Scribbler S3 - Can not set port COM9's options - DTR: false
As written in another topic, my school purchased a couple S3's to try out, and they arrived today after only 3 days!
Unfortunately I do have two issues when trying to program them through BlocklyProp (Solo). Both issues seem to have something to do with failing communication between my computers and S3's.
Issue 1: Unable to upload programs
The first time I upload a program to S3, the upload is successful and the program runs.
But, after that the upload fails with below messages. Reinserting the USB-cable is sometimes helping, but it's a hit or miss.
Issue 2: Terminal screen empty
When the program sometimes uploads correctly, the terminal window is empty even if my program should output a text there. The only block I have is a "Terminal send text", see attachment. The C-code produced is below. Only once I've been able to see text in the terminal window.
Other blocks are working though.
Same issues on two different computers and with both S3's, using Chrome (version 84.0.4147.135 (Official Build) (64-bit) on Win10.
Compile... Succeeded.
Download...Failed!
-------- loader messages --------
Scanning port COM9
Error: Download failed!
Added screenshot from BlocklyProp Launcher with verbose outputIssue 2: Terminal screen empty
// ------ Libraries and Definitions ------
#include "simpletools.h"
#include "s3.h"
// ------ Main Program ------
int main() {
s3_setup();pause(100);
simpleterm_reopen(31,30,0,9600);
print("Hello world, S3 calling...!");
Have also mailed Parallax support to hopefully experience same great support as I've seen others receive, but not heard anything yet from them, not easy to call them with 10 hours time difference.
In the meantime, I've continued troubleshooting myself.
Tried SimpleIde:
Issue 1: Repetitively downloading and running the same program in SimpleIde is working ok
Issue 2: I need to change the terminal window baud value to 9600 to see anything in it.
Is it possible to change the terminal window baud value through BlocklyProp Solo?
Reinserting the USB-cable in the computer seems to solve Issue 1 as a workaround, but we can't really use the S3's as intended with this, it feels shaky and unprofessional.
You will get great support from Parallax - they are limited a bit now by some folks working from home.
Let's keep at this until we get you working!
@Whit, thx for jumping in!
Updated the USB drivers now, unfortunately did not help. Also restarted my computer, just in case.
Also tried to use https://solo.parallax.com/ directly, instead of clicking the blue "BlocklyProp Solo" button in the launcher. Same issues.
When using the old, to be depreciated, BlocklyProp site, everything works ok.
I've attached a screenshot from the log.
Right before the error message "...DTR: false..." is thrown (Issue 1), a reset signal is generated. Is the reset perhaps not successful?
The text "Connected terminal to COM9 at 115200 baud" might be the reason for why nothing is printed in the terminal window (Issue 2) as the C-code clearly shows the S3 is trying to communicate at 9600 baud. This goes hand in hand with my findings running from SimpleIde.
Edit: When using https://solo.parallax.com/ directly, and by using the Inspect option in Chrome, I tried to find traces from the communication between BlocklyProp and S3. The console gives some information, but less than the BlocklyProp launcher gives. Don't know if the lower communication details are available in Chrome for troubleshooting.
---------------------------------------------------------------------------------- [23/08/2020 15:07:24] 753 IRP_MJ_DEVICE_CONTROL - Request operates a serial port (COM9) STATUS_CANCELLED IOCTL_SERIAL_CLR_DTR - Request clears the DTR control signal. ----------------------------------------------------------------------------------
Issue 1 not happening, i.e. repetitively uploading programs from BlocklyProp is working alright
Issue 2, i.e. terminal window empty, is only happening the first time after launching BlocklyProp, next times the expected text is shown.
So, at least in my case, S3's are behaving differently than a PAB when using BlocklyProp Solo.
I think the problem with seeing the output message may be because you need a delay after starting the serial routine and sending the message. Try repeating the message and you will see if this is the problem - you will overrun the pc output but you will see data.
I've seen this happen on occasion with user's computers but have been unable to duplicate it to solve it. Thanks for all the info you've provided in this thread... I will review now. Perhaps it's happening with S3s a lot (I've been using Propeller Activity Boards)"
That definitely seems like Solo is requesting the wrong baud rate for the terminal. I'll look into this today.
Strangely, we do not seem to have your messages in our support system.
Issue 1: Good news, and that's what I'd expect to see too... the problem seems to be with our Chrome-based access to the serial port with BlocklyProp Launcher.
Issue 2: No, Solo should automatically open it at 9600 baud. This is probably an oversight when we rewrote the system. Will review.
Please elaborate... what does "everything works ok" mean? No download problems, even after multiple attempts (with same S3, Cable, Computer)?
Yes, likely the reset signal failed to generate because the error is indicating that the operating system told it that it could not set the DTR signal to false. I've been unable to duplicate this reliably and have only seen a couple users with this problem (sometimes it's constant, sometimes infrequent).
The Inspect options on solo.parallax.com shows you the messages from the solo site, but the download details are occuring from the BlocklyProp Launcher app itself, whose Inspect feature in unavailable; it's the reason why we created the Verbose Logging mode in the Launcher itself. Thanks for posting screenshots of those messages.
Can you post a link to that tool? It may be helpful to me to diagnose; for example the STATUS_CANCELLED message is very curious.
This is very curious and gives me great insight. The S3 uses slightly different serial circuitry... I'm going to have to check the signals to see what the difference is.
No download problems, same S3, cable and computer.
I apologize for the problem. Not sure if this is something we missed in updates on our side or something that occured due to changes in Chrome. The latter is very likely.
I'm remote from the office, but I will retrieve an S3, hook up logic/scope and see if I can find what's happening.
Here's the link: https://www.com-port-monitoring.com/
Btw, thx for chiming in Jeff! FWIW, the e-mails I've sent last Thursday, Friday and today, went to support@parallax.com. No indication of that the e-mails wouldn't have been sent ok
We're receiving other support emails, but I'll do a test to check our system.
Is that a possibility? E-mail me at kgracey@parallax.com if it is, else we'll continue to work through this on the forums.
Sure, I'll shoot you an e-mail
so Ken, what else you speak?
You're an experienced Parallax customer and can work through the problems, thankfully. Imagine if you were a first-time middle school robotics teacher. We would have failed miserably in their eyes!
I know Jeff will solve this problem in due course, like he has with all other technical issues he's handled through the years. The benefits will extend to all of our customers.
Thanks for your patience.
Sincerely, Ken Gracey
Great news so far!
What answer did you guys come up with? I am having the same issue with Propeller Activity Boards. My first download works fine then I only get the DTR false messages after that.
