PNut exe detected as virus — Parallax Forums
This discussion was created from comments split from: PNut/Spin2 Latest Version (v34t - DEBUGGER added).
  • My computer (Win10 Pro) says that the ZIP file has a virus....
    239 x 64 - 4K
  • JonnyMac wrote: »
    Yup, still a problem. That's why I stick with Win7 Pro.
  • cgraceycgracey Posts: 14,293
    I doubt there's really a virus in there. Does anyone have an opinion on this?
  • Windows 10 Pro sure thinks so -- so much that even after getting it downloaded (used Firefox), as soon as I unzip, Windows Defender obliterates PNut. I'm trying to get a screen cap so you can see what Win10 is whining about.
  • It's whining about PNut_v34t.exe.
    No problems with download, unzip with 7-zip, and run .exe
    Running Windows 10 Pro 1909 build 18363.959
    edited 2020-07-15 21:27
    Windows 8.1 Pro, each and every security update applied, up to ~6 hour ago:
    P.S. Sorry, only brazilian portuguese text, but should be readable to everyone...
    P.S.II - Grave = Severe
    824 x 203 - 12K
  • RaymanRayman Posts: 16,104
    I'm having trouble with this one too...
    This happened before and I figure out a work around, but don't remember it now...
    Ok, I got it... You have to get into Windows Defender and "Allow on Device" for this program...
    Here's the window you need to get to, but this is AFTER it was allowed...
    500 x 728 - 27K
    How do we stop this from happening? Do we send Microsoft money?
  • cgracey wrote: »
    Signing the executable generally keeps the crazy heuristics at bay - PropTool is signed, so you already have a certificate laying around somewhere
    edited 2020-07-15 23:43
    Need to sign
    Yes, costs money
    @ersmith eventually did this for FastSpin
    Yes, sorry I wasn't clear -- what I meant was the virus that had been detected; it was as @Yanomani shows.
  • Rayman wrote: »
    Need to sign
    Yes, costs money
    Not necessary:
    Parallax can self-sign an CA certificate and distribute (make downloadable) it to its clients/customers/users so that they can import it into trusted CA authorities in windows certificate store. Then any further certificate used for whatever reason (eg software signing) and signed by this 'root CA parallax certificate' will be recognized by the OS.
    Any skilled organization sooner or later internally do this if not for other things at least to sing excel macros and avoid MS Office complaining on files from network shares as disabling the office control becomes dangerous for outside malware macros.
    Any admin of the PC can import the certificate.
    In organizations, schools, ... it can be deployed via MS AD GPOs.
    I am pretty sure linux have also something similar. Anyway it doesn't matter since Parallax is offering only Windows tools :D
  • All that certificate bogus is ridiculous. I've been there myself. You can buy certificates for ~$40 in the internet. They ask you to enter your address information but they don't verify anything. All you need is a credit card (which can be stolen) or a Paypal account (which can be hacked). So I wouldn't be surprised if signed trojans appear.
  • VonSzarvasVonSzarvas Posts: 3,631
    edited 2020-07-16 11:25
    Or generate free trusted certs that are already validated here : https://www.sslforfree.com
  • VonSzarvas wrote: »
    Unfortunately SSL certificates don't work for code signing. :(
  • ersmith wrote: »
    VonSzarvas wrote: »
    Darn, I thought they provided general certs too. Must have read too quickly.
  • I got PNut 34T to work on one of my smaller, not virus protected, laptops. But on my *bigger* machine with Defender / Kaspersky and all the virus protection stuff on it - no go, zip, nada, deleted automatically. Grrrr... Is there a work around?
    I described a way above for just the Windows A/V. Other A/V may also have override settings.
    Another way I've seen work is to sideload, that is, get onto your computer not by the internet, but some other way...
    Maybe download on a Mac or something and then copy to a cloud file service, for example...
    Or, USB stick.
    I think anything downloaded from the internet gets higher scrutiny...
    edited 2020-07-16 15:33
    I'm curious if building the .exe file with static (and not dynamic) linking would help...
    I ran dependency walker on pnut and it shows some errors...
    Never mind...
    Sorry, was using outdated tool...
    edited 2020-07-16 15:32
    Hmm... I ran this on one of my codes and it gives the same sort of errors...
    Maybe that doesn't mean anything...
    Sorry, this is probably a meaningless side-track...
    But, looks like depends.exe doesn't work on Win10. Found a MS note to use this instead:
    https://github.com/lucasg/Dependencies
    This doesn't show any errors...
    What's worse than single-platform tools is zero-platform tools.
    Did v34s not have this problem?
  • I dug out my win10 laptop, and using @Raymond method, I was able to install. I never installed v34s on my laptop, so I don't know if it had the same problem.
  • Bitdefender thinks v34s is a virus. I have not tried v34t yet.
    John Abshier
  • JonnyMacJonnyMac Posts: 9,714
    edited 2020-07-16 16:54
    Every version of PNut that I've tried has come with a warning; T was the first version the generated to virus alert.
    I did find a work-around for my PC: I copied the files to the destination folder (after bypassing the warning when attempting to copy), and and then ran PNut before asking WD to scan. I got the normal "Are you sure you want to run this program ?" warning. After running, everything seems fine.
    I will experiment with DEBUG to provide feedback, but I do look forward to the integration into Propeller Tool as I find that a far more comfortable editing environment.
  • Sorry about the problems you're having with PNut and AV systems on your computers.
    It's quite common for at least one of the published antivirus systems to detect a potential problem with new software. I think this is because many now employ heuristic "fingerprint"-type techniques to try to catch malicious software early based on the known profiles of previous, hopefully verified, infections. Quite often, the lack of a download history for a given app is enough to trigger warnings of "suspicious" software in some systems, such as Norton. That makes life tough for end-users and developers. Digitally-signing may improve the situation, but isn't a guarantee it will prevent false-positives... I'm very curious about it in this case. We usually don't digitally sign executables while in active development. I haven't been digitally signing the alpha releases of Propeller Tool and haven't heard of people experiencing any problems yet.
    Regardless, we may try digitally signing PNut as an experiment for this case.
    Chip and I discussed it and I'm pretty sure this is all due to the exe compressor, which I've seen cause false detections before. I usually check exe's I produce with VirusTotal and, honestly, I don't worry about it if the number of detections is low (around 2 to 4 out of 70+ AV systems) because they are typically heuristically-triggered (indicated by their system) and often from mostly-unknown AV engines. When something triggers many, or more well-known AV engines, then it's more cause for concern in my experience. OS-level triggers (built-in AV systems) are also, of course, a big concern because they are seriously inhibiting and scaring users. I don't know how many times I've been in contact with Symantec about a false-positive detection with seemingly no way to get them to prove it or fix their engine. Haven't had to do that much in recent months. In my experience, using exe compressors, doing certain things like adding in TCP/UDP-IP libraries, creating a stub resource that I attached to the end of the built exe, etc. are all things that falsely trigger some AV systems. Very frustrating.
    I could start my own protest movement against unfair software profiling.
    By the way, the compressed version of PNut_v34f.exe through PNut_v34t.exe triggers 11 to 13 detections across the current set of 72 AV systems that VirusTotal uses. The uncompressed version of v34t triggers only 2 out of 72, and only heuristically. I'm still seriously thinking this is all false-positive results.
    <soapbox>This grief is all brought to us by greed, ill will, and an unending supply of smart people using their skills for high-tech malice rather than for the betterment of humanity.</soapbox>
  • pilot0315pilot0315 Posts: 977
    edited 2020-07-17 00:19
    @System
    @JonnyMac
    I had issues with windows 10 pro not liking Pnut.
    Try this:
    1 Right click on Pnut icon and select properties.
    2. Compatibility
    3. Run the compatibility troubleshooter
    This made windows 10 accept Pnut.
    I've been using an .exe packer to reduce the .exe size to 40% of original. I will not use that in the coming releases. There should be no problem, then.
