Can Propeller 1 or 2 be used to create a contact-less body temperature sensor
Hi,
Can Propeller 1 or 2 be used to create a contact-less body temperature sensor ? ( to check for fever )
If yes, which low cost temperature sensor would be most suitable for propellers ?
Unfortunately the medical grade version
MLX90614ESF-DCC
is out of stock in Mouser, Digikey, Element14 and RS.
Got any other more available infrared chip?
https://www.newegg.com/p/2S7-00VK-00D22?item=9SIADG45WJ0598&source=region&nm_mc=knc-googlemkp-pc&cm_mmc=knc-googlemkp-pc-_-pla-keyboardmall-_-gadgets-_-9SIADG45WJ0598&gclid=CjwKCAjwqdn1BRBREiwAEbZcR-16Mmimf2aNK16XwfmKnMFIs9Bnz3yoleeNIV3nGwzAFUdYoNdH5hoCV4EQAvD_BwE&gclsrc=aw.ds
Agreed, but I think the availability of the particular sensor is in question.
MLX90614ESF-DCC
One version is calibrated.
That might work.
A bit expensive though ...
