libesphttpd project needs to be updated with the new espmissingincludes.h.
ESP8266_NONOS_SDK is linked to the wrong version. It should be 9960ef3 and not 3fe474e.
Thanks! I've already done those two things although I haven't committed the new espmissingincludes.h file to the libesphttpd repository yet. Maybe I should just switch to Linux to get this problem resolved in the Parallax Github repository and then try to get the build working on my Mac as a separate step.
I'm trying to setup eep-open-sdk under Ubuntu and I get this error while trying to run make:
checking for bash >= 3.1... no
configure: error: could not find bash >= 3.1
make[1]: *** [../Makefile:149: _ct-ng] Error 1
make[1]: Leaving directory '/home/dbetz/esp-open-sdk/crosstool-NG'
make: *** [Makefile:145: crosstool-NG/ct-ng] Error 2
But I'm running bash version 5.0.17.
dbetz@dbetz-VirtualBox:~/esp-open-sdk$ bash --version
GNU bash, version 5.0.17(1)-release (x86_64-pc-linux-gnu)
Copyright (C) 2019 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software; you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Actually, esp-open-sdk hasn't been updated in at least three years. I think it would be better to figure out how to build this with current tools from Espressif.
I think even though the project hasn't been update in three years it uses a link to the espressif tools on there site so it should have download the current version. Now how it does that may be an issue.
Also, it failed to build on my system due to an error that seems like a problem in the configure script.
Okay, I got past that problem by editing crosstools-NG/configure.ac to allow bash versions beginning with "5".
I covered that bug in my thread.
I forgot to mention it, I suppose it should be fixed too!
Okay, I got everything to build except that I get this warning. Is this to be expected?
cc -o mkupgimg mkupgimg.c
mkupgimg.c: In function ‘main’:
mkupgimg.c:93:19: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long unsigned int’ [-Wformat=]
93 | printf("Header: %d bytes, user1: %d bytes, user2: %d bytes.\n", sizeof(hdr), (int)l1, (int)l2);
| int long unsigned int
| %ld
| %ld
| %ld
I didn't get that error.
Since it's only a warning it only happens the first time you run the makefile when it needs to build mkupgimg. If you do a "make clean" followed by "make" to you get it? Or maybe it has something to do with the version of GCC I'm using being more picky than what you're using.
I have run make clean, then make like 10 times, due to my own testing of the new /Parallax-Esp/release/Makefile
So thats probably not it.
Heres my gcc version
gcc version 8.3.0 (Debian 8.3.0-6)
I have
gcc (Ubuntu 9.3.0-10ubuntu2) 9.3.0
I just committed the updated version of espmissingincludes.h to the libesphttpd project and updated the pointer to it in the Parallax-ESP project. I think it should build now.
I also updated the README.md file with instructions to checkout the correct version of the ESP SDK. It would be nice if that happened automatically but I'm not sure how to do that.
The README, needs to tell the user to GIT the esptool in the same directory as Parallax-Esp.
Parallax used to use a C version of this tool because the Python version had some deficiency that I can't recall. Are you sure the current python tool works correctly for this firmware?
Also, what does the _v08 version of esp_init_data_default do that the original didn't?
I do not know the difference, I just know the original is missing now that we changed to ESP8266_NONOS_SDK
Because its located here: /Parallax-ESP/ESP8266_NONOS_SDK/bin/esp_init_data_default_v08.bin
IF you leave it as it was, the Makefile will not work.
You can refer to the release note about the bootloader update.
https://github.com/espressif/ESP8266_NONOS_SDK/releases
It is always suggested that using the latest SDK with the latest bootloader.
Thanks for your interest in ESP8266!
It looks like this is no longer needed, you fixed it in the repo.
ESP8266_NONOS_SDK @ 9960ef3
NICE!
Yes, that does seem to be true. I'll get rid of it in the README.md file next time I push changes.
@iseries You wanna push the fixes to github?
And the entire Release folder that contains the files needed to run flash-all.sh (linux) or flash-all.bat (windows)
http://forums.parallax.com/discussion/comment/1505814/#Comment_1505814
The fix: https://github.com/pfalcon/esp-open-sdk/issues/365
cc -o mkupgimg mkupgimg.c mkupgimg.c: In function ‘main’: mkupgimg.c:93:19: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long unsigned int’ [-Wformat=] 93 | printf("Header: %d bytes, user1: %d bytes, user2: %d bytes.\n", sizeof(hdr), (int)l1, (int)l2); | ~^ ~~~~~~~~~~~ | | | | int long unsigned int | %ldI didn't get that error.
http://forums.parallax.com/discussion/comment/1505463/#Comment_1505463
https://github.com/parallaxinc/Parallax-ESP/blob/master/release/Makefile
LOL, I need to learn how to do that.
That's if I can find my github login/pass.
Excellent!
Ok, trying it now.
/Parallax-ESP/release$ git diff diff --git a/release/Makefile b/release/Makefile index a8610fe..df51c13 100644 --- a/release/Makefile +++ b/release/Makefile @@ -1,5 +1,8 @@ #SDK=../../esp_iot_sdk_v1.5.2 -SDK=../esp_iot_sdk_v2.0.0.p1 +#SDK=../esp_iot_sdk_v2.0.0.p1 +SDK=../ESP8266_NONOS_SDK +ESPTOOL=../../esptool + ZIP=parallax-esp-$(shell date "+%Y-%m-%d-%H%M").zip $(info ZIP $(ZIP)) @@ -9,10 +12,12 @@ release/httpd.user1.bin \ release/httpd.user2.bin \ release/Parallax-ESP.ota \ release/blank.bin \ -release/esp_init_data_default.bin +release/esp_init_data_default_v08.bin \ +release/esptool.py #IMAGES+=release/boot_v1.5.bin -IMAGES+=release/boot_v1.6.bin +#IMAGES+=release/boot_v1.6.bin +IMAGES+=release/boot_v1.7.bin CP=cp @@ -46,7 +51,11 @@ release/Parallax-ESP.ota: ../build/httpd.ota release/blank.bin: $(SDK)/bin/blank.bin $(CP) $< $@ -release/esp_init_data_default.bin: $(SDK)/bin/esp_init_data_default.bin +#release/esp_init_data_default.bin: $(SDK)/bin/esp_init_data_default.bin +release/esp_init_data_default_v08.bin: $(SDK)/bin/esp_init_data_default_v08.bin + $(CP) $< $@ + +release/esptool.py: $(ESPTOOL)/esptool.py $(CP) $< $@ release:The README, needs to tell the user to GIT the esptool in the same directory as the Parallax-Esp folder.
I have tested it, it fully flashes the module, and it works properly.
Heres the test results --> http://forums.parallax.com/discussion/comment/1505464/#Comment_1505464
I did not know a c version existed..
I just git this repo.
Do you know where the c version is located? I can try that also.
boot_v1.6.bin
and
boot_v1.7.bin
Esspressif says use the latest version, FROM THEM.
https://bbs.espressif.com/viewtopic.php?t=4730
NICE!
