Add a Library "include" / Import Library ( .h) into BLocklyProp Solo - — Parallax Forums
In Simple IR Remote Codes Driving Code - libraries are included I would like to build on that to add remote control buttons for the gripper but I assume I need the "servo.h" library How do I access it thru BlocklyProp and or where is it located in the left hand column in thr BlocklyProp Solo screen
  • I think you can just click on the "servo" group in the menu on the left side of the screen. That gives you the option of selecting blocks for different types of servos. If you are using the parallax gripper you would use the standard servo (the top one in the list)
  • Thanks
    I did not realize that
    Issue closed
