How to use CRCBIT and/or CRCNIB for CRC7 (for MMC)?
in Propeller 2
For uSD, you can ignore the CRC, but eMMC is making me use it...
I tried for a second to use the assembly commands CRCNIB and CRCBIT to speed it up.
But, I can't figure it out...
Anybody know how to do this?
Here's my Spin2 version that works:
PUB crc7(buffer,count):r | crc, c,i, j,n 'calculate crc of series of bytes for MMC
crc := 0
repeat j from 1 to count
c := byte[buffer++]
'Number of loops is 8 for first bytes, 7 for last byte
if j==count
n:=7
else
n:=8
repeat i from 1 to n
crc <<= 1
if c&$80
crc+=1
if crc&$80
crc^=$9
c<<=1
crc:=crc & $7F
r := (crc<<1)+1
return r
http://forums.parallax.com/discussion/171293/crc8
From this page: http://doitwireless.com/2015/05/31/crc-routines/
Your polynomial is $9.
You may have to reverse the byte c before running the rep loop, and the last loop will need to be 7
You should be able to do something like this Sorry, dont have time to test atm.
or using the crcnib
With the traditional way of shifting in bits, there needs to be preliminary shifts to load the data into the crc result. Not so with CRCBIT since the
incoming bit and the outgoing bit are xor'd to see if the poly needs xor'ing into the result.
This website is helpful: http://www.sunshine2k.de/coding/javascript/crc/crc_js.html
I see SMBus is "CRC8_MAXIM" there. The actual polynomial is $31, but we need to use the reversed version, $8C, with the CRCBIT routine, as shown by @JonnyMac
Also, that page says both the input and the output are bit reversed. But, this seems to be done automatically by CRCBIT somehow...
Also, I see a lot of people are using a table to do this... Maybe that's the way to go. I'll just use the LUT, once I figure out how to translate CRC8_MAXIM into CRC7 for MMC...
Or, maybe I can just make the table without actually figuring anything out...
Just use the crcbit or crcnib. You'll be glad you did! Sorry I'm busy at work so I can't get it done for you just now but perhaps later.
Just run a single known character thru the crcnib once (just a nibble( and compare the result with your spin code. Retry with the crc initialised to 0 or $FF, try reversing the characters bits, and the reverse of the polynomial ($31 and $8C). There are not a lot of combinations here and you should find one that matches your spin. BTW Are you sure your spin is correct?
I’ll try and find some time to test it with the crcbit crcnib instructions.
Spent quite some time on this this morning.
I cannot get your code to give the correct results. If you want me to spend any more time on it I need a working program that I can compile with serial output that I can test with. Either pnut or fastspin is fine.
This sequence is a know valid one for SD cards
$40 $00 $00 $00 $00 $95
where $95 is the crc value.
From what I've been able to research, the final crc value calculated is $4A which is then shl #1 and add #1 to give $95.
In hindsight I probably should have gone back to study the algorithm again. I haven't done it since the 80's.
I found this c code but I cannot run it to verify if it works and i don;t understand the "for" statement
#include <stdbool.h> crc_t crc_update(crc_t crc, const void *data, size_t data_len) { const unsigned char *d = (const unsigned char *)data; unsigned int i; bool bit; unsigned char c; while (data_len--) { c = *d++; for (i = 0x80; i > 0; i >>= 1) { bit = crc & 0x40; if (c & i) { bit = !bit; } crc <<= 1; if (bit) { crc ^= 0x09; } } crc &= 0x7f; } return crc & 0x7f; }/* * Table for CRC-7 (polynomial x^7 + x^3 + 1). * This is a big-endian CRC (msbit is highest power of x), * aligned so the msbit of the byte is the x^6 coefficient * and the lsbit is not used. */ const u8 crc7_be_syndrome_table[256] = { 0x00, 0x12, 0x24, 0x36, 0x48, 0x5a, 0x6c, 0x7e, 0x90, 0x82, 0xb4, 0xa6, 0xd8, 0xca, 0xfc, 0xee, 0x32, 0x20, 0x16, 0x04, 0x7a, 0x68, 0x5e, 0x4c, 0xa2, 0xb0, 0x86, 0x94, 0xea, 0xf8, 0xce, 0xdc, 0x64, 0x76, 0x40, 0x52, 0x2c, 0x3e, 0x08, 0x1a, 0xf4, 0xe6, 0xd0, 0xc2, 0xbc, 0xae, 0x98, 0x8a, 0x56, 0x44, 0x72, 0x60, 0x1e, 0x0c, 0x3a, 0x28, 0xc6, 0xd4, 0xe2, 0xf0, 0x8e, 0x9c, 0xaa, 0xb8, 0xc8, 0xda, 0xec, 0xfe, 0x80, 0x92, 0xa4, 0xb6, 0x58, 0x4a, 0x7c, 0x6e, 0x10, 0x02, 0x34, 0x26, 0xfa, 0xe8, 0xde, 0xcc, 0xb2, 0xa0, 0x96, 0x84, 0x6a, 0x78, 0x4e, 0x5c, 0x22, 0x30, 0x06, 0x14, 0xac, 0xbe, 0x88, 0x9a, 0xe4, 0xf6, 0xc0, 0xd2, 0x3c, 0x2e, 0x18, 0x0a, 0x74, 0x66, 0x50, 0x42, 0x9e, 0x8c, 0xba, 0xa8, 0xd6, 0xc4, 0xf2, 0xe0, 0x0e, 0x1c, 0x2a, 0x38, 0x46, 0x54, 0x62, 0x70, 0x82, 0x90, 0xa6, 0xb4, 0xca, 0xd8, 0xee, 0xfc, 0x12, 0x00, 0x36, 0x24, 0x5a, 0x48, 0x7e, 0x6c, 0xb0, 0xa2, 0x94, 0x86, 0xf8, 0xea, 0xdc, 0xce, 0x20, 0x32, 0x04, 0x16, 0x68, 0x7a, 0x4c, 0x5e, 0xe6, 0xf4, 0xc2, 0xd0, 0xae, 0xbc, 0x8a, 0x98, 0x76, 0x64, 0x52, 0x40, 0x3e, 0x2c, 0x1a, 0x08, 0xd4, 0xc6, 0xf0, 0xe2, 0x9c, 0x8e, 0xb8, 0xaa, 0x44, 0x56, 0x60, 0x72, 0x0c, 0x1e, 0x28, 0x3a, 0x4a, 0x58, 0x6e, 0x7c, 0x02, 0x10, 0x26, 0x34, 0xda, 0xc8, 0xfe, 0xec, 0x92, 0x80, 0xb6, 0xa4, 0x78, 0x6a, 0x5c, 0x4e, 0x30, 0x22, 0x14, 0x06, 0xe8, 0xfa, 0xcc, 0xde, 0xa0, 0xb2, 0x84, 0x96, 0x2e, 0x3c, 0x0a, 0x18, 0x66, 0x74, 0x42, 0x50, 0xbe, 0xac, 0x9a, 0x88, 0xf6, 0xe4, 0xd2, 0xc0, 0x1c, 0x0e, 0x38, 0x2a, 0x54, 0x46, 0x70, 0x62, 0x8c, 0x9e, 0xa8, 0xba, 0xc4, 0xd6, 0xe0, 0xf2filename is crc7expl.zip
It seems this kind of thing is ancient history and not so many people still remember how to do it by hand
There is a left shift and a +1 at the very end.
I think that 1 at the end is actually the stop bit, which is why it is not included in the above...
Here is the important part:
/****************/ static unsigned char Encode(unsigned char Seed, unsigned char Input, unsigned char Depth) /* -- Produce a 7 bit CRC value Msb first. Seed is last round or initial round shift register value (lower 7 bits significant). Input is an 8 bit value from byte stream being CRCd. CRC register is seeded initially with the value 0 prior to mixing in the variable packet data. Depth is usually 8, but the last time is 7 to shift in the augment string of 7 zeros. *****************/ { /*begin-Encode. - local defs: */ register unsigned char regval; // shift register byte. register unsigned char count; register unsigned char cc; // data to manipulate. #define POLYNOM (0x9) // polynomical value to XOR when 1 pops out. /*BODY*/ regval = Seed; // get prior round's register value. cc = Input; // get input byte to generate CRC, MSB first. /* msb first of byte for Depth elements */ for (count = Depth // set count to 8 or 7. ; count-- // for count # of bits. ; cc <<= 1 // shift input value towards MSB to get next bit. ) { // Shift seven bit register left and put in MSB value of input to LSB. regval = (regval << 1) + ((cc & 0x80) ? 1 : 0); // Test D7 of shift register as MSB of byte, test if 1 and therefore XOR. if (regval & 0x80) regval ^= POLYNOM; } // end byte loop. return (regval & 0x7f); // return lower 7 bits of CRC as value to use. } /*... end-Encode. .....*/ void CCRC7Dlg::OnBnClickedButton1() { char* cp; // pointer into command line argument list. int walker; // index into argv parameter list. int value, nuval; // temporary values from cmd line and CRC generator. unsigned char CrcAccum; // local storage of each round of CRC. UpdateData(true); //fake command line input int argc; char argv[100]; argc = 5;+32; //#characters 6 +payload argv[1] = 64;// +1; //64==CMD0, 64+1=CMD1 for (int i=2;i<40;i++) argv[i] = 0; // 7 bit shift register CRC computation across 5 byte SD message field // with 6th byte of message being the CRC field generated herein. if (argc != (1 + 5)) { //fprintf(stderr, "\nCRC_7 command line syntax error.\n"); //fprintf(stderr, "Requires 5 argument(s) to encode w/crc value\n"); //fprintf(stderr, "Usage is :\nCRC_7 0 0 0 0 0\n"); //fprintf(stderr, " or similar with decimal value for each byte.\n"); //fprintf(stderr, " Use CRC_7 64 0 0 0 0\n to generate example run.\n\n"); //return 1; // EARLY EXIT, CMND LINE SYNTAX ERROR } // start w/seed of 0 per algorithm. CrcAccum = 0; // loop through 5 command line decimal values. Display in HEX to // stdout, can be captured via >> on cmdline. for (walker = 1; walker < argc; walker++) { //cp = &argv[walker]; //RJA added & value = argv[walker];//RJA changing text to char for input cp;// atoi(cp); nuval = Encode(CrcAccum, value, 8); //printf(" CRC remainder of 0x%02X for 0x%02X input byte.\n" // , nuval // , value //); CrcAccum = nuval; // reload crc accum. } // mix in last 7 bits of 0s to augment, and then shift final CRC // remainder left and OR in fixed 1 LSB. nuval = Encode(CrcAccum, 0, 7); value = (nuval << 1) + 1; //printf("CRC remainder after augment is 0x%02X with FINAL CRC byte of 0x%02X.\n" // , nuval // , value //); return;//0; }You need to verify a spin program that takes $40 $00 $00 $00 $00 and gives $65. I can then convert it to pasm and then use the crcbit/crcnib instructions.
I think you had it
The shift and 1 at end is the stop bit
#include <stdio.h> unsigned char crc7(unsigned char *buf, int len) { int i, j; unsigned char crc, val; crc = 0; for (i = 0; i < len; i++) { val = buf[i]; for (j = 0; j < 8; j++) { crc <<= 1; if ((val & 0x80) ^ (crc & 0x80)) crc ^=0x09; val <<= 1; } } crc = (crc << 1) | 1; return(crc); } int main() { unsigned char sample1[] = {0x40, 0x00, 0x00, 0x00, 0x00, 0x95}; unsigned char sample2[] = {0x48, 0x00, 0x00, 0x01, 0xAA, 0x87}; printf("CRC = %x\n", crc7(sample1, 5)); printf("CRC = %x\n", crc7(sample2, 5)); return 0; }EDIT: I replaced byte[@crc] with just crc, and masked it to 8 bits at the end.
EDIT2: I also replaced byte[@val] with just val. cspin was trying very hard to maintain 8-bit values.
PUB crc7(buf, len) | i, j, crc, val crc := 0 i := 0 repeat while (i < len) val := byte[buf][i] j := 0 repeat while (j < 8) crc <<= 1 if ((val & $80) ^ (crc & $80)) crc ^= $09 val <<= 1 j++ i++ crc := (crc << 1) | 1 return crc & 255Like to make it faster with new crcnib instruction ...
mov len, ##LENGTH mov ptra, ##STARTADDR mov crc, #0 wc loop rdbyte data, ptra++ rep #2, #8 shr data, #1 wc crcbit crc, #$90 ' reverse of 09 for opposite CRCBIT working order djnz len, #loop rev crc shr crc, #24 or crc, #1 EDIT: and crc, #$FF ' for just 7 bit crc shifted after stop bit included. EDIT2: actually redundantThe spin code at the top post is not giving the correct result for the initial command 0 which must be $95 but it returns $93
crc := crc7(@buf2, 5) ser.TxHex8(crc) ser.TxCR() PUB crc7(buff,count):r | crc, c,i, j,n 'calculate crc of series of bytes for MMC crc := 0 repeat j from 1 to count c := byte[buff++] 'Number of loops is 8 for first bytes, 7 for last byte if j==count n:=7 else n:=8 repeat i from 1 to n crc <<= 1 if c&$80 crc+=1 if crc&$80 crc^=$9 c<<=1 crc:=crc & $7F r := (crc<<1)+1 return r DAT buf2 byte $40,0,0,0,0,$95What is happening is that it is getting the wrong input characters
Found a bug in my code - just retrying.
Yes, the crc generated is wrong:(
It also generates the wrong value $1B which should be $87 for the command8
'Send command and sometimes get response 'first, need to calculate CRC7 cmdout[0]:=$40+op cmdout[1]:=(parm>>24)&$FF cmdout[2]:=(parm>>16)&$FF cmdout[3]:=(parm>>8)&$FF cmdout[4]:=(parm>>0)&$FF cmdout[5]:=0 c:=crc7(@cmdout,6)I’ll try tomorrow ...
Late here...
PUB crc7(buf, len) : crc | val repeat len val := byte[buf++] repeat 8 crc <<= 1 if (val ^ crc) & $80 crc ^= $09 val <<= 1 crc := ((crc << 1) | 1) & 255An alternate CRCNIB may speed this up even more. I'm just not 100% sure what the xx values are. Maybe they are just the same as the single bit case and the HW just figures it out for you. This could then be as fast as 14 clocks per byte if the fifo is used.
mov len, ##LENGTH mov ptra, ##STARTADDR mov crc, #0 wc loop rdbyte data, ptra++ rev data setq data crcnib crc, #xx ' what constant value to use? crcnib crc, #xx djnz len, #loop rev crc shr crc, #24 or crc, #1I'll try crcnib now
PUB crc7(buf, len) : crc | i,val repeat i from 0 to len-1 val := byte[buf][i] << 24 org setq val crcnib crc,#$90>>1 crcnib crc,#$90>>1 end return (crc rev 6) << 1 | 1or with the outer loop also in PASM:
PUB crc7(buf, len) : crc | val org cr7lp rdbyte val,buf add buf,#1 shl val,#24 setq val crcnib crc,#$90>>1 crcnib crc,#$90>>1 djnz len,#cr7lp end return (crc rev 6) << 1 | 1AndyI think I'm seeing that I got hung up by the code I found and that last 7 bits of zero it does.
Although it works, it is unlike all the other code...
Now, I have code that just works on the first 5 bytes and doesn't have that dummy 6th byte:
PUB crc7_c(buffer,count):r | crc, c,i, j,n,len 'calculate crc of series of bytes for MMC crc := 0 repeat j from 1 to count-1 c := byte[buffer++] repeat i from 1 to 8 crc <<= 1 if ((c^crc)&$80)>0 crc^=$9 c<<=1 crc:=crc & $7F r := (crc<<1)+1 return rWas just about to figure this all out, but maybe Andy beat me to it...
Or, maybe @"Dave Hein" or @rogloh would work this way too...
