Propeller font problem
tritonium
Hi
Was roaming around the forum looking at ping posts and came across what I suppose to be a circuit diagram using the prop font.
What I saw was
So I have the parallax font ok but maybe its not visible to 'ms edge' browser.
Its tucked away in...
C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Help\Content\Resources\Stylesheets\Parallax.ttf
What do you think I should do?
Dave
What I saw was
│┌───┐ ┌───┐│ Connection To Propeller
││ ‣ │ SR04 │ ‣ ││ Remember SR04 Requires
│└───┘ └───┘│ +5V Power Supply
│ Vcc Trig Echo Gnd │
5V │ │ │ │
 │ 1K  10K │
trigger ┘ │ │
echo ─────┘ │
Dave
<html> ┌───────────────────┐ │┌───┐ ┌───┐│ Connection To Propeller ││ ‣ │ SR04 │ ‣ ││ Remember SR04 Requires │└───┘ └───┘│ +5V Power Supply │ Vcc Trig Echo Gnd │ └──┬────┬────┬───┬──┘ 5V │ │ │ │  │ 1K  10K │ └───┘ │ │ │ │ │ │ trigger ┘ │ │ echo ─────┘ │  </html>Save the file as something.html, then open it in a web browser. Do a select-all (ctrl-A), then a copy (ctrl-C). Open the Propeller Tool, and paste (ctrl-V) what you just copied from the browser screen. From there, it's a matter of figuring out where the line breaks go, adding spaces, maybe duplicating or deleting some graphics, etc. Anyway, this is what I got when I did all that:
Thanks- that did the trick- still needed heavy correcting as you say for newlines and missing spaces; you must have spent some time correcting it- without your example I think I would be defeated.
However it wasn't the circuit I was looking for- in a thread now lost, was mention of connecting six pings (I think) to six + 1 prop pins, (plus supply) and also only using one pin not two for one ping.
I've figured out how I would do it but was wanting to check against other ideas.
edit- to add this was not a parallax ping but sr04...
Dave
@Publison
https://forums.parallax.com/discussion/135899/one-buck-ultrasonic-sensor/p3
near top of page 3
Dave
Thanks!
Well I've collected a few approaches......
yet to try
Hmm... for some reason the thumbnail is clipped- click image to see whole
still have trouble inserting image....
Dave
