sounds like Parallax uses the Python version for factory programming the WX modules.
I got my USB2serial ports working with Ubuntu running under VirtualBox on my Mac. Now I just need to get a working flash script...
Sorry, i was doing some garden work, laying new bricks in the greenhouse. Gotta get away from the screen once in a while.
Heres the esptool.py working script. It DOES NOT check the file system size, it just requires the user to do it.
I do not know how to query for the size and store it in a variable to check it in a bash script, i am not that smart.
I could try to do it by searching the nets. The flash size is 4MB, I think your old c version used 2mb (the python version is case sensitive)
# File name: /Parallax-Esp/release/release/flash-all.sh
# This uses esptool.py
# flash the firmware
# and clear out all settings and the user flash filesystem
PORT=/dev/ttyUSB0
if [ ! -z $1 ]
then
PORT=$1
fi
echo Using port $PORT
BAUD=115200
FLASH_SIZE=4MB # 16MB, detect, 256KB, 2MB-c1, 8MB, 2MB, 4MB, 512KB, 1MB, 4MB-c1
FLASH_BLOCK_SIZE=1024
FLASH_SPEED=80m # keep,40m,26m,20m,80m
FLASH_INTERFACE=qio # keep,qio,qout,dio,dout
BOOT_LOADER=0x000000
USER1_IMAGE=0x001000
USER_SETTINGS1=0x07E000
USER_SETTINGS2=0x07F000
if [ $FLASH_SIZE = 1MB ]; then
WIFI_SETTINGS1=0x0FC000
WIFI_SETTINGS2=0x0FE000
WIFI_SETTINGS3=0x0FA000
elif [ $FLASH_SIZE = 2MB ]; then
WIFI_SETTINGS1=0x1FC000
WIFI_SETTINGS2=0x1FE000
WIFI_SETTINGS3=0x1FA000
elif [ $FLASH_SIZE = 4MB ]; then
WIFI_SETTINGS1=0x3FC000
WIFI_SETTINGS2=0x3FE000
WIFI_SETTINGS3=0x3FA000
else
echo Unsupported flash size $FLASH_SIZE
exit 1
fi
#flash filesystem base
FFS_BASE=0x100000
./esptool.py \
--port $PORT \
--baud $BAUD \
write_flash \
--flash_freq $FLASH_SPEED \
--flash_mode $FLASH_INTERFACE \
--flash_size $FLASH_SIZE \
--verify \
--compress \
$BOOT_LOADER boot_v1.7.bin \
$USER1_IMAGE httpd.user1.bin \
$USER_SETTINGS1 blank.bin \
$USER_SETTINGS2 blank.bin \
$WIFI_SETTINGS1 esp_init_data_default_v08.bin \
$WIFI_SETTINGS2 blank.bin \
$WIFI_SETTINGS3 blank.bin \
$FFS_BASE blank.bin
The C version is good for windows users? then all they would need is the RELEASE folder? I might be wrong, i think.
(i guess? can win users run .sh scripts?)
Actually i guess windows users would need a .BAT version of the script.
I could write that also.
I suppose im presenting too many options, go which ever way to feel is best, I will support what you choose.
Scripts for all versions of esptool and esptool-ck can be made also, we already have the .sh version for both in this thread.
A .BAT file version for the esptool-ck.exe (win32) (in their releases folder) would be simple to make.
I grew up on DOS.
I guess multiple versions could be made and put the entire /Parallax-Esp/release/release folder on github under https://github.com/parallaxinc/Parallax-ESP/releases/
Then they could still flash a bricked/any esp module without needing linux/raspberrypi/mac.[/b]
Attached, are all the WINDOWS files needed to flash any ESP8266 (with at least 1MB flash on it) to the ParallaxWX code, the latest compile as of SEPT-05-2020
The .OTA file is included also for updating the firmware over the AIR. (OTA updating, this requires at least a 2MB flash)
Here is the windows Flash-all.bat script.
@echo off
ECHO Filename: Flash-all.bat
ECHO THIS WILL Flash the firmware and clear out all settings and the user flash filesystem.
ECHO IT LOOKS ON COM1 FOR THE ESP. YOU MUST SET YOUR COM PORT FOR THE PROPPLUG IN THE DEVICE MANAGER, OR IN THIS FILE TO MATCH.
ECHO THIS BATCH WILL ATTEMPT TO SET THE PORT SPEED. YOU MAY NEED TO SET THE COM PORT SPEED SETTING IN THE DEVICE MANAGER TO THE SAME IN THIS FILE 115200.
ECHO SET YOUR FLASH SIZE TO EITHER 1M, 2M or 4M, IT IS CURRENTLY SET AS 2M.
ECHO TO STOP Press CTRL-C, Then Answer with a CAPITAL Y, Otherwise press any key to continue.
PAUSE
set PORT=COM1
set BAUD=115200
REM Currently supported methods are: none, ck, nodemcu, wifio.
set BOARD=none
REM <512K|256K|1M|2M|4M|8M|16M|32M>
set FLASH_SIZE=2M
REM <40|26|20|80>
set FLASH_SPEED=80
REM <qio|qout|dio|dout>
set FLASH_INTERFACE=qio
set FLASH_BLOCK_SIZE=1024
set BOOT_LOADER=0x000000
set USER1_IMAGE=0x001000
set USER_SETTINGS1=0x07E000
set USER_SETTINGS2=0x07F000
REM Flash filesystem base
set FFS_BASE=0x100000
if %FLASH_SIZE%==1M goto :Flash1M
if %FLASH_SIZE%==2M goto :Flash2M
if %FLASH_SIZE%==4M goto :Flash4M
if %FLASH_SIZE%==8M goto :Flash8M
if %FLASH_SIZE%==16M goto :Flash16M
if %FLASH_SIZE%==32M goto :Flash32M
:Flash1M
set WIFI_SETTINGS1=0x0FC000
set WIFI_SETTINGS2=0x0FE000
set WIFI_SETTINGS3=0x0FA000
goto Go
:Flash2M
set WIFI_SETTINGS1=0x1FC000
set WIFI_SETTINGS2=0x1FE000
set WIFI_SETTINGS3=0x1FA000
goto Go
:Flash4M
set WIFI_SETTINGS1=0x3FC000
set WIFI_SETTINGS2=0x3FE000
set WIFI_SETTINGS3=0x3FA000
goto Go
:Flash8M
echo Unsupported flash size! %FLASH_SIZE% exit 1
:Flash16M
:Flash32M
:Go
set tt0=-v
set tt1=-cp %PORT%
set tt2=-cd %BOARD%
set tt3=-cb %BAUD%
set tt4=-bz %FLASH_SIZE%
set tt5=-bf %FLASH_SPEED%
set tt6=-bm %FLASH_INTERFACE%
set tt7=-ca %BOOT_LOADER%
set tt8=-cf boot_v1.7.bin
set tt9=-ca %USER1_IMAGE%
set tt10=-cf httpd.user1.bin
set tt11=-ca %USER_SETTINGS1%
set tt12=-cf blank.bin
set tt13=-ca %USER_SETTINGS2%
set tt14=-cf blank.bin
set tt15=-ca %WIFI_SETTINGS1%
set tt16=-cf esp_init_data_default_v08.bin
set tt17=-ca %WIFI_SETTINGS2%
set tt18=-cf blank.bin
set tt19=-ca %WIFI_SETTINGS3%
set tt20=-cf blank.bin
set tt21=-ca %FFS_BASE%
set tt22=-cf blank.bin
Mode Com1: Baud=%BAUD% Parity=N Data=8 Stop=1
call esptool.exe %tt0% %tt1% %tt2% %tt3% %tt4% %tt5% %tt6% %tt7% %tt8% %tt9% %tt10% %tt11% %tt12% %tt13% %tt14% %tt15% %tt16% %tt17% %tt18% %tt19% %tt20% %tt21% %tt22%
PAUSE
I must say, this new firmware seems like the WX config pages load MUCH faster.
I haven't found ANY bugs YET.
The test I have done so far:
I do telnet to putty connections.
I do uploads of html pages.
I do uploads of spin prop programs.
I do uploads of .OTA files.
I do uploads of C prop programs that talk to the esp using the SSCP command parsing. (webpage test) https://learn.parallax.com/tutorials/language/propeller-c/parallax-wx-wi-fi-module-prop-c/page-requests-info-propeller
I did these tests while a PropPlug was connected to the DBG (debug) port of the WX module to see any errors, none so far.
I have NOT tried to fill the FLASH SPACE (file system) of the ESP using the upload webpage. (someone should do that)
I have tested the new firmware for the WX module with a program that fills 7,905 longs.
When I compiled it in PROPTOOL, it said I can fit 7,909 longs.
But with my TELNET demo program, anything more than 7,905 and the prop won't run.
I don't know if this means the firmware is bugged, but 4 longs short of what the proptool says I can upload.
Is that just because of my program, you'd think proptool would see that...
I don't think being 4 longs short is a big deal, is this a bug in the WX firmware?
I haven't tried to download this program with the PropPlug to test if it does the same, I supposed I could.
I did this ram space fill (7,905) on the prop while a PropPlug was connected to the DBG (debug) port of the WX module to see any errors, none so far.
''* Telnet Wireless WX Ansi Command Demo and RAM space filler *
''* Author: Clock Loop @ parallax forums *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
CON
Tx = 30 'serial out to wx device
Rx = 31 'serial in from wx device
OBJ
Term : "FullDuplexSerial"
VAR
long FillIt[7905]
Pub Port23Display | Years, Dayz, Hour, Mnit
Years := 13
Dayz := 6
Hour := 3
Mnit := 45
term.start(Rx, Tx, 0, 115_200) '1cog start telnet terminal
waitcnt(80_000_000 + cnt)
term.str(string(27)) 'Set command mode
term.str(string("[2J")) 'Clear telnet screen
term.str(string("[1;1f")) 'Set Position
term.str(string("[0m")) 'Turn off character attributes
'--------------SOME ANSI COMMAND CODE INFO---------
'term.str(string(27)) 'Set command mode
'term.str(string("[2J")) 'clear screen
'term.str(string("[0m")) 'Turn off character attributes
'term.str(string("[1m")) 'Turn bold mode on
'term.str(string("[2m")) 'Turn low intensity mode on
'term.str(string("[4m")) 'Turn underline mode on
'term.str(string("[5m")) 'Turn blinking mode on
'term.str(string("[7m")) 'Turn reverse video on
'term.str(string("[8m")) 'Turn invisible text mode on
'term.str(string("#3")) 'Double-height letters, top half
Esc#3 Double-height letters, top half DECDHL
Esc#4 Double-height letters, bottom half DECDHL
Esc#5 Single width, single height letters DECSWL
Esc#6 Double width, single height letters DECDWL
Repeat
term.str(string("[5;5f")) 'Set Position
term.str(string("[31m")) 'Red color text
term.str(string("UpTime : "))
term.dec(Years)
term.str(string(":Years "))
term.dec(Dayz)
term.str(string(":Days "))
term.dec(Hour)
term.str(string(":Hours "))
term.dec(Mnit)
term.str(string(":Min "))
Dat
Terms of Use: MIT License
Permission is hereby granted, free of charge, to any person obtaining a copy of this
software and associated documentation files (the "Software"), to deal in the Software
without restriction, including without limitation the rights to use, copy, modify,
merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be included in all copies
or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Thanks!
The reason we used 2MB is that the original Parallax WX modules had only 2MB of flash and using 2MB allowed the firmware to work on all modules. I'm not sure if any 2MB modules were ever sold though. They might have just been the prototypes we were using while developing the product.
@"Clock Loop" I tried your new flash script with mixed results. First, I had to change "./esptool.py" to "esptool" because Ubuntu installed the python script in /usr/local/bin with the name "esptool" without the ".py". Second, I had to remove the --compress option because my ESP8266 board doesn't support that apparently. I have to admit that the board I'm using at the moment is not the Parallax WX module so maybe --compress isn't a problem with that module. I'm wondering if we should include esptool.py with the WX firmware release or if we should just assume that the user has it already installed?
It also needs the flash-all.sh file to be fixed for the new files.
And the same is probably true for all the other .sh files.
Apparently I fixed my copy and forgot I did this when I fixed the Makefile...
I think so, I am re-running git for the repo and see what you changed now.
You are fast.
Ok, the Makefile looks great!
No, apparently I changed it a lot to make it all work.
Sorry all this re- downloading of the repo wiped out my git diff of the flash-all.sh when I ran it for the Makefile.
Or should esptool get installed into their executable folder?
Or you can refer to it if they GIT it in the same folder as Parallax-Esp.
Heres the git diff of flash-all.sh when I used esptool c version and kept it in its git folder beside Parallax-esp
I grew up on DOS.
Do what you feel is best!
How to connect a PROPPLUG to the ESP. Purchase a PropPlug to flash an ESP8266 --> https://www.parallax.com/product/32201
And purchase a Parallax WX ESP8266 WiFi Module - SIP --> https://www.parallax.com/product/32420s
SUPPORT PARALLAX, DON'T BE A LEECH! (lol)
PGM (IO0) must be tied to GROUND BEFORE POWER ON.
''******************************************* ''* Telnet Wireless WX Ansi Command Demo and RAM space filler * ''* Author: Clock Loop @ parallax forums * ''******************************************* CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CON Tx = 30 'serial out to wx device Rx = 31 'serial in from wx device OBJ Term : "FullDuplexSerial" VAR long FillIt[7905] Pub Port23Display | Years, Dayz, Hour, Mnit Years := 13 Dayz := 6 Hour := 3 Mnit := 45 term.start(Rx, Tx, 0, 115_200) '1cog start telnet terminal waitcnt(80_000_000 + cnt) term.str(string(27)) 'Set command mode term.str(string("[2J")) 'Clear telnet screen term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("[0m")) 'Turn off character attributes '--------------SOME ANSI COMMAND CODE INFO--------- 'term.str(string(27)) 'Set command mode 'term.str(string("[2J")) 'clear screen 'term.str(string(27)) 'Set command mode 'term.str(string("[0m")) 'Turn off character attributes 'term.str(string("[1m")) 'Turn bold mode on 'term.str(string("[2m")) 'Turn low intensity mode on 'term.str(string("[4m")) 'Turn underline mode on 'term.str(string("[5m")) 'Turn blinking mode on 'term.str(string("[7m")) 'Turn reverse video on 'term.str(string("[8m")) 'Turn invisible text mode on 'term.str(string("#3")) 'Double-height letters, top half { Esc#3 Double-height letters, top half DECDHL Esc#4 Double-height letters, bottom half DECDHL Esc#5 Single width, single height letters DECSWL Esc#6 Double width, single height letters DECDWL } Repeat term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position waitcnt(80_000_000 + cnt) term.str(string(27)) 'Set command mode term.str(string("[5;5f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("[31m")) 'Red color text term.str(string("UpTime : ")) term.dec(Years) term.str(string(":Years ")) term.dec(Dayz) term.str(string(":Days ")) term.dec(Hour) term.str(string(":Hours ")) term.dec(Mnit) term.str(string(":Min ")) Dat {{ Terms of Use: MIT License Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. }}
