MicroPython zoom meeting...
Cluso99
in Propeller 2
Great presentation guys!
A couple of things that came out of todays meetup...
The debug cog displaying on VGA - could you release the code please. I expect we can expand upon this nicely
The pasm editor - again could you release the code please. We can make a pasm/spin version too
Since you are currently thinking about a filesystem in flash, maybe later SD, how about adopting @ersmith approach to smooth out the boundaries and allow SD access and HOST access seamlessly with his interesting host file system provided by the P2load Terminal, basically the serial stream gets double used to provide file access.
I have not looked at the protocol itself, but hell yes this is absolutely cool to access the SD card or the HOST file system with almost the same code.
Now add your flash file system. Or, start with that and keep in mind to add SD and Plan9 later. Just try to use the opportunity to make it compatible, since you are building it now new anyways...
I am very impressed with what you have done so far and I will give you now all a physically thumps down so it will be a thump up down under.
It is already indeed possible to achieve some basic integration via the method that Eric first implemented and I had used way back in January for spawning COGs from encoded hex strings than contain the PASM code. That part wasn't shown today in Brian's demos, but back then I managed to get my own PASM video driver COG spawned from MicroPython using this approach and then controlled via Python variables that are mapped to it's display and region list area. This is nice as it is fully interactive from Python and you can reconfigure video display interactively on the fly. That's at least one way it can be done already, but you need to code your PASM in a way that makes use of structures that Python can negotiate via its startup parameter area.
Here's the thread link to the way it was done. That particular work was initially tested by using Eric's RISC-V version, but the COG spawning capability was also later ported into the native version after that. It works out okay, though it does use some extra heap overhead for initial string manipulation IIRC, hopefully it should be garbage collected later at some point.
https://forums.parallax.com/discussion/comment/1486686/#Comment_1486686
(there was another SVGA example posted later on too)
Ideally we probably need some way to get objects stored in frozen code areas or SPI flash regions like Brian talked about. Also HyperFlash/HyperRAM offer some potential to be exploited by MicroPython down the track for extending capabilities now my driver is working, but that needs more consideration as to how to further integrate...too much to do!
1. Module import capability with Mu File System
2. Resolve board type (from ESP to a P2) for auto-detect
3. Release the interpreter so people may experiment and work towards creating modules. Ask Parallax to contibute to the function call nomenclature.
And maybe most importantly:
4. Define the initial extent of features around which MicroPython for P2 will function and encapsulate those features in a release. This includes the extent of interaction between MicroPython and Spin2/PASM running in other cogs.
MicroPython needn't do everything a P2 can do with Spin/PASM.
There's more, for certain, but these are my notes from yesterday. TeamOz is doing excellent work for the community!
And then make a software tool python top priority, which is 200 times slower than C and which does only support 1 core of 8. So only 1/(200*8) of the power of P2 is accessible with this tool. Even if you don't need the speed of C, you will be happy if your battery is running very much longer, if you can slow down the clock rate.
If Micropython is a must for education, then there are other hardware solutions already available, which fit better.
Sorry to be honest, but this decision of priority seems to be completely wrong!
Kind regards Christof
Did you see the presentation yesterday?
Educational customers are a very different audience. We would communicate the capabilities of MicroPython within the P2 as a system, rather than the P2's extensive feature set. Then, we work within these boundaries to deliver tutorials and examples. As it appears, the combination would be the most powerful MicroPython port once we develop modules to leverage the combination. It isn't common for customers in this realm to get wrapped up in clock cycles, code efficiency and what's missing based on the architecture of the processor.
The bigger question in my mind is what we'd do with the P2 in education. I don't see strapping it on a rolling robot chassis as all that interesting, but making an educational program (remember the "Understanding Signals" tutorial?) that looks inside of communication protocols, analog and digital signals and parallel processing could be useful for engineers and education. The only problem with this approach is that the market is smaller than, say, robotics.
All thoughts are welcome!
Not sure where you got the idea that python (or micropython) is 200 times slower than C... maybe on some specific mcu/platform? Certainly not in general.
Ken,
I think putting a P2 on a rolling(or otherwise moving) robot is a very exciting idea. The extra memory, performance, and capabilities of the P2 alone will make for a much more capable and interesting robot.
In particular, It’s being used for big data analysis and AI (artificial intelligence).
I use it every day at work. Yes, it’s slow. But the work I do doesn’t require it to be fast.
Basic was slow, then along came Visual Basic and it was slow too. When it gained enough users who complained about it being slow, but still continued to use it, MS built a compiler (the same base compiler as used in Visual C). I expect to see the same path with python, so probably micropython too at some stage.
Currently (at least for now anyway) micropython can only utilise one cog/core. The other cogs can be pasm (for speed) or spin, or any other language given the compiler. Fastspin can do a multitude of languages already!
I see the main program running on P2 likely to be micropython or spin2. On P1 that was spin. The main program in almost all circumstances does not need to be fast. It handles the main program, dedicating other cogs/cores to other time critical pasm code, and other cogs/cores to the slower things in spin2.
So, IMHO, micropython will be a major player for education, and that then flows to commercial products. Micropython on the P2 will open up so many opportunities that other micros cannot possibly hope to do. Here the P2 is unique!!!
Thanks again for all of your hard work on this!
I never used the Basic Stamp so I’m in the dark here.
I was sooo impressed with the micropython work the guys are doing. With an extension to access hub it can interact much better with other cogs/cores running other languages via a hub mailbox.
Now that we have 0.5MB of hub RAM (not flash), plus hubexec, we have an extremely powerful micro that is completely different to any other out there. Large soft-loadable programs run nicely on this mix where flash based micros come unstuck.
In just one (or two) cogs we can have a full-blown terminal using VGA or HDMI and keyboard (mouse optional) that can interact with any other cog(s). If you want a second terminal for debugging, no problem. This makes self-hosting a breeze.
I think it would be great to get the spin/pasm (pnut) compiler section (ie not the editor) written in micropython (python initially as that would be the fastest way to develop and test on a PC). Python in many ways is more like spin that any other language. And you can compile python to an .exe. I think Chip would love python.
Here's a video from the MicroPython creator (Damien George) at PyCon AU demonstrating 7 different ways to blink a led within the MP environment
The blink rates vary from ~58 kHz (naive, simple code) through 27,000 kHz using Viper mode, across the 7 examples. Thats a 500x speedup
We don't yet have a Viper equivalent for P2 within that first MP cog, partly because we have 7 other cogs that can run pasm2, but we can head in that direction over time.
https://www.youtube.com/watch?v=hHec4qL00x0&feature=youtu.be
Ah, but there's a problem - the reason why there isn't and won't be really fast AOT compilers for full python,ruby,javascript and similar languages is because of their dynamic type systems - if you're not sure what type some value is, you waste valueable time figuring out:
(Incidentally, I have to qualify "really fast AOT compilers for [language]" because there are AOT compilers for restricted subsets of dynamic languages - see RPython,mypyc,etc and of course there's JIT compilers for every major dynamic language.)
I talked about this with Brian after the presentation yesterday. We both think the thing to do is release a 'working set' combning all these components soon after MP 1.13 comes out.
From there people can either use the combined system, or modify it, or extract individual components such as the editor or whole-of-hub memory persistence display
This also gives us the chance to bake in a couple of necessary extras, including saving code to flash w/ wear levelling. It keeps our ongoing development quick in the mean time.
I don't think it will be too long before MP 1.13 is released
I didn't hear anyone ask on the video but are you still using p2gcc to compile MicroPython? Do you have any plans to change that at some point since p2gcc isn't currently supported as far as I know?
Speed and not to be able to deal with 7 of 8 cores are already mentioned as disadvantages of python on P2. The next item is code size of the interpreter. Because there is no linker usually very many routines are built in. On P2 all this occupies Hub Ram. The video showed 128k heap left over. Here you have to store all code and data for Micropython and the other cores.
How large is micropython for P2 at the moment?
Python has some advantages:
* You can interactively use large libraries like numpy, written in C like Matlab.
* Portability between systems. But this only applies, if you have same libraries on different hardware like CC on arduino.
If Python has to be teached, I would use a system with very high clock speed and big memory. Or a system, where the micropython can stay in flash. Raspi is of course the competition here. Cheap, fast, available, well documented, powerful, lots of memory.
I do think, that at some time the energy consumption of computers will matter. Python can then only survive, if it has a compiler. Because of this dynamic types it will even then be inefficient.
It seems to be strange to me, to educate kids today with a language which is so inefficient. For battery powered things python is a problem.
If Parallax wants to sell P2 they have to provide software which is known (not a special language like spin2, sorry) and which does support the specific strengths of P2.
Best Regards Christof
The good thing is a lot of the variable access code is abstracted anyway and there already is quite a lot of inherent overhead in referencing the variables to begin with, so the added read/write latency of HypeRAM on top may not appear to be quite so bad, at least in some applications where the performance can be traded for program size...TBD.
Another approach would be to somehow separate code from data, and keep Python variables in the heap but the code in external memory. Again not sure if/how this can be done. Probably more of a question needed to be asked of the creator of MicroPython (Damien George) as to its feasibility.
While Python is definitely not a language one would expect to fit well in the uC space, it is exactly what Parallax needs to make it successful in the EDU market. Python is the modern day Basic. I didn't watch the replay yet, however for EDU I don't think Python's inefficiency is going to be a problem. What Parallax will need is some useful, small Python libraries.
For the enthusiast/pro market, I think Parallax has made a real mistake with pushing Spin over C, however its Ken and Chip's money being spent. My concerns watching the sausage being made in this forum is that the P2 is now so complicated, unless some compiler is going to hide most of the internals.
riscvp2, since it already has a code cache built in, would also easily lend itself to running code from external memory such as flash, which would increase the heap size even more.
I don't want to pursue any of this unless there's interest, though. My version of micropython has been shunted aside (for better or for worse) so there's not much motivation to work on it further.
For example can flexc compile
http://www.tinypy.org/
Or
https://wiki.python.org/moin/PyMite
The idea is to have C as the main thing.
I don't know how hard it would be to port those to flexc. Why don't you give it a try and let us know?
+1
When I discovered the Prop 1, I went straight to PropBasic; Easiest language to learn, spits out pure PASM. It pains me to have something work harder than it needs to.
No. - Edit: Tinypy gives with FlexC error: inline struct expressions not supported yet. Catalina reports a different problem.
Because I have no P2. Unfortunately it is not yet offered for a reasonable price as a board and in Germany.
And because I don't think, it makes any sense to use Python exept perhaps for education, if some teacher think this is the only way. It's Parallax, who could have the benefit, to bring these 2 very different goals together.
The libraries and their documentation (!!!!) has to be done twice, if things are independent. Flexc could be used as a some sort of linker to bring in only the needed libraries. Your compiler with a CMM and a tiny little scripting language, which has a subset of the syntax of Python seems perhaps to be a solution. PBasic is not at all a full blown MS-Basic too.
Well, I don't think, that you have to do this for free. Other producers have to invest in software too. The great libraries of teensy or of esp32 did not come from alone. As a customer I do pay for software via a higher hardware price. Teensy sells the bootloader chip for about 7 $. https://www.pjrc.com/store/ic_mkl02.html So I assume, there is about 2$ for software per sold system? As only Parallax sell their P2, they have to put the price onto P2.
Parallax does spend such money for spin2 and for pasm and for this debug()-function. The problem is, that they cannot spend the money for spin2+flexgui+catalina+micropython+tychyon+? So the question is, how can things be brought together? These tools have to be professional and to be very reliable. It is no fun at all, if you are fighting a bug and don't know, if is your bug or the compilers bug. What will Parallax do, if you do not continue your work?
I see my role as a (potential) customer of the "makertype". I am not a software professional. I have tried quiet some boards in the past and different languages. Including spin1, forth and python. Using spin1 I was forced to use pasm1.
I do think, I have some overview over the competition of makerboards and try to bring the point of view of makers, who know the arduino invironment, in here. As I work in a bigger company, I cannot imagine at all that a company with more than 5 employees would use a P2 (these days without a official datasheet) and with spin2.
I did buy some p1s some years ago. I left p1 programming, because it was more easy to use arduino-cc and their libraries. P1 ran out of memory, sometimes the tools have not been relieable. Assembler was not needed any more using the very powerful Arduino-CC.
I tried to contribute to the Parallax forums in the past by posting hopefully interesting projects, but Parallax seems not to care very much of this kind of showroom for their products. Contributions of the first forum have been lost. Long time ago lots of fun: https://forums.parallax.com/discussion/148487/drops-rain-and-sleep-and-the-prop-using-propbasic#latest
Well, I do try to contribute to this development writing this point of view and in this case a suggestion, which is not so bad...
@Mickster, yes PropBasic was a breakthrough for me too with P1!
Best regards, Christof
There are plenty of edge case reasons why micropython makes sense. Is it a main-line solution? The future of microcontroller development? Nah, but I still have an angle grinder even though I shouldn't cut pizza with it.
