Looking for Propeller + LW20 + Bluetooth consultant to write embedded code for project
Hi,
I'm currently developing a couple prototypes that utilize the Propeller, Lightware LW20 range sensor, and Bluetooth module, and would like to see about engage an experienced consultant to help with the embedded code to interface and analyze the LW20C sensors signal to interpret distances and initiate certain outputs depending on these values. Please reference schematic, block diagram and pictures of hardware setup.
Interested parties, please send me a Private message via the forum with your contact details so I can connect with you.
Thanks. Best, Justin.
Justin McDonough
Justin McDonough
Just to let you know, I removed the duplicate post in the Propeller category as we always try to prevent duplication and dilution of replies across multiple threads.
Good luck with your project, and hopefully you will connect with some people here that can help.
And it goes without saying--- if you can share pictures and maybe a little story of your future gadget powered by a Propeller, that would always be interesting !!! And maybe it could be considered for a future spot in the newsletter too, if you wanted to share with the world!
https://www.cnet.com/roadshow/news/velodyne-velabit-small-inexpensive-lidar-ces/
If you go back and edit your first post, look for "attach a file". You can use that the attach a picture.
